Connect duet 3 to Rpi 4 with USB cable
    TRATOON
    Is it possible to connect the Duet 3 to a rpi 4 with a usb cable or any other method without the ribbon cable, as it is too short
    undefined 1 Reply Last reply 4 Sept 2022, 19:49 Reply Quote 0
      jay_s_uk @TRATOON
      @tratoon no. it needs to be SPI, so the ribbon cable
      undefined 2 Replies Last reply 4 Sept 2022, 19:52 Reply Quote 0
        TRATOON @jay_s_uk
        @jay_s_uk is there anyway to only connect necessary pins or are all of them necessary. If so which ones need to be connected?
          TRATOON
          @jay_s_uk would it be pins SBC 3.3v, mosi,miso,Spck,gnd
            TRATOON @jay_s_uk
            @jay_s_uk I looked at https://forum.duet3d.com/topic/20883/duet3-sbc-wiring-without-the-ribbon-cable/14 but I still don’t understand which pins need connections and where they go on both boards also some of the poster’s pin outs don’t match mine like TFR_rdy and spi_npcs0
            undefined 1 Reply Last reply 4 Sept 2022, 20:51 Reply Quote 0
              jay_s_uk @TRATOON
              @tratoon yes, you can just connect the pins required but I really wouldn't recommend running a cable any longer than the one provided as you will run into issues. SPI really inst great over long cables.
              Why do you need the SBC? For WiFi?
              undefined 1 Reply Last reply 4 Sept 2022, 22:28 Reply Quote 0
                TRATOON @jay_s_uk
                @jay_s_uk yes and as far as I’m aware faster upload speeds . Coul you please explain the differences.
                • undefined TRATOON marked this topic as a question 5 Sept 2022, 07:31
                • undefined TRATOON has marked this topic as solved 5 Sept 2022, 07:31
                7 out of 7
