    New experimental firmware 1.20beta2
    Firmware installation
    12
    44
    5.7k
      @darookee:
      @dc42:
      Were you trying to home all, or specific axes? Which axes show up in DWC as homed, before and after sending the command? Have you created any additional axes using M584?
      First I did home all, then I quickly hit the emergency stop button, because it tried to move waaay out of the printer frame, as it was reporting Y-169 and my Z-homing point is at X100Y100. Then I tried homing X and Y seperately. Directly they were marked as 'not homed' (all buttons orange). I only have X Y Z (and E).
      At which point(s) did you get the "Homing failed" message?
      The buttons will be marked as "not homed" when you ask to home those axes. They should change to "homed" status as each one is completed.
      • darookeeundefined
        darookee
        @dc42:
        The message appeared directly after the homing procedure, the buttons did not change.
        Here is my homex.g
        ; Lift Z relative to current position
        G91
        G1 Z5 F12000
        G90
        ; Move quickly to X axis endstop and stop there (first pass)
        G1 X-205 F1800 S1
        ; Go back a few mm
        G91
        G1 X5 F12000
        G90
        ; Move slowly to X axis endstop once more (second pass)
        G1 X-205 F360 S1
        ; Lower Z again
        G91
        G1 Z-5 F12000
        G90
        homey.g is the same, just with X. I think I didn't change anything after generating it with the configurator. I certainly did not change anything here after the update.
        • andreduplessisundefined
          andreduplessis
          @darookee:
          After updating my CoreXY can't home. At first it reported X-62Y-123 (or similar), at the second try it reported X0Y-0.4 and now it reports X-0.0Y-100.3 after trying to home X and Y. It also reports
          Error: Homing failed
          These are in my config.g
          M574 X1 Y1 Z0 S0
          M208 X-11 Y-0.75 Z0 S1
          M208 X200 Y200 Z240 S0
          Could this be because of the stall detection feature? I have not configured it, so I was thinking that it will not be used…?
          I have the same homing issue on coreXY. After some digging around, I think that the issue creeps in the code where the endstops are checked.
          In DDA.cpp around line 1270 the function is returned and part just below it which sets the homed axes is never invoked on a platform that shares drives:
          if (endStopsToCheck == 0 || kin.QueryTerminateHomingMove(drive))
          	MoveAborted();									// no more endstops to check, or this axis uses shared motors, so stop the entire move
          	return;
          I may be smoking something, but that is the only location that I could find where the AxesHomed bits are set. After removing the return, the axes homed like before (barring everything else that might now be broken πŸ™‚ )
            You are right, it's a bug. I shouldn't have added the 'return' at line 1274. I'll release a new beta tomorrow. In the meantime, CoreXY users should revert to version 1.20beta1.
            • KeeganBundefined
              KeeganB
              Is anyone seeing any weird behavior with controlling heaters?
              on fresh power up both the hot end and the bed heaters are set to "off." When I click them in DWC I can cycle through to active, but then it goes into "changing tool" mode and I can't do anything until it hits target temp…?
              Artemis
              Rostock Max v2
              Orion
                That's normal behaviour if you have tool change files that wait for your tools to reach temperature.
                • KeeganBundefined
                  KeeganB
                  @dc42:
                  Ah, I found it! I think these must have been created by the RRF configurator. I recently used it to redo all of my config files fresh in an attempt to solve my wifi issues. Thanks David.
                  Artemis
                  Rostock Max v2
                  Orion
                  • kazolarundefined
                    kazolar
                    I think I figured out an issue. It has something to do with how the Duet powers up and initializes. If it powers and hits some race condition or if I try to home it before it finishes some part of the startup routine – which is not clear when it does, it doesn't home correctly, if I wait a couple of minutes after power up. It appears to work properly.
                    Is there a way to add something to end config.g to print a message to the console -- Ready or something like that?
                    • MoS-tekknixundefined
                      MoS-tekknix
                      Additional, i'm not able to print Files with Spaces or Brackets in the Filename anymore.
                      They upload just fine, but they are not able to print cause they will not be found. The Filename is not the same anymore.
                      Uploaded a File Test Cube (0.4).gcode
                      Trying to print:
                      [[language]]
                      M32 Test Cube (0.4).gcode
                      Error: M32: GCode file "Test Cube .gcode" not found
                      As you can see, eveything after ( will be cutted. Even if the Space after Cube is visible, no Special-Character can be used.
                        The open-bracket character starts a comment in standard CNC gcode, so filenames with brackets in them should never have been allowed - just like filenames with semicolons in them. In the 1.20release I intend to allow filenames in commands such as M32 to have double quotation marks around them, which will provide a way round this.
                          I've just released 1.20beta3 which fixes a number of bugs in 1.20beta2. See the whats_new file for details.
                            MoS-tekknix
                            @dc42:
                            Ah, was not aware of this. Sorry if i've overseen this.
                            Will test beta3 now
                            Cheers
                            MoS-tekknix
                              Btw the standard I am referring to is http://ws680.nist.gov/publication/get_pdf.cfm?pub_id=823374 and section 3.3.4 describes comments. We have increasing interest in using Duets to control CNC machines, so I am striving for a greater compatibility with CNC gcode, without having to use a separate build of the firmware.
                                MoS-tekknix
                                Confirmed the Error is gone for config-override.g
                                Thanks, waiting for Final of it πŸ˜‰ But, i hope that we see always an ongoing release of Firmware(s) πŸ˜‰
                                  MoS-tekknix
                                  Mhh, tried to do a simulation via WebIf and it stucks at 0.5%, also it is not possible to cancel the print. Need to press Emergency-Stop
                                  • AS-3D Druckundefined
                                    AS-3D Druck
                                    Nice a new Version. πŸ™‚
                                    Can i simply upload the latest Version from:
                                    Firmware Version: 1.19.2 (2017-09-01)
                                    WiFi Server Version: 1.19.2
                                    My CoreXY Printer
                                    Best regards
                                    AS-3D Druck / Andre
                                      @MoS-tekknix:
                                      I confirm there is a bug in simulation mode, in 1.20b2 and b3.
                                        @AS-3D:
                                        My CoreXY Printer
                                        Latest stable firmware is always at https://github.com/dc42/RepRapFirmware/releases. Read the upgrade notes first, especially the ones for upgrading from 1.18 to 1.19.
                                          MoS-tekknix
                                          @dc42:
                                          @MoS-tekknix:
                                          Thanks David.
                                            AS-3D Druck
                                            @AS-3D:
                                            My CoreXY Printer
                                            My fault, i wanna know if i can use the latest Beta Version from my current Version or do i have to use Beta 1 and after that Beta 2?
                                            Best regards
                                            AS-3D Druck / Andre
