    Layer tracking with variable layer heights
    Duet Web Control
    780
    • Norderundefined
      Norder @Norder
      I simulated the GCode on my printer and the following values came out.
      The layer heights are only correct from layer 29, before that they deviate extremely from 0.1mm.
      Google Translate
      --- Original Text ---
      Ich habe den GCode mal auf meinem Drucker simuliert und dabei sind folgende Werte heraus gekommen.
      Erst ab Layer 29 sind die Schichthöhen korrekt, vorher weichen sie doch schon extrem von der 0,1mm ab.
      DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
      Thingiverse
        Phaedrux Moderator @tmreith
        @tmreith said in Layer tracking with variable layer heights:
        However DWC seems to be calculating layers from a perceived Z height and layer heights.
        Yes this may be the case.
        What version of firmware and DWC are you running?
        tmreithundefined 1 Reply Last reply Reply Quote 0
        • tmreithundefined
          tmreith @Phaedrux
          @phaedrux
          Board: Duet 3 MB6HC (MB6HC)
          DSF Version: 3.3.0
          Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
          Duet Web Control 3.3.0
          I thought there was a keyword like "layer count" or "num_layers" that was being read in past before DWC would try to calculate based on a layer_height value and the max Z value.
          The mixed layer heights are definitely messing with the layer calculation.
          I have full control over the gcode, so I can add in the required commented value to drive the DWC.
            Can you update to 3.4.1?
            • tmreithundefined
              tmreith @Phaedrux
              @phaedrux
              unfortunately not. The machines are validated to 3.3 and would require a re-validation effort if I updated the firmware.
              Is there a layer count keyword that is still being used in the g-code? I can insert what ever DWC needs to establish a value vs trying to calculate from a Z height and the layer height value.
                See if you can add num_layers=## to the end of the file.
                https://forum.duet3d.com/topic/27471/num_layers-in-g-code/4?_=1662052426372
                • tmreithundefined
                  tmreith @Phaedrux
                  @phaedrux
                  I added the following to the end of the gcode file, and there was no effect.
                  ; num_layers=64
                  I looked at the source code for FileInfoParser.cpp and it definitely has a routine to parse "num_layers" keyword. I am not sure why the DWC doesn't seem to see the value.
                  I have another machine running 3.4.1, so I'll give it a try on that machine over the weekend.
                  • tmreithundefined
                    tmreith @tmreith
                    @tmreith
                    Works on a Duet 2 Wifi running 3.4.1.
                    Added the following to the last line in gcode file.
                    ; num_layers: 64
                      Maybe a limitation or bug in the DuetPi version?
                      @chrishamm
                      • chrishammundefined
                        chrishamm administrators @tmreith
                        @tmreith @Phaedrux Parsing the number of layers (aka num_layers) isn't supported in DSF or RRF v3.3. In order to use this feature you must be on v3.4 or newer.
                        PS: Until v3.4 RRF/DSF attempt to compute the number of layers from the object height (last absolute G0/G1 Z command in the print file) and the layer height. If you have an extra G1 Z lift command in there, the reported object height and the number of layers are probably wrong.
                        Duet software engineer
                          Phaedrux Moderator @chrishamm
                          @chrishamm said in Layer tracking with variable layer heights:
                          His end code Z lift has ; E on the line.
                            chrishamm administrators @Phaedrux
                            @phaedrux It is correctly processed by DSF 3.4.1, I just checked (object height = 11.05mm). The number of layers was not present in the original file but once added that is parsed correctly, too.
