    Euclid facility
    91
    4.7k
      A Former User
      hello friends I installed the Euclid probe but I really need help to configure it thank you in advance
        A Former User @A Former User
        my config
        M558 K0 P5 C"^zprobe.in" H8 F300 T9000 A3 S0.01
        ; K0 for probe 0, P5 for NC switch, C for input pin,
        ; ^ for enabling the native pullup resistor on Duet 2
        ; hardware running RRF3
        ; H dive height of 8mm, F300 probing speed 6mm/sec,
        ; T9000 travel speed 150mm/sec,
        ; A3 number of probes 1, S0.01 max tolerance of 0.01
        ;G31 P50 X-1 Y-20 Z1.444 ; Set Z probe trigger value, offset and trigger height
        G31 K0 P500 X-27.955 Y-18.716 Z1.033 ; CHECK for LOOSE things first! set Z probe trigger
        ; value, offset and trigger height. Higher numbers
        ; makes nozzle closer to bed
        ; switch plunger is 16.4mm to the LEFT and 29.27mm in
        ; FRONT of the nozzle. Switch triggers 0.9mm BELOW nozzle
        ; https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Secti
        M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
        A Former User? Nurgelrotundefined 2 Replies Last reply Reply Quote 0
            when I raise the bed it touches the probe but does not stop even though the probe is on and plugged in I do not understand and the command m401 and m402 nothing happens
              Phaedrux Moderator @A Former User
              Did this probe come with instruction?
                A Former User @Phaedrux
                @phaedrux hello non
                R4ffersundefined 1 Reply Last reply Reply Quote 0
                • R4ffersundefined
                  R4ffers @A Former User
                  @sgk instructions are here https://euclidprobe.github.io/
                  Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                  A Former User? 2 Replies Last reply Reply Quote 0
                    A Former User @R4ffers
                    @r4ffers Hello OK thank you I'll go look at the documentation 👍
                      @r4ffers I don't understand I have to do a retract and deploy file I can't understand and in addition it doesn't give how to put the m558 line on their site it's for a duet 2 and I have a duet 3.
                      • R4ffersundefined
                        @sgk Hi, this is my M558 line.
                        M558 K0 P8 C"^121.io2.in" T18000 F600:180 H5 A10 S0.03
                        You'll also need a G31 line.
                        Please make sure to check Duet docs, don't just add stuff to your config as all machines are different.
                          @r4ffers I understand but it's hard for me I'm a novice so there are a lot of things that I have trouble understanding. Thanks for line 558.
                          • R4ffersundefined
                            @sgk have a look in duet docs at M558 and G31 so you know what each element does. Also look at the Euclid link I posted earlier which will take you through the commissioning side of it. Pretty sure there's macro examples for deploy and retract posted there too.
                              @r4ffers Yes thank you indeed I have already configured everything on config bed home z but when I launch home The bed does not go up and the probe does not stop the bed going up.
                                bed
                                G91 ; relative positioning
                                G90 ; absolute positioning
                                G28 ; home all
                                G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis
                                G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                                G29 S0 ; probe the bed and enable compensation
                                M291 P"Leveling finished !" R"Probing.." S1 T2
                                ; Euclid Probe Independant Screw Leveling Macro
                                ; RRF3.X Firmware Example
                                ; saveas system/bed4point.g
                                ; could save it as conventional bed.g but for illustration purposes
                                ; the name is purposefully altered
                                ; comments and echo statements throughout are provided for convenience
                                ; probe is -16.4 in X -29.4 in Y bed is 290 in X 325 in Y
                                ; locations of probe points are at
                                ; (18, 285) (270,285)
                                ; (18,65) (270,65)
                                ; adjust coords so that probe hits symmetric points on the bed and avoids dock
                                ; echo "Running bed4point.g"
                                M558 F60 A3 ; fix probe speed to 1mm/s
                                G90
                                G4 P250
                                G30 P0 X18.0 Y65.0 F9000.0 Z-99999 ; probe front left PEI
                                G30 P1 X18.0 Y285.0 F9000.0 Z-99999 ; probe back left PEI
                                G30 P2 X270.0 Y285.0 F9000.0 Z-99999 ; probe back right PEI
                                G30 P3 X270.0 Y65.0 F9000.0 Z-99999 S3 ; probe near front right leadscrew and calibrate 3 motors PEI
                                ; echo "bed4point.g complete"
                                  config
                                  M208 X-3.50 Y0 Z0 S1 ; Set axis minima
                                  M208 X330 Y320 Z350 S0 ; Set axis maxima
                                                               ; ================ Endstops =======================
                                  M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                                  M574 Y2 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
        ; ================ Z-Probe ========================
                                  ;M558 P8 C"io2.in" A5 H5 F120 T15000 ; set Z probe type to unmodulated and the dive height + speeds (for Mini IR sensor M558 P8 C"io2.in" A2 H5 F120 T15000)
                                  M558 K0 P5 C"io8.in" H8 F300 T9000 A3 S0.01
                                  M557 X20:270 Y20:270 P3 ; Define mesh grid
                                    deploy
                                    ; Euclid Probe Fixed Dock M401 Deploy Probe Macro
                                    ; saveas system/deployprobe.g
                                    ; __________________________________________________________________________
                                    ; | * Probe Ready Position |
                                    ; | X150 Y150 |
                                    ; | * Dock staging position |
                                    ; | X0 Y70 |
                                    ; | * Dock Exit Position |
                                    ; | X0 Y40 |
                                    ; | X0 Y0 X30 Y0 X100 Y0 |
                                    ; | * Dock * Dock Side * Dock Preflight |
                                    ; |________________________________________________________________________|
                                    ; Above is example 300x300 bed to coorelate with macros and movements below.
                                    ; This example is for a fixed dock, fixed gantry/carraige and moving bed motion system.
                                    ; RailCore, Ender5, V-Core3, etc...
                                    ; coordinates are re-written below above the macros
                                    echo "Running deployprobe.g"
                                    if !move.axes[0].homed || !move.axes[1].homed ; If the printer hasn't been homed, home it
                                    M98 P"0:/sys/homexy.g"
                                    ; uncomment next line to echo the probe deploy state
                                    ; echo "Object Model Deployuser token =" ^sensors.probes[0].deployedByUser
                                    M564 H1 S0 ; Allow movement BEYOND axes boundaries (for Y to reach probe dock)
                                    echo "Lift Z in advance of deploy"
                                    G0 H2 Z15 F3000 ; move Z 15 for clearance above dock.
                                    ; ; need to figure out some safety check on this
                                    ; uncomment next line to echo the probe value
                                    ; echo "Probe Value =" ^sensors.probes[0].value[0]
                                    if sensors.probes[0].value[0]!=1000 ; if sensor is value other than 1000 do this
                                    ; echo "deployuser token = " ^sensors.probes[0].deployedByUser
                                    ; echo "Probe State = " ^sensors.probes[0].value[0]
                                    abort "deployprobe start value Probe already picked up. Manually return probe to the dock"
                                    ; if we're here we know it's becasue the above is true which I assume is because you have an NC switch as a probe.
                                    ; echo "Passed first logic test to deploy probe"
                                    ;Preflight position is X100 Y8.5
                                    ;Dock Side position is at X30 Y8.5
                                    ;Docked probe postion is at X0 Y8.5
                                    ;Dock exit point is at X0 Y40
                                    ;Dock Re-Entry Staging Position is at X0 Y70
                                    ;Probe Ready Position X150 Y150
                                    ; echo "Probe Pickup macro running"
                                    G0 X100 Y8.5 F6000 ; move to Preflight Position
                                    M400 ; wait for moves to finish
                                    G0 X30 Y8.5 F6000 ; move to Dock Side dock location
                                    ; uncomment next line to echo the probe deplot state
                                    ; echo "Object Model Deployuser token (before while loop) = " ^sensors.probes[0].deployedByUser
                                    G0 X0 Y8.5 F3000 ; move over Dock
                                    G4 P500 ; pause 0.5 seconds
                                    G0 X0 Y40 F300 ; slide probe out of dock - slowly
                                    G0 X170 Y170 F3000 ; move to re-entry position
                                    echo "Probe Pickup complete"
                                    ; uncomment to echo the probe deploy state
                                    ; echo "Object Model Deployuser token (after while loop) = " ^sensors.probes[0].deployedByUser
                                    G0 X170 Y170 G3000 ; move to the center of the bed
                                    if sensors.probes[0].value[0]!=0
                                    echo "Object Model Deployuser token (in abort if section)= " ^sensors.probes[0].deployedByUser
                                    abort "Deployprobe endvalue not 0 Probe not picked up! Deployt cancelled."
                                    M564 H1 S1 ; Restrict movement to within axes boundaries (for normal Y movement)
                                    echo "Macro deployprobe.g complete"
                                      retract
                                      ; Euclid Probe Fixed Dock Retract Probe Macro M402
                                      ; RRF3.x Firmware Example
                                      ; saveas system/retractprobe.g
                                      ; | X150 Y150 |
                                      ; | * Dock Re-entry staging position |
                                      ; | X0 Y70 |
                                      ; | X0 Y40 |
                                      echo "running retractprobe.g macro"
                                      ; Preflight position is X100 Y0
                                      ; Dock Side position is at X30 Y0
                                      ; Docked probe postion is at X0 Y0
                                      ; Dock exit point is at X65 Y0
                                      ; Dock Re-Entry Staging Position is at X0 Y70
                                      ; Probe Ready Position X150 Y150
                                      M564 S0 ; allow beyond limit axis to print area
                                      if sensors.probes[0].value[0]!= 0
                                      abort "retractprobe: Probe not currently picked up!"
                                      ; echo "pass first logic loop"
                                      ; uncomment next line to echo the probe value and probe deploy state
                                      G0 X0 Y70 F3000 ; move to ready position
                                      G0 X0 Y30 F3000 ; move to the entry position for the dock
                                      G0 X0 Y8.5 F300 ; move into the dock position
                                      G4 P250 ; pause 250 usecs
                                      G0 X30 Y8.5 F6000 ; move to the side adjacent to the dock swiping the probe off
                                      G0 X100 Y8.5 F3000 ; move to the side adjacent to the dock swiping the probe off
                                      G0 X170.0 Y170.0 F6000 ; move to the center of the bed
                                      M564 S1 ; limit axis to print area
                                      ; echo "complete movement commands"
                                      if sensors.probes[0].value[0]!= 1000
                                      abort "retractprobe.g Probe not correctly dropped off in dock!"
                                      echo "Macro retractprobe.g complete"
                                      xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        homez
                                        G1 H2 Z5 F6000 S2 ; lift Z relative to current position
                                        G1 X152 Y166.4 F6000 ; go to first probe point
                                        ;G91 ; relative positioning
                                        ;G90 ; absolute positioning
                                        ; Euclid Probe homez.g Example Macro
                                        ; saveas system/homez.g
                                        M290 S0 R0 ; clear baby steps
                                        G1 H2 Z6 F6000 ; lift Z relative to current position to clear any obstructions
                                        M400
                                        ; echo "Call deployprobe.g macro"
                                        M401 P0 ; This runs macro file deployprobe
                                        ; echo "Return"
                                        G1 X145 Y162.5 F9000 ; go to center of bed in advance of probe that point
                                        M400
                                        ; echo "G30 Command"
                                        G30 ; Probe the bed at the current XY position. When the probe is triggered,
                                        ; adjust the Z offset of the current tool to make the current position Z=0.
                                        G1 Z10 ; raise Z=10
                                        M400
                                        G4 P500
                                        ; echo "Call bed4point.g macro"
                                        M98 P"0:/sys/bed4point.g" ; tram bed
                                        ; echo "Return"
                                        G1 X145 Y162.5 F9000 ; go back to the first probe point and reprobe 0 in case it moved
                                        G30
                                        ; echo "Call retractprobe.g macro"
                                        M402 P0 ; retract probe
                                        ; echo "Return"
                                        G1 Z10 F600 ; lift Z relative to current position
                                        M564 S1 H0 ; reset the bounding limits
                                        ; G1 X150 Y0 F9000 ; move carraige to center front
                                          homeall
                                          G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-355 ; home X axis
                                          G1 H1 Y355 ; home Y axis
                                          G1 X5 Y-5 F6000 ; go back a few mm
                                          G1 H1 X-355 F400 ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Y355 ; then move slowly to Y axis endstop
                                          G1 X170 Y180 F6000 ; go to first probe point X11.5 Y65.8 Z0 The coordinate put the Z sensor in the center of the bed.
                                          G30 ; Probe
