    Euclid facility
    91
    4.9k
      A Former User @A Former User
      homez
      G91 ; relative positioning
      G1 H2 Z5 F6000 S2 ; lift Z relative to current position
      G90 ; absolute positioning
      G1 X152 Y166.4 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G90 ; absolute positioning
      ; Euclid Probe homez.g Example Macro
      ; RRF3.X Firmware Example
      ; saveas system/homez.g
      ; comments and echo statements throughout are provided for convenience
      if !move.axes[0].homed || !move.axes[1].homed ; If the printer hasn't been homed, home it
      M98 P"0:/sys/homexy.g"
      M290 S0 R0 ; clear baby steps
      G1 H2 Z6 F6000 ; lift Z relative to current position to clear any obstructions
      M400
      ; echo "Call deployprobe.g macro"
      M401 P0 ; This runs macro file deployprobe
      ; echo "Return"
      G1 X145 Y162.5 F9000 ; go to center of bed in advance of probe that point
      M400
      ; echo "G30 Command"
      G30 ; Probe the bed at the current XY position. When the probe is triggered,
      ; adjust the Z offset of the current tool to make the current position Z=0.
      G1 Z10 ; raise Z=10
      M400
      G4 P500
      ; echo "Call bed4point.g macro"
      M98 P"0:/sys/bed4point.g" ; tram bed
      ; echo "Return"
      G1 X145 Y162.5 F9000 ; go back to the first probe point and reprobe 0 in case it moved
      G30
      ; echo "Call retractprobe.g macro"
      M402 P0 ; retract probe
      ; echo "Return"
      G1 Z10 F600 ; lift Z relative to current position
      M564 S1 H0 ; reset the bounding limits
      ; G1 X150 Y0 F9000 ; move carraige to center front
        homeall
        G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X-355 ; home X axis
        G1 H1 Y355 ; home Y axis
        G1 X5 Y-5 F6000 ; go back a few mm
        G1 H1 X-355 F400 ; move slowly to X axis endstop once more (second pass)
        G1 H1 Y355 ; then move slowly to Y axis endstop
        G1 X170 Y180 F6000 ; go to first probe point X11.5 Y65.8 Z0 The coordinate put the Z sensor in the center of the bed.
        G30 ; Probe
          • PaulHewundefined
            PaulHew
            Firstly I would make sure the probe works correctly.
            Get the EndStops Monitor plugin from Here
            Click the 'Plugins' button on left toolbar
            Then click
            Select the file you just downloaded, and install it.
            When it is installed, you need to enable it by clicking the green 'Start' button
            Press 'F5' on your keyboard to refresh the printers webpage.
            go here
            Click the 'Endstops' tab and it will display the status of your endstops
            With the Euclid NOT connected it should say 'Yes' under triggered
            With the Euclid connected and the switch NOT activated your screen should look like this.
            Also note the 'Z-Probe' field in the 'Status' box at the top of the screen
            When the Euclid is connected and the switch is NOT depressed it should read 0
            When Euclid not connected it should read 1000 and be high lighted in RED
            If this is not the case, add a '^' to this line, like mine.
            M558 K0 P8 C"^io0.in" H8 F300 60 T9000 A3 S0.01
            Let us know how you get on.
            Regards,
            Paul.
              A Former User @PaulHew
              @paulhew
              no it did not work when the bed goes up and it coughs the probe sensor the bed does not stopCapture d’écran 2022-09-10 094421.jpg
                  it works it detects the probe I changed this line
                  C"^io8.in"
                  C"^io2.in"
                  A Former User? PaulHewundefined 2 Replies Last reply Reply Quote 0
                    but i get this error when i do home
                    10/09/2022 10:07:04 G28
                    Error: Probe already triggered at start of probing move
                    • PaulHewundefined
                      PaulHew @A Former User
                      @sgk why are you using 2 io's?
                      Please post your config.g, not just bits of it.
                      Also a picture like below, WITHOUT the Euclid connected.
                      P.
                        @paulhew
                        ; ================ Drives mapping =================
                        M569 P1 S0 ; physical drive 0.1 goes forwards - X driver
                        M569 P2 S0 ; physical drive 0.2 goes forwards - Y driver
                        M569 P3 S1 ; physical drive 0.3 goes forwards - Z1 Right driver
                        M569 P4 S0 ; physical drive 0.4 goes forwards - Z2 Left driver
                        M569 P0 S1 ; physical drive 0.0 goes forwards - extruder driver
                        M584 X1 Y2 Z4:3 E0 ; set drive mapping
                                                           ; ================ Drives settings ================
                        M92 X200.00 Y200.00 Z800.00 E693.55 ; set steps per mm - for Matrix extruder:E324.214
                        M566 X500 Y500 Z800 E600 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
                        M203 X20000 Y20000 Z600 E3600 ; Set maximum speeds (mm/min)
                        M201 X1000 Y1000 Z100 E600 ; Set accelerations (mm/s^2)
                        M906 X1350 Y1350 Z1200 E700 I10 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S60 ; Set idle timeout
                                                     ; ================ Independent Z leveling (original 2 z-axis) =================
                        M671 X-45.0:364.0 Y165.0:165.0 S5.0 ;bed compensation
                                                        ; ================ Axis Limits ====================
                        M208 X-3.50 Y0 Z0 S1 ; Set axis minima
                        M208 X330 Y320 Z350 S0 ; Set axis maxima
                                                     ; ================ Endstops =======================
                        M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                        M574 Y2 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                                                       ; ================ Z-Probe ========================
                        ;M558 P8 C"io2.in" A5 H5 F120 T15000 ; set Z probe type to unmodulated and the dive height + speeds (for Mini IR sensor M558 P8 C"io2.in" A2 H5 F120 T15000)
                        ;M558 K0 P5 C"io8.in" H8 F300 60 T9000 A3 S0.01
                        M558 K0 P5 C"^io2.in" H8 F300 60 T9000 A3 S0.01 ;
                        ;M558 K0 P5 C"^io2.in" H8 F300 T9000 A3 S0.01 ; K0 for probe 0, P5 for NC switch, C for input pin,
                        ;G31 P50 X-1 Y-20 Z1.444 ; Set Z probe trigger value, offset and trigger height
                        G31 K0 P500 X-27.955 Y-18.716 Z1.033 ; CHECK for LOOSE things first! set Z probe trigger
                        M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                        M557 X20:270 Y20:270 P3 ; Define mesh grid
                                                          ; ================ Heaters ==============================================
                        M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                        M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 (if NOT using SSR - delete Q10)
                        M307 H0 R0.312 K0.313:0.000 D13.50 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                        M143 H0 S100 ; set temperature limit for heater 0 to 100C
                        M308 S1 P"temp1" Y"thermistor" A"Hotend" T107537 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                        M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1
                        M307 H1 R2.451 K0.445:0.102 D5.36 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit
                                                   ; ================ Fans & Lights ==================
                        M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                        M106 P0 S0 H1 T35 ; set fan 0 value. Thermostatic control is turned on
                        M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                        M106 P1 S0 H-1 C"Layers Fan" ; set fan 1 value. Thermostatic control is turned off
                        M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency (lights)
                        M106 P2 S0.2 H-1 C"Lights" ; set fan 2 value. Thermostatic control is turned off (lights)
                                                          ; ================ Tools ==========================
                        M563 P0 D0 H1 F1 ; define tool 0
                                                    ; ===================== Custom settings ====================
                        M572 D0 S0.05 ;pressure advance Set bowden extruder elasticity compensation for E0
                        M207 S1.5 F3600 Z0.01 ; Set firmware retraction parameters
                        M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
                        ; ================ Miscellaneous ==================
                        ;M575 P1 S1 B57600 ; enable support for PanelDue
                        Capture d’écran 2022-09-10 104241.jpg 3c42b59b-6af7-4984-a76e-bb71bb06e20f.jpg
                        • PaulHewundefined
                          PaulHew
                          when you MANUALLY connect the probe to its dock, does Z-Probe in the dashboard change from a Red 1000 to 0?
                            @paulhew YES
                              now it works but when I launch home I have this error and the probe does not feel the bed I would like to make a video but in this forum I cannot put a video
                              A Former User? Norderundefined 2 Replies Last reply Reply Quote 0
                                @sgk 10/09/2022 10:50:49 Upload of bed.g successful after 0s
                                10/09/2022 10:50:07 G28
                                10/09/2022 10:49:44 Upload of bed.g successful after 0s
                                  example when I do g32 the probe does not feel the bed
                                  • Norderundefined
                                    Norder @A Former User
                                    @sgk said in Euclid facility:
                                    ...I would like to make a video but in this forum I cannot put a video
                                    Upload video to YouTube and post the link here.
                                    DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
                                    Thingiverse
                                      A Former User @Norder
                                      @norder yes ok
                                        https://youtu.be/8k9bdBqXdbc
                                        • PaulHewundefined
                                          PaulHew
                                          So it homes Z OK.
                                          Just the 4 point mesh is the issue?
                                          • PaulHewundefined
                                            PaulHew
                                            homeall.g deployprobe.g bed4point.g retractprobe.g homez(1).g
                                            These are all my WORKING homing files.
                                            And my config.g
                                            config.g
                                            After running the Z homing, instead of running G32, type the commands from your homez.g or mine.
                                            G32 iirc runs bed.g, i do not have a bed.g 😉
                                            rename bed.g to oldbed.g
                                            When I run g32, it says bed.g not found, so remove, move or rename it.
                                            homez does everything, i think.
                                            You are nearly there.
                                            A Former User? 2 Replies Last reply Reply Quote 1
