    Tool change issues after firmware update 1.19.2
    7.0k
    • MrTundefined
      MrT
      Dear ,
      yes I am sure that it is not a reporting error from the web interface cause when I try to park t1 back the tool it's crashing with tool0 trying to park back tool0 with isn't loaded tool1 is
      Thanks
      Best regard
      Manuel
      • MrTundefined
        MrT
        dear DC42
        Hope you had a successful trade show saw some videos on YouTube 🙂 next year I will try to come , if time permits
        I was overseas for some time, just came back .
        So nothing changed to my situation , so I am coming back to you 🙂
        Best Regards
        Manuel Topiol
          Thanks for the reminder.
          Please try firmware 1.20beta2. It probably won't change anything, but I need to know that the fault is still present.
          Pending your report, I have this on my list to look at tomorrow.
          • MrTundefined
            MrT
            Good evening
            Thanks for the quick responds
            I will update the firmware to 1.20beta 2 1st thing in the morning and revert with result
            Best Regards
            Manuel
            • MrTundefined
              MrT
              Dear I have done the update of the firmware per your request
              Situation is the same with a slight difference
              now when I select tool 0 from a fresh machine boot , it doesn't complete the full tool change, the gcode file is not fully processed,
              as opposed to before I could just type T0 and it will collect the tool without problem .
              after I put the T0 back in standby and do an other T0 I will get it correctly ,
              then I do a T1 command and it will fetch tool1 but after the selection is complete T0 is set to active.
              , I feel strange, for sure I am not the only guy owning a duet wifi with a tool change, but no one else is complaining about this problem
              Best Regards
              Manuel Topiol
              • MrTundefined
                MrT
                for info
                Firmware Name: RepRapFirmware for Duet WiFi
                Firmware Electronics: Duet WiFi 1.0
                Firmware Version: 1.20beta4 (2017-10-28)
                WiFi Server Version: 1.20beta2
                Web Interface Version: 1.19.3
                best regards
                • MrTundefined
                  MrT
                  Dear DC42
                  There is some improvement and possibly resolved !!!!
                  I just updated the firmware as per previous msg
                  tried again the tool change, the problem of the 1st boot and T0 command disappeared, then I did a T1 command and I got an error MSG Error: Bad command: Lift Z relatively to current position
                  I removed the Z lift command and now when I change tools the correct tool is active 🙂
                  some thing strange is that the z lift is the same in pre0 then in pre1 but the error is only appearing in T1
                  Best Regards
                  Manuel Topiol
                    I'm glad the main issue is resolved. I think you have the text "Lift Z relatively to current position" in your tpre1.g file, without the semicolon at the start to indicate that it is a comment.
                    • MrTundefined
                      MrT
                      I will check right away
                      • MrTundefined
                        MrT
                        🙂 you are right
                        the ; was missing , but it has always been missing cause I did not edit the file 🙂
                        the error msg is gone but the stop in the middle of the tool change remains on T1
                        T0 is being parked and collected correctly
                        but when it goes back to collect tool1 seems that to stops before finished and immediately wait for the tool to get to temp then continue printing but the tool1 is not loaded
                        Thanks
                        Best Regards
                        Manuel Topiol
                          OK, it's back on my list to look at.
                          • MrTundefined
                            MrT
                            Dear DC42
                            just to see what happens I have let the printer continue to print
                            the behavior is as follow
                            start printing
                            T0 is loaded waiting till it reaches temp , start 1 layer
                            T0 is parked Tfree fully executed
                            T1 is in the process of being loaded the gcode executes to the 5th line of the tpre, and stops there
                            then remains there till the nozzle reaches the temperature ,
                            once the temperature is reached it continues to print , without the tool being loaded , but the tool is active like it should .
                            once the layer without loaded tool is completed it executes Tfree1 successfully
                            Then execute tpre0 successfully and tool0 is correctly loaded wait for temp to be reached and start printing.
                            hope it will help u to find the glitch
                            Best Regards
                            Manuel Topiol
                            I have put back the 1.18 firmware and the switching is back to normal no stopping at T1 command
                            • foehnsturmundefined
                              foehnsturm
                              This is probably not closely related but I'm running 1.19.2 (2017-09-01) and noticed that the final line of my tfree macros is not reliably executed (when using the select tool command in the WebUI). It sometimes finishes the macro without performing the last move but will perfectly execute any following command (which ofc could cause a crash into the dock). I ended up with duplicating the final line to safeguard its execution.
                              Magnetic tool changer on a corexy.
                              [[language]]
                              ; tfree0.g
                              ; called when tool 0 is freed
                              M83
                              G0 E-5 F1200
                              M82
                              G0 X252 Y215 F16000
                              G91
                              G0 Y47
                              G0 X30 F4000
                              G0 X4 F2000
                              G90
                              G0 Y215 F6000
                              G0 Y215 F6000
                              • MrTundefined
                                MrT
                                Dear foehnsturm
                                I am also using a magnetic tool change , with the 1.18 firmware I can confirm that all is working well ,
                                I never managed to get 1.19 working ,since I always had the wrong tool active. did you experience something similar ?
                                The issue with wrong tool being active got solved with the latest 1.2 beta4 but I am still facing some issues with the tpre file as it is not fully executed.
                                Best Regards
                                MT
                                • MrTundefined
                                  MrT
                                  Dear DC42 & foehnsturm
                                  Seems foehnsturm is correct !!
                                  I have tried to add the last line of tpre1 2 times and it seems to work 🙂
                                  If I may ask what slicer are you guys using ?
                                  thanks to both of you
                                  Best Regards
                                  MT
                                    foehnsturm
                                    Great that I could help.
                                    @dc42, could there be an issue with always completely executing the macro?
                                    @topiolm@hotmail.com, no yet using a slicer 😉 Just finished the park and pickup sequences.
                                    • MrTundefined
                                      MrT
                                      foehnsturm
                                      do you use something similar to mark2 for your tool change ?
                                      Best Regards
                                      MT
                                        foehnsturm
                                        A little more complicated: multiple toolheads but only one stepper.
                                        • MrTundefined
                                          MrT
                                          I have tried some similar approach some time ago without much success I was clogging my nozzle 2 often with the retract , then I just dropped it. since I have limited time for my hobbies 😞
                                          If you don't mind could you post some picture just for my curiosity 🙂
                                          Best Regards
                                          MT
                                          Ps if you intrested something I have tested with great success ,the use of compressed air for cooling the part during printing , for small part worked miracles only problem was the amount of air used and the noise, my neighbor became crazy , the compressor was working to much and for to long :-). so reverted to the traditional fan,
                                          the advantaged was less weight on the head and vibration was reduced ,not that there is a lot of vibration , but any improvement is an improvement how ever small 🙂
                                          • MrTundefined
                                            MrT
                                            Dear DC42
                                            I found an other issue , if I cancel a print the tool change macro are not being executed
                                            to better explain , if I cancel a print and a tool is still loaded , I and I click on the tool to put it back in standby and go back to its parking place , I get no responds
                                            Best regards
                                            MT
