Tool change issues after firmware update 1.19.2
7.0k
    MrT
    Dear Sorry was on my mobile did not see David's Post
    please find her under the config file
    M111 S0
    G21
    G90
    M83
    M555 P2
    M208 X0 Y0 Z-1 S1
    M208 X200 Y200 Z306 S0
    M574 X1 Z2 S0
    M574 Y1 S0
    M558 P1 X0 Y0 Z1 H3 F200 T6000
    G31 P500 X0 Y0 Z0.3
    M557 X10:140 Y10:140 S20
    M569 P0 S0
    M569 P1 S0
    M569 P2 S1
    M569 P3 S1
    M569 P4 S1
    M350 X16 Y16 E16:16 I1
    M350 Z16 I0
    M92 X160 Y160 Z400 E837:837
    M566 X400 Y400 Z15 E100:100
    M203 X10000 Y10000 Z2400 E1500:1500
    M201 X1200 Y1200 Z200 E3000:3000
    M906 X1400 Y1400 Z1300 E1400:1400
    M84 S0
    M143 H0 S110
    M143 H1 S335
    M143 H2 S265
    M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30
    M305 P2 T100000 B4138 C0 R4700 X201
    M305 P1 T100000 B4138 C0 R4700 X200
    M305 P0 T100000 B4725 C7.060000e-8 R3750 X1
    M563 P0 D0 H1
    G10 P0 X-19.92 Y-0.20 Z0.0
    G10 P0 R0 S0
    M563 P1 D1 H2
    G10 P1 X19.8 Y0 Z-0.09
    G10 P1 R0 S0
    M550 PMy printer
    M552 S1 ;
    M587########################
    M586 P0 S1
    M586 P1 S0
    M586 P2 S0
    M106 P2 S0.3 I0 F12 H-1
    M106 P1 S1 I0 F100 H-1
    M106 P0 S1 I0 F10 H-1
    tfree0:
    G90
    M83
    G91
    G1 Z5 F6000
    G90
    G1 X-15 F6000
    G1 Y180 F6000
    G1 X30 F6000
    G1 X70 F6000
    tfree1
    G90
    M83
    G91
    G1 Z5 F6000
    G90
    G1 X195 Y50 F6000
    G1 Y180 F6000
    G1 X50 F6000
    G1 Y50 F6000
    tpre0
    G90
    M83
    G0 X50 F6000
    G1 Y180 F6000
    G1 X5 F6000
    G1 Y50 F6000
    tpre1
    G90
    M83
    G0 X50 F6000
    G1 Y180 F6000
    G1 X175 F6000
    G1 Y50 F6000
    thanks
    Manuel Topiol
      MrT
      Friendly bump
      Best regards
      Manuel
        MrT
        Dear dc42 & t3p3tony
        Did u have any chance to check on my issue , I am still Struggling with it , I can confirme that the issue is not related with the tfree tpre and tpost , if I disabled them and do the tool change movements via the slicer I get the same result the wrong tool is active when I switch to tool1
        In the hope of hearing from you
        Best regards
        Manuel Topiol
          MrT
          Gentle bump bump
          Regards
          Manuel
            We're going to be busy with the TCT show for the next week, so feel free to remind us after that.
            Also please check whether this is a Duet Web Control bug, or whether the same bug occurs if you send the appropriate T commands directly. One of my machines exhibits an inability to select or deselect a tool using the Tool link in DWC 1.19, but it works fine if I send the appropriate T commands from the GCode Console.
              MrT
              Dear thanks for your reply
              with the t command I get the same result I have been trying every possible combinations with no success, I am supprized that no more people are experiencing the same problems , or maybe less people are using a tool change
              Ok i will recontacter you after your show , hope it goes well , good luck !!!
              Best regards
              Manuel Topiol
                number40fan
                There were directions to roll back to 1.18 if you wanted to do that, just to confirm it is an update issue.
                  MrT
                  Good day
                  Yes I did roll back the issue was gone , then I did the update again the issue was back , since then I am doing try and error to pin point where the issue is comming from.
                  The steps I undertook where :
                  1 ) tool change with a very basic gcode file just switchings from t0 to t1 to t0 to t1 with the tfree tpost tpre active
                  2 )deactivated the tfree tpost tpre and did the tool change from within the slicer
                  3 )tripel checked my config file and cabeling
                  Issue stays the same what ever I do .the active tool remains t0 after loading t1
                  Every test I did tend to let me think it's an update issue or some mistake on my part but it's not very likely I have my config info in a previous post maybe you could help me have a double check
                  Best regards
                  Manuel
                    Are you certain that Tool 0 stays active after you select Tool 1, and it isn't that DWC is mis-reporting it? If you send G10 P0 S0 then this should cool down tool 0 if it really is active, but do nothing if it isn't.
                    You can remove the M587 command from config.g, it only needs to run once to save your access point details on the WiFi module.
                      MrT
                      Dear ,
                      yes I am sure that it is not a reporting error from the web interface cause when I try to park t1 back the tool it's crashing with tool0 trying to park back tool0 with isn't loaded tool1 is
                      Thanks
                      Best regard
                      Manuel
                        MrT
                        dear DC42
                        Hope you had a successful trade show saw some videos on YouTube 🙂 next year I will try to come , if time permits
                        I was overseas for some time, just came back .
                        So nothing changed to my situation , so I am coming back to you 🙂
                        Best Regards
                        Manuel Topiol
                          Thanks for the reminder.
                          Please try firmware 1.20beta2. It probably won't change anything, but I need to know that the fault is still present.
                          Pending your report, I have this on my list to look at tomorrow.
                            MrT
                            Good evening
                            Thanks for the quick responds
                            I will update the firmware to 1.20beta 2 1st thing in the morning and revert with result
                            Best Regards
                            Manuel
                              MrT
                              Dear I have done the update of the firmware per your request
                              Situation is the same with a slight difference
                              now when I select tool 0 from a fresh machine boot , it doesn't complete the full tool change, the gcode file is not fully processed,
                              as opposed to before I could just type T0 and it will collect the tool without problem .
                              after I put the T0 back in standby and do an other T0 I will get it correctly ,
                              then I do a T1 command and it will fetch tool1 but after the selection is complete T0 is set to active.
                              , I feel strange, for sure I am not the only guy owning a duet wifi with a tool change, but no one else is complaining about this problem
                              Best Regards
                              Manuel Topiol
                                MrT
                                for info
                                Firmware Name: RepRapFirmware for Duet WiFi
                                Firmware Electronics: Duet WiFi 1.0
                                Firmware Version: 1.20beta4 (2017-10-28)
                                WiFi Server Version: 1.20beta2
                                Web Interface Version: 1.19.3
                                best regards
                                  MrT
                                  Dear DC42
                                  There is some improvement and possibly resolved !!!!
                                  I just updated the firmware as per previous msg
                                  tried again the tool change, the problem of the 1st boot and T0 command disappeared, then I did a T1 command and I got an error MSG Error: Bad command: Lift Z relatively to current position
                                  I removed the Z lift command and now when I change tools the correct tool is active 🙂
                                  some thing strange is that the z lift is the same in pre0 then in pre1 but the error is only appearing in T1
                                  Best Regards
                                  Manuel Topiol
                                    I'm glad the main issue is resolved. I think you have the text "Lift Z relatively to current position" in your tpre1.g file, without the semicolon at the start to indicate that it is a comment.
                                      MrT
                                      I will check right away
                                        MrT
                                        🙂 you are right
                                        the ; was missing , but it has always been missing cause I did not edit the file 🙂
                                        the error msg is gone but the stop in the middle of the tool change remains on T1
                                        T0 is being parked and collected correctly
                                        but when it goes back to collect tool1 seems that to stops before finished and immediately wait for the tool to get to temp then continue printing but the tool1 is not loaded
                                        Thanks
                                        Best Regards
                                        Manuel Topiol
                                          OK, it's back on my list to look at.
