    Unable to make External stepper driver work
    • cj19944undefined
      cj19944
      Hi i am using an duet 3 6hc with and 1xd expansion board and i am trying to connect an external stepper driver i am currently not getting any movement when i try to extrude or retract on the dashboard. im pretty sure i have my wiring right but i dont know if my config is 100 percent from what i have looked into i seems to be okay. I send the command to check if xd board is conected with m115 b122, thanks. This is extruder i am trying to connect https://docs.dyzedesign.com/pulsar.html#reprap-firmware
      code_text
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri May 06 2022 00:13:26 GMT+0100 (British Summer Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"L3D"                                  ; set printer name
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 P10.10.1.4/ S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.0 S0                                 ; physical drive 0.0 goes backwards
      M569 P0.1 S0                                 ; physical drive 0.1 goes backwards
      M569 P0.2 S0                                 ; physical drive 0.2 goes backwards
      M569 P0.3 S0                                 ; physical drive 0.3 goes backwards
      M569 P122.0 S1 R1 T3:3:3:5:0
      M584 X0.0 Y0.1 Z0.2 E0.3:122.0                  ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
      M92 X320.00 Y320.00 Z320.00 E492.45:3200.00     ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z600.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
      M906 X2800 Y2800 Z2800 E1200:2700 I60           ; set motor currents (mA) and motor idle factor in per cent
      M84 S200                                    ; Set idle timeout
      M208 X20 Y0 Z0 S1                            ; set axis minima
      M208 X1100 Y1000 Z1500 S0                    ; set axis maxima
      M574 X1 S1 P"io1.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io2.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"io4.in" H10 F240 T12000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-22 Y-10 Z3.66                        ; set Z probe trigger value, offset and trigger height
      M557 X50:1000 Y0:1000 S50                    ; define mesh grid
      M308 S0 P"temp0" Y"pt1000"                   ; configure sensor 0 as PT1000 on pin temp0
      M950 H0 C"out0" T0                           ; create nozzle heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S280
      ; bed
                                       ; set temperature limit for heater 0 to 280C
      M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"122.out0" T1                         ; create bed heater output on 1.out0 and map it to sensor 1
      M307 H1 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H1                                      ; map heated bed to heater 1
      M143 H1 S150                                 ; set temperature limit for heater 1 to 150C
      ; dyze
      M308 S2 P"spi.cs2" Y"rtd-max31865"           ; configure sensor 2 as PT100 on pin spi.cs2
      M950 H2 C"out1" T2                           ; create nozzle heater output on out1 and map it to sensor 2
      M307 H2 B0 S2                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S480                                 ; set temperature limit for heater 2 to 150C
      M308 S3 P"spi.cs1" Y"rtd-max31865"           ; configure sensor 3 as PT100 on pin spi.cs1
      M950 H3 C"out2" T3                           ; create nozzle heater output on out2 and map it to sensor 3
      M307 H3 R0.882 K0.330:0.000 D22.74 E1.35 S1.00 B0 V28.3                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S480                                ; set temperature limit for heater 3 to 150C
      M308 S4 P"spi.cs0" Y"rtd-max31865"           ; configure sensor 4 as PT100 on pin spi.cs0
      M950 H4 C"out3" T4                           ; create nozzle heater output on out3 and map it to sensor 4
      M307 H4 R0.964 K0.156:0.000 D21.85 E1.35 S1.00 B0 V28.3                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H4 S480
      M950 F0 C"out6" Q500                         ; create fan 0 on pin out6 and set its frequency
      M106 P0 C"Part fan" S1 H0 T45                            ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out5" Q500                         ; create fan 1 on pin out5 and set its frequency
      M106 P1 C"noctua" S1 H-1                     ; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"!out4" Q500                        ; create fan 2 on pin !out4 and set its frequency
      M106 P2 C"pump" S1 H0 T25                    ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"slice head" D0 F0 T0                  ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"dyze head" D1 H2:3:4 F0 T1                  ; define tool 1
      G10 P1 X0 Y0 Z0                              ; set tool 1 axis offsets
      G10 P1 R0 S0
      cj19944undefined 1 Reply Last reply Reply Quote 0
      • cj19944undefined
        cj19944 @cj19944
        @cj19944 this is the mircostepper drive ,the green light is on constantly which says it is not enabled
        https://drive.google.com/file/d/1Oqd8jz7uU2o1Le19gp45uWQ7Z-tONXLA/edit
        Here is the drive it is an r60 model.
        dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @cj19944
          @cj19944 the enable polarity varies between drivers. Try swapping the ENA+ and ENA- wires over; or alternatively, change R1 to R0 in the M569 command for that driver.
          PS - you could drive the motor in that device directly from the 6HC. The documentation says it needs 2.7A RMS and the 6HC can do up to 4.5A RMS.
            droftarts administrators @cj19944
            @cj19944 See @dc42's answer for enabling the driver.
            This is incorrect; you have five variables for the T parameter, when it only takes four. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m569-set-motor-driver-direction-enable-polarity-mode-and-step-pulse-timing
            There is no information in the driver user manual about pulse speeds, and your current ones look very fast. Once it is enabled, try something a bit slower and more standard for external drivers, eg:
            M569 P122.0 S1 R1 T5:5:10:10
            Then reduce the timings to find the limit, if needed.
            • cj19944undefined
              cj19944
              Really appreciate your help I will try these changes and see what happens.
              • cj19944undefined
                cj19944
                Hi this issue is solved now by changing r1 to r0 and adjusting the timing, thanks again for your help.
                • droftartsundefined droftarts marked this topic as a question
                • droftartsundefined droftarts has marked this topic as solved
                  dc42 administrators @droftarts
                  @droftarts the Pulsar manual gives this suggestion for the driver timings:
                  M569 PXXX SXXX R1 T3:3:5:0
                  • nachogilundefined nachogil referenced this topic
