    Duet 6HC Heat Sink Enclosure
    My Duet controlled machine
    1.1k
      deckingman @Michael Hathaway
      @michael-hathaway Ah OK. I get it now. I'd be interested to see some thermal tests with and without the heat sink if pos.
      Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
      • Michael Hathawayundefined
        Michael Hathaway @deckingman
        @deckingman Yes, when I finish the project.
        I have attached fans front, back, side. Even my good Noctua fans die and then I have to fix it. I just wanted to come up with an enclosure where I didn't have to use a fan anymore. I love printing, hate maintenance lol...
        Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
        www.MatterHackers.com - https://discord.gg/Ked7GREqux
          droftarts administrators @Michael Hathaway
          @michael-hathaway said in Duet 6HC Heat Sink Enclosure:
          The heat sink attaches to the bottom of the 6HC.
          Ahhhh.... that explains it! I didn't get that from the way the parts were orientated in the render. And I remember you had a heatsink stuck on the top of MCU on the Mini 5+ board you were having problems with.
          Will be interesting to see the results of thermal tests.
            Michael Hathaway @droftarts
            @droftarts I personally have never added a heat sink to the MCU. I think it might be worth testing. shrug I read somewhere that the sensor for the MCU is not accurate? I am not sure if that is something that has been fixed or updated?
            I was also wondering if the sdcard gets warm, if cooling would help it's reliability?
            deckingmanundefined droftartsundefined dc42undefined 3 Replies Last reply Reply Quote 0
              ................. I read somewhere that the sensor for the MCU is not accurate? I am not sure if that is something that has been fixed or updated? ................
              It's not terribly accurate but can be calibrated (essentially by applying an offset). M912 is the command to put in your config.g https://docs.duet3d.com/User_manual/Reference/Gcodes#m912-set-electronics-temperature-monitor-adjustment
              The process is to leave the machine to cool down - say overnight. Then take a reading of the ambient, preferably close to the MCU if it's likely to vary. Then turn the machine on and note the MCU temperature in DWC as soon as possible. The difference between ambient and reported will be the offset to apply.
                @michael-hathaway Oh, sorry, must have been another picture of a Mini 5+ I saw with a heatsink on the MCU. The MCU generally doesn't get that hot; probably 20C over ambient. And cooling the PCB would be plenty for that.
                For the Mini 5+ MCU temperature sensor, see https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_configuring_mcu_temp#mcu-temp-in-duet-3-mini-5
                The SAME54P20A chip used in the Duet 3 Mini 5+ does not have a functioning temperature sensor. In theory it does have an on-chip temperature sensor, but the errata document for the chip says it doesn't work.
                However, experimental support for the Duet 3 Mini 5+ on-chip MCU temperature sensor has been added in RepRapFirmware 3.3 beta 3. As the chip manufacturer advises that it is not supported and should not be used, we can't promise that it will give useful readings on all boards. It will be removed if it causes significant support issues. Please report any issues in the Duet3D support forum.
                We haven't had any negative reports about accuracy since enabling it, so 🤷 !
                I think the SD card can get warm if working hard, and can get hot if it has been shorted (usually 24V shorted to 3.3V rail). But I don't think it gets any hotter than the MCU.
                  @deckingman Thank you for that. I had the mini 5 MCU as high as 67-69C, but I have the feeling that it was a lot hotter than that because it was doing some crazy things.
                    dc42 administrators @Michael Hathaway
                    The MCU doesn't generate much heat so it doesn't require a heatsink. The built-in temperature sensor can be calibrated to improve its accuracy, see https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_configuring_mcu_temp#calibrating-the-mcu-temperature.
                    SD cards don't generate much heat. If the Duet as a whole is getting hot, cooling it with a fan might extend the life of the SD card.
                      Michael Hathaway @dc42
                      @dc42 Thank you DC42. My actual problem with the mini 5 is that it is inside the heat chamber, so I will have to pump cool air in and then back out.
                      I do not have heat problems with my 6HC's. This project is just for fun. 😁
                      Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
                        Michael Hathaway @Michael Hathaway
                        Thing of beauty. Now I need to add the heat sink/6HC assembly and take her for a test ride.
                          I finally got around to making the new 6HC enclosure which is inside my print enclosure. The board/drivers will be cooled with ambient air from outside the chamber.
                          1 Reply Last reply Reply Quote 5
