Solved SOLVED - Heater Temp not increasing after initial test.
yes temp rises with holding it in my hand and matches if i plug in my stock hotend... i spoke with other people who have installed rapido on ender hardware and all have said it was just plug and play. I just swapped out connectors on the wires only thing changed isI wanted to update to the latest firmware... So i used reprap configurator to reconfigure for updating firmware from 2.x to latest via duet documentation guide....
It just feels like i did something wrong in the configurator but im not sure what... like i mentioned when i swapped the tool numbers in the config.g for bed and heater and enabled the bed heater... the nozzle started climbing normally. I just cant figure out how to swap them in system files... It seems like whats going on now is bed and nozzle are both configured to same tool and the bed got the spot and nozzle is in limbo somewhere.
does anything in my congig-override seem odd? should my H1 say V0? considering the bed says 24.1...
; config-override.g file generated in response to M500 at 2022-09-16 11:17
; Heater model parameters
M307 H0 A108.5 C416.2 D6.8 S1.00 V24.1 B0
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
Jeeze man and now this morning when i boot up there is no heater button on paneldue
WHAT THE EFF IS GOING ON -
@anvil said in PLEASE HELP- Heater Temp not increasing after initial test.:
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0Delete these lines from your config.g
And please post your current config.g.
@phaedrux said in PLEASE HELP- Heater Temp not increasing after initial test.:
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0Delete these lines from your config.g (do you mean config-override? those lines arent in my gonfig.g)
current config.g
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.13 on Sun Sep 18 2022 12:45:59 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Ender 5 Plus IWS" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.56 Y80.49 Z801.62 E674.42 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E10000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1200 I10 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F180 T12000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X42 Y11 Z2.5 ; set Z probe trigger value, offset and trigger height
M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
M557 X0:315 Y0:315 S25 ; define mesh grid; Heaters
M950 H1 C"!e0heat" T1 ; create nozzle heater output on !e0heat and map it to sensor 1
M563 P1 S"Nozzle" D0 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
can i just delete everything in my config-override?
and also i just changed
to
i forgot i tried to invert it to see if that worked.
Just for giggles and grins I tried to see if maybe they somehow sent me a rapido plus with the pt1000 and temp read 2000c so its not that.
phaetus has the regular thermistor listed as a Semitec 104NT4 thermistor
104NT-4-R025H42Gif that makes any difference?
Do they give any values for that thermistor?
Doing some googling it looks like the same as the E3D thermistor and it uses these settings
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
change in thermistor values made no difference.
I dont understand how changing the hotend thermistor values would change anything if when i swap T0 and T1 in the m307 definition in the config the nozzle then works and increases in temperature until it dead times out from the bed thermistor not reading an increase in temperature.
Does it not seem like a config issue of some sort? I figured that changing those tool numbers sort of indicated that its a config issue... like the reprap configurator has gotten something wrong or I input something wrong in it and then its burried in the .json file somewhere and i just dont know...
Ive reached out to phaetus to ask if there is anything im missing or if there is any values they may know of.
Is the forum the only place to get support for an issue like this? I really need to get this sorted out asap.
How do you have it wired? Your config doesn't define a t1 at all so not sure how changing that makes a difference.
Can you show how it's wired?
Its sort of a process to remove and open the enclosure....but i have the heater wires coming out of the e0 output connector.... but i think im finding my issue...in the reprap configurator
SO... currently its labeled like this for the I/O mapping/ heaters and tools
but it looks like in the I/O mapping section i should swap nozzle and heater so the nozzle output is on 0 and the bed is on 1
but when i do that and go to the tool define section It wont let me select the H1 option it just keeps it N/A
should i just swap the wires to the e1 heater output maybe and see if that works?
Im not understanding why it wont let me select the nozzle as the 0 heater in the mapping page and also define it as a tool. and i tried changing it to tool 1 but it still doesnt work
thats how the heater output is wired e0
and this doesnt define heater 1 as tool 1?
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C -
It's typical to have the bed heater defined as heater 0 and extruders after.
The first tool should be tool0.
Leave your wiring as it is, and change your config like this
; Tools M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
Then at the bottom of config.g add
T0
should i change my heaters m950 values to reflect accordingly?
like delete the T0 from the bed m950 and change the nozzle m950 to T0?
or just delete those values all together from that heater section of the config? -
No, leave the heater section alone. Just change the tool definition.
ugh dangit. Nada.
and you're sure the nozzle T1 and bed T0 in the heaters section aren't affecting that?
Ok so I was just starting to feel like it may somehow be a bad heater core and I plugged in a new rapido hotend just to at least rule it out. And it worked!!
No idea if it sent it to the moon on initial test and burned the heater core out or something but It appears to have just been the heater itself!
Sheesh! -
@anvil i did say check it with a multimeter....
@jay_s_uk haha yaaaaa. crud
