    motor phase A/B may be disconnected reported by driver(s) 0123
    835
    • nicolo17undefined
      nicolo17 @Phaedrux
      @phaedrux hello, thank you very much for your reply!
      This is a new build, but the board was used before in another printer with different motors, it's not new.
      To verify the phases I used a multimeter, if I get resistance between 2 wires, that belong to the same phase, no continuity = different phase.
      If I disconnect all the motors and I try to home x and y I get the same error
      • nicolo17undefined
        nicolo17 @Phaedrux
        @phaedrux I'm using a 12V 33A psu, specifications of the motor: https://www.gotronic.fr/pj-451.pdf
          Phaedrux Moderator @nicolo17
          @nicolo17 said in motor phase A/B may be disconnected reported by driver(s) 0123:
          Can you test with one of those previously working motors?
          nicolo17undefined 1 Reply Last reply Reply Quote 0
          • nicolo17undefined
            nicolo17 @Phaedrux
            @phaedrux I tested now the old motors and I got the same error...
            hayseed_byteundefined 1 Reply Last reply Reply Quote 0
            • hayseed_byteundefined
              hayseed_byte @nicolo17
              @nicolo17
              You might check this thread:
              https://forum.duet3d.com/topic/28498/phase-a-and-b-may-be-disconnected
              I believe you're trying to make the motors go too fast for your supply voltage.
              https://wildbot.me/wildbot
              Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
              • nicolo17undefined
                nicolo17 @hayseed_byte
                @hayseed_byte @Phaedrux Thank you! I tried to change speed and acceleration (now I put very low values) in config.g under "drivers" sectionandand I'm still getting the same error 😞
                This is my config.g section:
                M569 P2 S0 ; physical drive 2 goes backwards
                M92 X100.00 Y100.00 Z400.00 E100.00 ; set steps per mm
                M566 X100.00 Y100.00 Z5.00 E100.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X400.00 Y400.00 Z50.00 E400.00 ; set maximum speeds (mm/min)
                M201 X900.00 Y900.00 Z70.00 E2500.00 ; set accelerations (mm/s^2)
                M906 X1500 Y1500 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30
                I also share my M122 response, if it can help:
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later
                Board ID: 08DGM-95BNL-MGPSN-6J9F6-3S46N-TJWMW
                Used output buffers: 3 of 26 (26 max)
                Static ram: 23860
                Dynamic ram: 75168 of which 12 recycled
                Never used RAM 12968, free system stack 130 words
                Tasks: NETWORK(ready,6.4%,219) HEAT(notifyWait,0.0%,329) Move(notifyWait,0.0%,312) MAIN(running,92.6%,440) IDLE(ready,1.0%,30), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:06:54 ago, cause: software
                Last software reset at 2022-09-18 10:58, reason: User, GCodes spinning, available RAM 12968, slot 0
                Error status: 0x04
                Aux0 errors 0,0,0
                Step timer max interval 0
                MCU temperature: min 26.1, current 26.7, max 27.6
                Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 3278 queued, 3278 completed
                Driver 0: standstill, SG min n/a
                Driver 1: standstill, SG min n/a
                Driver 2: standstill, SG min n/a
                Driver 3: standstill, SG min n/a
                Driver 4: over temperature warning, over temperature shutdown, phase A short to ground, phase B short to ground, standstill, SG min n/a
                Driver 5:
                Driver 6:
                Driver 7:
                Driver 8:
                Driver 9:
                Driver 10:
                Driver 11:
                Date/time: 2022-09-18 11:05:18
                Slowest loop: 9.98ms; fastest: 0.19ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 3, maxWait 43059ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 10, completed 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                === AuxDDARing ===
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty
                === Network ===
                Slowest loop: 202.25ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  WiFi firmware version 1.26
                  WiFi MAC address 2c:3a:e8:0b:09:1f
                  WiFi Vcc 3.43, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 23752
                  WiFi IP address 192.168.1.116
                  WiFi signal strength -59dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                • nicolo17undefined
                  nicolo17 @nicolo17
                  @nicolo17 I have ''Driver 4: over temperature warning, over temperature shutdown, phase A short to ground, phase B short to ground, standstill, SG min n/a'' because I removed this driver from the board because was burned during an old project
                    Can you grab some close up well lit photos of the board, especially in the driver chip area?
                    • nicolo17undefined
                      nicolo17 @Phaedrux
                      @phaedrux WhatsApp Image 2022-09-19 at 18.28.09.jpeg WhatsApp Image 2022-09-19 at 18.28.10.jpeg
                        You can try adding M569 P4 R-1 to your config to disable that driver entirely. That may get rid of that error at least.
                        As for the other driver errors I'm not sure. You've already tested with previously working drivers and the error persists.
                        From a software side the only two things I can suggest at this point is to try updating the firmware to 3.4.2 just to refresh everything.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.2/Duet2and3Firmware-3.4.2.zip
                        Next you can try connecting a single motor only and a fresh config set from the config tool.
                        Otherwise has there been any event that you can think of which may have caused some damage to the board?
                        • nicolo17undefined
                          nicolo17 @Phaedrux
                          @phaedrux Today a tried to use another duet 2 wifi and now the printer works... I think the other board is broken... I'll try to use it with a duex so I can connect motors directly to it, I hope it will work. Thank you very much for your help!
