inductive Z-probe problem after firmware upgrade
Firmware installation
532
    rubinkingma
    Hi all,
    Im finally upgrading the firmware of my printer (from 1.19)
    Firmware is there and working, web interface is better than ever but i cant get the Z-probe working again and im thinking im missing something basic here (it always is).
    What happens is that if i ask the machine to "home Z" itll go up 5 mm and thats it.
    In home Z It states that itll go up for 5 mm then down.
    I feel like its thinking it allready has a positive Z signal.
    Heres my old config:
    ;*** Wifi Networking
    M552 S1 ; Enable WiFi
    M555 P2 ; Set output to look like Marlin
    M575 P1 B57600 S1 ; Comms parameters for PanelDue
    ; Machine configuration
    M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
    M569 P2 S0 ; Drive 2 goes forwards
    M569 P3 S0 ; Drive 3 goes forwards
    ; If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
    M574 X1 Y1 Z0 S0 ; set endstop configuration (X and Y and endstops only, at low end, active high)
    M667 S1 ; set CoreXY mode
    M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
    M92 X80 Y80 Z400 ; Set axis steps/mm
    M92 E418.5:418.5 ; Set extruder steps/mm
    M906 X800 Y800 Z800 E800 ; Set motor currents (mA)
    M201 X1200 Y1200 Z30 E1000 ; Accelerations (mm/s^2)
    M203 X15000 Y15000 Z600 E3600 ; Maximum speeds (mm/min)
    M566 X600 Y600 Z30 E20 ; Maximum jerk speeds mm/minute
    M208 X300 Y198 Z160 ; set axis maxima (adjust to suit your machine)
    M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
    G21 ; Work in millimetres
    ; Z probe
    M558 P5 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis
    G31 X 28 Y12 Z0.4 P500 ; Set the probe height and threshold (put your own values here)
    ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
    ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
    M557 P0 X60 Y30 ; Four...
    M557 P1 X60 Y165 ; ...probe points...
    M557 P2 X222 Y165 ; ...for bed...
    M557 P3 X222 Y30 ; ...levelling
    ;M557 P4 X141 Y82.5 ; 5th probe point for levelling
    ; Thermistors and heaters
    ;*** You can use S and B parameters to define the parameters of the thermistors you are using
    M305 P0 R4700 T100000 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
    ;M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
    M305 P1 R4700 T100000 B4725 C7.06e-8
    M307 H1 A314.3 C197.3 D3.5 B0
    M143 H1 S288
    M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
    M301 H1 P30 I0.14 D90 T0.50 S1.0 ; PID settings for extruder 0
    M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
    M570 S120 ; Increase to allow extra heating time if needed
    ; Tool definition
    M563 P0 D0 H1 ; Define tool 0
    G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
    ;*** If you have a dual-nozzle build, un-comment the following 3 lines
    ;M563 P1 D1 H2 ; Define tool 1
    ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
    ;*** If you are using axis compensation, put the figures in the following command
    M556 S78 X0 Y0 Z0 ; Axis compensation here
    T0 ; select first hot end
    And this is the new config:
    M550 P"Hypercube Master" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P3 S0 ; physical drive 3 goes forwards
    M92 X80.00 Y80.00 Z400.00 E418.50 ; set steps per mm
    M203 X900000.00 Y900000.00 Z36000.00 E216000.00 ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z30.00 E1000.00 ; set accelerations (mm/s^2)
    M84 S30 ; Set idle timeout
    M208 X300 Y198 Z160 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
    M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
    M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X28 Y12 Z0.4 ; set Z probe trigger value, offset and trigger height
    ;M308 P1 B4725 C7.060000e-8
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
    The probe is a inductive PNP normally open sensor.
    Chances are there are more things not fixed at this point.
    Thanks in advance!!
    Rubin, The Netherlands
      Th0mpy
      Does the z-probe show triggered in DWC? Also, what board are you running?
      If you are in fact inverted on the signal you can change this line:
      Add an "!" before the pin name so it reads like this:
      M558 P5 C"!zprobe.in" H5 F120 T6000
      Usually the team that scores the most points wins the game.
        rubinkingma
        It shows triggered when it should (gives a value of 1000 when approached with something metal).
        Also i kinda solved it, tho im not sure if this is a solution "as intended"
        Apparantly i forgot to tell the system to use the probe as a Z-stop.
        So heres the updated config:
        M574 Z1 S2
        M558 P5 C"^zprobe.in" H5 F120 T6000
        ;M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        I added the M574 Z1 S2 line, then needed to slow the home script because of fast aproach
        Tell me if im doing this wrong 😄
        Next are the heaters, configuring my slicer again, start working with my materials apart from generated G-code.
        Enough to do
        undefined 2 Replies Last reply 19 Sept 2022, 19:32 Reply Quote 0
          Th0mpy @rubinkingma
          @rubinkingma
          You shouldn't need the M574 Z1.... Let me look at my config, one moment.
            Th0mpy @rubinkingma
            @rubinkingma
            This should be all you need, this is mine:
            M558 P5 C"^io3.in" H5 F600 T6000 A10
            G31 P500 X0 Y25 Z3.6
            M557 X15:205 Y25:205 P4
            undefined 1 Reply Last reply 19 Sept 2022, 19:42 Reply Quote 0
              What do you have in your homing files?
              @rubinkingma said in inductive Z-probe problem after firmware upgrade:
              ; Z probe
              You should remove the old RRF2 commands.
              undefined 1 Reply Last reply 19 Sept 2022, 19:45 Reply Quote 0
                rubinkingma @Th0mpy
                @th0mpy
                Weird, when i dont it complains about "cant enable endstop".
                undefined 1 Reply Last reply 19 Sept 2022, 19:43 Reply Quote 0
                  Th0mpy @rubinkingma
                  @rubinkingma
                  Can you paste in your homeall.g and homez.g?
                  Sorry, what board are you using? Just to confirm the pins.
                  undefined 1 Reply Last reply 19 Sept 2022, 19:47 Reply Quote 0
                    rubinkingma @Phaedrux
                    @phaedrux
                    Thank you for your reply, what part is RRF2 ?
                    I got to 3xx firmware today after running 1.19 since 2017
                    Used the configurator and while i could have dropped some old stuff in there looking for solutions i'm not at the point where i can see the difference between old and new config.
                      rubinkingma @Th0mpy
                      @th0mpy
                      homeall ( I have been dicking around with this for mesh compensation)
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.3.13 on Mon Sep 19 2022 15:01:08 GMT+0200 (Midden-Europese zomertijd)
                      ;G91 ; relative positioning
                      ;G1 H2 Z5 F6000 ; lift Z relative to current position
                      ;G1 H1 X-305 Y-203 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                      ;G1 H1 X-305 ; home X axis
                      ;G1 H1 Y-203 ; home Y axis
                      ;G1 X5 Y5 F6000 ; go back a few mm
                      ;G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                      ;G1 H1 Y-203 ; then move slowly to Y axis endstop
                      ;G1 H1 Z-165 F360 ; move Z down stopping at the endstop
                      ;G90 ; absolute positioning
                      ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                      ; homeall.g
                      G1 H2 X5 Y5 F6000 ; go back a few mm
                      G1 H2 Z5 F6000
                      G1 X150 Y100 F6000
                      G30 ;probe bed
                      Home Z
                      ; homez.g
                      ; called to home the Z axis
                      G1 H2 Z5 F600 ; lift Z relative to current position
                      G1 H1 Z-165 F1000 ; move Z down until the endstop is triggered (first pass)
                      G1 Z5 F1000 ; go back a few mm
                      G1 H1 Z-100 F360 ; move slowly to Z axis endstop once more (second pass)
                      undefined 1 Reply Last reply 19 Sept 2022, 19:51 Reply Quote 0
                        Ah, nevermind about the old config parts. I see now that it's two separate configs. I've edited your post to make it a bit clearer.
                        Can you send M122 and M98 P"config.g" in the console and copy and paste the results here?
                        undefined undefined 2 Replies Last reply 19 Sept 2022, 19:50 Reply Quote 0
                          @phaedrux
                          M122:
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
                          Board ID: 08DAM-9K9K2-NGNSN-6J9D6-3S46T-TPSRK
                          Used output buffers: 1 of 26 (24 max)
                          Static ram: 23860
                          Dynamic ram: 74924 of which 40 recycled
                          Never used RAM 13184, free system stack 106 words
                          Tasks: NETWORK(ready,15.2%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,292) MAIN(running,84.8%,442) IDLE(ready,0.0%,30), total 100.0%
                          Owned mutexes: WiFi(NETWORK)
                          Last reset 01:25:43 ago, cause: power up
                          Last software reset at 2022-09-19 20:21, reason: User, GCodes spinning, available RAM 13256, slot 0
                          Error status: 0x08
                          Aux0 errors 0,0,0
                          Step timer max interval 0
                          MCU temperature: min 40.0, current 40.5, max 43.3
                          Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                          Events: 0 queued, 0 completed
                          Driver 0: standstill, SG min 31
                          Driver 1: standstill, SG min 38
                          Driver 2: standstill, SG min 13
                          Driver 3: standstill, SG min n/a
                          Driver 4: standstill, SG min n/a
                          Driver 5:
                          Driver 6:
                          Driver 7:
                          Driver 8:
                          Driver 9:
                          Driver 10:
                          Driver 11:
                          Date/time: 2022-09-19 21:49:25
                          Slowest loop: 8.64ms; fastest: 0.17ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 0.7ms, write time 24.2ms, max retries 0
                          DMs created 83, segments created 3, maxWait 1254428ms, bed compensation in use: mesh, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 883, completed 883, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty
                          === Network ===
                          Slowest loop: 243.62ms; fastest: 0.07ms
                          HTTP sessions: 1 of 8
                          = WiFi =
                          Network state is active
                          WiFi firmware version 1.27
                          WiFi MAC address 5c:cf:7f:f7:de:92
                          WiFi Vcc 3.37, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 25864
                          WiFi IP address 192.168.1.201
                          WiFi signal strength -77dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                            Th0mpy @Phaedrux
                            @phaedrux
                            I see the issue.
                            In the homez.g file change this:
                            to this
                            G1 X150 Y150 F6000
                            G90
                            G30
                              Phaedrux Moderator @rubinkingma
                              Your homez.g file is still looking for an endstop. It needs to be changed to use G30 instead of a G1 H1 Z move in order to use the probe.
                              Your homeall.g is using both an endstop move AND a G30 to probe.
                              Here are the corrected files
                              ; homeall.g
                              G1 X150 Y100 F6000
                              G30 ;probe bed
                              ; homez.g
                              G1 X150 Y100 F6000
                              G30 ;probe bed
                              undefined 1 Reply Last reply 19 Sept 2022, 19:54 Reply Quote 0
                                Th0mpy @Phaedrux
                                @phaedrux
                                Stop replying so fast 🙂
                                But you're right, I missed the homeall.g error.
                                  rubinkingma
                                  Thanks to you both!
                                  So it works now, this or next week ill start printing again and see what else i can find to complain about.
                                  This used to be my "quick and dirty" machine, and after a few years almost the only machine i use.
                                  I never took the time to really make it print nicely because i had a E3D volcano on it with a 0.8 Nozzle.
                                  Now with all these cool changes i want to dial it in with a 0.6 nozzle and make it a really nice machine.
                                  Its a core XY "hypercube" remix with hiwin rails for the bed.
                                  It should be able to make very nice prints if i just spend some time with it
                                  undefined 1 Reply Last reply 19 Sept 2022, 20:04 Reply Quote 1
                                    Th0mpy @rubinkingma
                                    @rubinkingma
                                    Excellent! Happy Printing!
                                    2 out of 17
