inductive Z-probe problem after firmware upgrade
Firmware installation
532
    Th0mpy
    Does the z-probe show triggered in DWC? Also, what board are you running?
    If you are in fact inverted on the signal you can change this line:
    M558 P5 C"zprobe.in" H5 F120 T6000
    Add an "!" before the pin name so it reads like this:
    M558 P5 C"!zprobe.in" H5 F120 T6000
    Usually the team that scores the most points wins the game.
      rubinkingma
      It shows triggered when it should (gives a value of 1000 when approached with something metal).
      Also i kinda solved it, tho im not sure if this is a solution "as intended"
      Apparantly i forgot to tell the system to use the probe as a Z-stop.
      So heres the updated config:
      M208 X300 Y198 Z160 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2
      M558 P5 C"^zprobe.in" H5 F120 T6000
      ;M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X28 Y12 Z0.4 ; set Z probe trigger value, offset and trigger height
      I added the M574 Z1 S2 line, then needed to slow the home script because of fast aproach
      Tell me if im doing this wrong 😄
      Next are the heaters, configuring my slicer again, start working with my materials apart from generated G-code.
      Enough to do
      undefined 2 Replies Last reply 19 Sept 2022, 19:32 Reply Quote 0
        Th0mpy @rubinkingma
        @rubinkingma
        You shouldn't need the M574 Z1.... Let me look at my config, one moment.
          Th0mpy @rubinkingma
          @rubinkingma
          This should be all you need, this is mine:
          M558 P5 C"^io3.in" H5 F600 T6000 A10
          G31 P500 X0 Y25 Z3.6
          M557 X15:205 Y25:205 P4
          undefined 1 Reply Last reply 19 Sept 2022, 19:42 Reply Quote 0
            What do you have in your homing files?
            @rubinkingma said in inductive Z-probe problem after firmware upgrade:
            ; Z probe
            M558 P5 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis
            G31 X 28 Y12 Z0.4 P500 ; Set the probe height and threshold (put your own values here)
            You should remove the old RRF2 commands.
            undefined 1 Reply Last reply 19 Sept 2022, 19:45 Reply Quote 0
              rubinkingma @Th0mpy
              @th0mpy
              Weird, when i dont it complains about "cant enable endstop".
              undefined 1 Reply Last reply 19 Sept 2022, 19:43 Reply Quote 0
                Th0mpy @rubinkingma
                @rubinkingma
                Can you paste in your homeall.g and homez.g?
                Sorry, what board are you using? Just to confirm the pins.
                undefined 1 Reply Last reply 19 Sept 2022, 19:47 Reply Quote 0
                  rubinkingma @Phaedrux
                  @phaedrux
                  Thank you for your reply, what part is RRF2 ?
                  I got to 3xx firmware today after running 1.19 since 2017
                  Used the configurator and while i could have dropped some old stuff in there looking for solutions i'm not at the point where i can see the difference between old and new config.
                    rubinkingma @Th0mpy
                    @th0mpy
                    homeall ( I have been dicking around with this for mesh compensation)
                    ; homeall.g
                    ; called to home all axes
                    ; generated by RepRapFirmware Configuration Tool v3.3.13 on Mon Sep 19 2022 15:01:08 GMT+0200 (Midden-Europese zomertijd)
                    ;G91 ; relative positioning
                    ;G1 H2 Z5 F6000 ; lift Z relative to current position
                    ;G1 H1 X-305 Y-203 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                    ;G1 H1 X-305 ; home X axis
                    ;G1 H1 Y-203 ; home Y axis
                    ;G1 X5 Y5 F6000 ; go back a few mm
                    ;G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                    ;G1 H1 Y-203 ; then move slowly to Y axis endstop
                    ;G1 H1 Z-165 F360 ; move Z down stopping at the endstop
                    ;G90 ; absolute positioning
                    ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                    ; homeall.g
                    G1 H2 X5 Y5 F6000 ; go back a few mm
                    G1 H2 Z5 F6000
                    G1 X150 Y100 F6000
                    G30 ;probe bed
                    Home Z
                    ; homez.g
                    ; called to home the Z axis
                    G1 H2 Z5 F600 ; lift Z relative to current position
                    G1 H1 Z-165 F1000 ; move Z down until the endstop is triggered (first pass)
                    G1 Z5 F1000 ; go back a few mm
                    G1 H1 Z-100 F360 ; move slowly to Z axis endstop once more (second pass)
                    undefined 1 Reply Last reply 19 Sept 2022, 19:51 Reply Quote 0
                      Ah, nevermind about the old config parts. I see now that it's two separate configs. I've edited your post to make it a bit clearer.
                      Can you send M122 and M98 P"config.g" in the console and copy and paste the results here?
                      undefined undefined 2 Replies Last reply 19 Sept 2022, 19:50 Reply Quote 0
                        @phaedrux
                        M122:
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
                        Board ID: 08DAM-9K9K2-NGNSN-6J9D6-3S46T-TPSRK
                        Used output buffers: 1 of 26 (24 max)
                        Static ram: 23860
                        Dynamic ram: 74924 of which 40 recycled
                        Never used RAM 13184, free system stack 106 words
                        Tasks: NETWORK(ready,15.2%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,292) MAIN(running,84.8%,442) IDLE(ready,0.0%,30), total 100.0%
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 01:25:43 ago, cause: power up
                        Last software reset at 2022-09-19 20:21, reason: User, GCodes spinning, available RAM 13256, slot 0
                        Error status: 0x08
                        Aux0 errors 0,0,0
                        Step timer max interval 0
                        MCU temperature: min 40.0, current 40.5, max 43.3
                        Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                        Events: 0 queued, 0 completed
                        Driver 0: standstill, SG min 31
                        Driver 1: standstill, SG min 38
                        Driver 2: standstill, SG min 13
                        Driver 3: standstill, SG min n/a
                        Driver 4: standstill, SG min n/a
                        Driver 5:
                        Driver 6:
                        Driver 7:
                        Driver 8:
                        Driver 9:
                        Driver 10:
                        Driver 11:
                        Date/time: 2022-09-19 21:49:25
                        Slowest loop: 8.64ms; fastest: 0.17ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 0.7ms, write time 24.2ms, max retries 0
                        DMs created 83, segments created 3, maxWait 1254428ms, bed compensation in use: mesh, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 883, completed 883, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty
                        === Network ===
                        Slowest loop: 243.62ms; fastest: 0.07ms
                        HTTP sessions: 1 of 8
                        = WiFi =
                        Network state is active
                        WiFi firmware version 1.27
                        WiFi MAC address 5c:cf:7f:f7:de:92
                        WiFi Vcc 3.37, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 25864
                        WiFi IP address 192.168.1.201
                        WiFi signal strength -77dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                          Th0mpy @Phaedrux
                          @phaedrux
                          I see the issue.
                          In the homez.g file change this:
                          to this
                          G1 X150 Y150 F6000
                          G90
                          G30
                            Phaedrux Moderator @rubinkingma
                            Your homez.g file is still looking for an endstop. It needs to be changed to use G30 instead of a G1 H1 Z move in order to use the probe.
                            Your homeall.g is using both an endstop move AND a G30 to probe.
                            Here are the corrected files
                            ; homeall.g
                            G1 X150 Y100 F6000
                            G30 ;probe bed
                            ; homez.g
                            G1 X150 Y100 F6000
                            G30 ;probe bed
                            undefined 1 Reply Last reply 19 Sept 2022, 19:54 Reply Quote 0
                              Th0mpy @Phaedrux
                              @phaedrux
                              Stop replying so fast 🙂
                              But you're right, I missed the homeall.g error.
                                rubinkingma
                                Thanks to you both!
                                So it works now, this or next week ill start printing again and see what else i can find to complain about.
                                This used to be my "quick and dirty" machine, and after a few years almost the only machine i use.
                                I never took the time to really make it print nicely because i had a E3D volcano on it with a 0.8 Nozzle.
                                Now with all these cool changes i want to dial it in with a 0.6 nozzle and make it a really nice machine.
                                Its a core XY "hypercube" remix with hiwin rails for the bed.
                                It should be able to make very nice prints if i just spend some time with it
                                undefined 1 Reply Last reply 19 Sept 2022, 20:04 Reply Quote 1
                                  Th0mpy @rubinkingma
                                  @rubinkingma
                                  Excellent! Happy Printing!
                                  11 out of 17
