    How do I use the BL-Touch When homing Z-axis
    Using Duet Controllers
    398
      jay_s_uk @TomasL
      @tomasl e.g.
      G1 X100 Y100
      G30
      obviously changing the move location to the centre of the bed, taking into account to offset of the probe as the firmware won't
      TomasLundefined 1 Reply Last reply Reply Quote 0
      • TomasLundefined
        TomasL @jay_s_uk
        @jay_s_uk
        Ok, so I,ll put this in the config.g, presumably at the end.
        So it would read
        G1 X33,5 Y82,5 Z5
        G30
        If I do this via the console, Z stops att 2,43 (+5mm) I do assume that the X-axis is lifted 5 mm after the g30 command.
        jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @TomasL
          @tomasl not in config, in your homing files
            jay_s_uk @TomasL
            @tomasl and if you want any further movements after the probe then you'll need to add those in
            • TomasLundefined
              TomasL @jay_s_uk
              @jay_s_uk
              Ok, I have put in homeall.g and homez.g
              G1 X33,5 Y82,5 F6000
              G30
              However Z-level is the same as the trigger height, is that correct?
                jay_s_uk @TomasL
                @tomasl the height it'll set is the z offset that you've set in G31 in your config
                • TomasLundefined
                  TomasL @jay_s_uk
                  @jay_s_uk Ok
                    For the record
                    https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
                    https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#bltouch
                    • TomasLundefined
                      TomasL @Phaedrux
                      @phaedrux Yes, I know all that, however my question was not answer in those documents.
                      droftartsundefined 1 Reply Last reply Reply Quote 1
                        droftarts administrators @TomasL
                        @tomasl For example configurations, see https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian#homing-z
