    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • jmjcoke2undefined
      jmjcoke2
      11
      12
        Time to review the wish list. Here is the original one, in order of decreasing votes, and a note of which ones have been implemented:
        (24 votes) 7. Dynamically-varying microstepping. This will allow you to configure 256x microstepping most cases, because the microstepping will be reduced automatically during high-speed moves.
        (19 votes) 1. Reworked WiFi server code, including configuration using files on the SD card, automatic retry if the connection is lost, live reporting of signal strength and status, more reliable support of multiple concurrent connections, and optional FTP and Telnet support. Done, although multiple concurrent clients can be problematic when one of them goes offline without disconnecting first.
        (17 votes) 6. Live monitoring of TMC2660 driver status and reporting of problems (e.g. overheat warning). Done.
        (17 votes) 16. Feed-forward temperature control to predict the effect of turning the print cooling fan on or increasing the extrusion rate, and therefore reduce the temperature fluctuation.
        (14 votes) 14. Support for powering off during a print, then resuming it when the printer is powered up again. Done, and being improved in 1.20.
        (13 votes) 3. Logging of various events, including print start/pause/resume/cancel/end, and error messages. Done in 1.20
        (13 votes) 17. Filament and printing time odometers.
        (13 votes) 18. Ability to update PanelDue firmware via the web interface. PanelDue version 3 has the hardware to support this but the firmware support needs to be written.
        (12 votes) 5. True bed levelling using 2, 3 or possibly 4 independently-driven Z motors and a Z probe. Done.
        (10 votes) 15. Support for PanelOne 20x4 text displays, or possibly 12864 mono graphics displays.
        (9 votes) 12. Better support for CNC machines. Partly done (M3/M4/M4 commands implemented in 1.20).
        (9 votes) 20. Ability to control an electronics cooling fan thermostatically based on CPU temperature and driver overheat warning. Done.
        (8 votes) 8. Standstill current reduction, which will allow higher motor currents to be used when the motors are moving.
        (8 votes) 19. Ability to wait for cool down before turning off ATX power.
        (7 votes) 11. Better support for laser cutters. Partly done (M3/M4/M4 commands implemented in 1.20).
        (6 votes) 13. Automatic advance of changes in the colour mix when using a mixing hot end. See deckingman's blog.
        (5 votes) 2. Better network security, including SSL if it can be made to work fast enough.
        (4 votes) 4. Independent homing switches for multiple Z motors. Largely superseded by #5, but can be done by defining additional axes.
        (4 votes) 9. Auto-park of motors when power is lost. This will help prevent motors getting out of sync when multiple motors are used to drive a single axis.
        (4 votes) 10. Axis hysteresis compensation.
        In addition, some new features have been requested:
        (requested and seconded) Filament monitor In beta
        (requested and seconded) Heater fault to pause print instead of aborting it Coming in 1.20beta2
        Automatic firmware update I would be reluctant to do this, because firmware updates sometimes require changes to the configuration files
        Email notifications of e.g. print complete
        Print start/stop macros There is already stop.g which is called when M0 is executed at the end of your print, and you can use the slicer start/end gcode to call your own macros
        Automatic XY skew compensation (using Mk42 bed)
        Use Stallguard for bed probing See recent thread on this subject
        Probe the bed multiple times at each point and take an average
        Allow file uploads to be requested during a print, defer them until the print has completed
        When bed probing, allow the probe point to be approached from the same direction each time, to mitigate the effect of combined tilt and backlash when positioning the head
        As many of the items have been completed now, I'll stat a new wishlist soon. Top of that list will be the highest-voted items that haven't yet been implemented. But before I create a new thread for the new wishlist, are there any other items that should be on it - for example, using StallGuard to detect printing problems?
        • Mikeundefined
          Mike
          Using StallGuard to detect possible print collisions and layer shifts is probably the coolest feature in Prusa's new i3. I realize it's much easier for them since Prusa Research controls which motors they have, but an option to configure that would be really nice.
            deckingman
            David,
            I'd kind of hold fire on "13 - advancing tool change commands" due to my recent discoveries about PLA hydrolysing which means it still needs to be purged. Granted, advancing the tool change command would reduce the amount of purge required, but that purge would still need to happen at the original tool position - not the new (advanced) one. So it all gets a bit complicated. You'd need to do something like move the tool command forward but keep the original in place, then do the (small) purge on the second (the original) instance of that tool command. Having said all that, filaments which don't hydrolyse may benefit but I need to do more testing.
            • Vladundefined
              Vlad
              12
              14
              Not the most popular options, but that would really be a next big step forward in this board and allow us to build more complex machines using it.
              • Vladundefined
                Vlad
                How about
                1. an iPhone/Android APP to control the board remotely? I think that would be awesome. Seems like an obvious choice, but I believe there is no app available yet.
                2. Make UI more eye pleasing/tap friendly.
                I know aesthetics is definitely less important than functional part, but shouldn't be overlooked too in my opinion 🙂 Just purchased your board, haven't received yet. Very excited to start my new build with it. Would loved to have purchased two boards, one for my CNC router, but I am unsure if it can deliver solid CNC functionality at this point. SO stayed with MACH4 controlled breakout board from "PoKeys" company. Would really prefer to switch to your board at some point in future though.
                • adavidmundefined
                  adavidm
                  @Vlad:
                  How about
                  The web interface works really nicely as a full screen web app on Android ("Add to Home Screen" on Chrome menu). It's responsive and full-featured, including access to the web-cam display. I use it to keep an eye on the printer from a different room in the house.
                  I don't think there is anything technically stopping the web interface from being accessed over the Internet using port-forwarding or reverse-proxying. I'd personally be very nervous about doing that though for, hopefully obvious, safety and security reasons.
                  • resamundefined
                    resam
                    I'm using DWC over the Internet via a reverse proxy + TLS + HTTP-Basic-Auth - and it works just fine!
                    Got my webcam, a wifi-enabled power socket, and DWC: all controlled & managed from my phone.
                    Just make sure your proxy doesn't add weird HTTP headers, as the Duet RRF limits headers to 16 at most (memory reasons?)
                      We can support more HTTP headers if it helps.
                      • resamundefined
                        resam
                        @dc42: great! I'm still not sure how I ended up hitting this limit, but my typical nginx config adds at least 4 additional headers. Chrome (or probably any other browser) adds 9 (when POST-upload). HTTP-Basic-Auth is one more header.
                        So we are pretty close to the current limit.
                        If there is enough RAM / resources available, I would recommend bumping [c]MaxHeaders[/c] to maybe at least 24 or 32.
                        (not sure what happens if somebody sends a really large cookie…?)
                          I've increased it to 30 for the Duet WiFi/Ethernet in the next beta. The other limit is that a complete HTTP request (excluding any postdata) must fit in 1460 bytes. A really large cookie could cause this limit to be exceeded, however DWC hasn't used cookies for a long time.
                          • JohnOCFIIundefined
                            JohnOCFII
                            @Mike:
                            Seconded. I have read the other thread, and realize that there may be limitations, but the concept is sure interesting.
                            • jmg123undefined
                              jmg123
                              MQTT - so the printer can send out it’s status to MQTT compatible services, not so it can be controlled. Basically the printer reports as an mqtt sensor.
                              Personally I would use it to send me a text message via IFTTT , or flash my living room lights when a print has stopped/finished. Though other things like show hot end temperature via the colour of. A Philips hue lightbulb would also be possible.
                              Reference designs based on LWIP stack are available. I reckon %complete, finished state and temperatures would be the info to broadcast.
                              https://home-assistant.io/components/sensor.mqtt/
                              • ultrasonic2undefined
                                ultrasonic2
                                10. Axis hysteresis compensation. Backlash compensation
                                Please please please do this… without it 3d printing will never be that good without every expensive hardware..
                                I have a number of printers of different kinematics but ALL suffer from backlash ... Seeming the only way to get rid of 99% of it is to go with ball screws on the X/Y access but that will massively increase cost, weight and inertia leading to a slow print..
                                Also it seems like Marlin is finally implementing this... so..
                                Thanks in advance
                                  deckingman
                                  @ultrasonic2:
                                  Thanks in advance
                                  That's an unusual observation and request. Have you got any pictures or other evidence of how this backlash \ axis hysteresis manifests itself on all your printers? From a basic engineering point of view, backlash is a known phenomenon with screw driven systems and gear trains but not with belted systems, so I'm curious as to why you think that going from a (presumably) belt driven system to a screw driven system would eliminate 99% of the backlash.
                                  • jmlundefined
                                    jml
                                    My votes in order of priority, though may be too late:
                                    • Alex.crundefined
                                      Alex.cr
                                      My Vote, though probably too late:
                                      I am sure Ian knows this but … in order to make the firmware more CNC friendly i would suggest 3 additional things.
                                      G2/G3 circular movement support
                                      Pitch error comp on the axis (for lead screw/ball screw support)
                                      Change M0/M1 to follow CNC convention with stop and option stop that doesn't necessarily cancel the job or turn the heaters off. Just performs a "feed hold"
                                      My 2 cents
                                      Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                                        G2 and G3 are already supported.
                                        Please explain what exactly you mean by "Pitch error comp".
                                        What exactly is the behaviour you would like to see for M0 and M1?
                                        • okerchoundefined
                                          okercho
                                          My vote for:
                                          Okercho
                                          Custom Prusa i3 Hephestos with Duet Wi-Fi
                                          E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                                          Rebuilding Hypercube Evolution
                                          • Alex.crundefined
                                            Alex.cr
                                            @dc42:
                                            My bad on the G2/G3. I guess I never gave it a shot…
                                            Pitch error comp is built into almost every CNC machine tool. It allows a user to deal with manufacturing defects in the lead screw and ball screws on a machine. Most machines allow a user to "adjust" where a specific point is in the axis. So a table by default might have points every 10MM. If you tell the machine to move to X10.0 but because of the lead screw it moves to 10.02, you can then provide that difference so the motion planner can get to the proper point. This is on top of what we would call steps/mm for the axis. This allows changes over the length of the axis. Not necessary for belts, can be very necessary for screws.
                                            For the M0/M1 commands:
                                            These are typically "pause commands" in traditional G-code. M0 will provide a feed hold command until a cycle start has been pressed. The spindle continues to turn.
                                            M1 does the same thing but is hooked to a switch on the controller called "optional stop". When the optional stop button is on(it is latched on, not momentary) the machine will stop just like an M0 and wait for the operator to press cycle start. If the optional stop button is off the machine ignores the command and keeps running. This is very useful when proving out new CNC programs and tooling.
                                            I admit I have not used the pause and resume commands that are in the firmware now. This would just help to bring Reprap firmware to industry standard on the subtractive manufacturing side.
                                            Hope all that makes sense!
