    Extract temp to external display
    Duet Web Control
    1.6k
    • tecnoundefined
      tecno @DIY-O-Sphere
      @DIY-O-Sphere
      M918 P2 E4 R6
      Done no diff, but when I turn the encoder board resets.
      tecnoundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        Tried another set of cables = no go
        Is it maybe so that there is no firmware, if so what files do I need?
        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
        • DIY-O-Sphereundefined
          DIY-O-Sphere @tecno
          @tecno
          Maybe swapped wiring?
          Check if EXP1 + EXP2 on board and the display are plugged in correctly.
          (UTC+1)
            DIY-O-Sphere @tecno
            @tecno
            This is what it looks like in my menu folder
            (UTC+1)
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @DIY-O-Sphere
              @DIY-O-Sphere
              Cables are inserted OK . My menu folder is like yours.
              Did you ever load in FW in your display board?
                DIY-O-Sphere @tecno
                @tecno
                I do not use this type of display, but maybe this will help. There are also versions (think from MKS) where the plug must be turned 180 ° .
                (UTC+1)
                • tecnoundefined
                  tecno @DIY-O-Sphere
                  @DIY-O-Sphere
                  Tried those settings also, next to be a pin detective and see if there is something in wireing.
                  Thanks for help, appreciated.
                  Will try more tomorrow.
                  • tecnoundefined
                    tecno @tecno
                    Pinout seems to be OK.
                    Is this display 5V and not compatible with Mini5+ ?
                    tecnoundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • tecnoundefined
                      tecno @tecno
                      Why is there no DISPLAY in the left menu?
                        DIY-O-Sphere @tecno
                        @tecno
                        It's under System. Have a look at the screenshot I have posted yesterday.
                        (UTC+1)
                          dc42 administrators @tecno
                          @tecno did you get it working?
                          • tecnoundefined
                            tecno @dc42
                            Unfortunately no
                            • tecnoundefined
                              tecno @tecno
                              Is there anybody out there (Pink Floyd) that can help me?
                                DIY-O-Sphere @tecno
                                @tecno
                                Can we have some picures of the wiring?
                                (UTC+1)
                                • tecnoundefined
                                  tecno @DIY-O-Sphere
                                  @DIY-O-Sphere
                                  Std 10 pin cables Exp1 to Exp1 and Exp2 to Exp2
                                  • tecnoundefined
                                    tecno @tecno
                                    Had a look again on how cables are keyed as I did not get any life at all. F-ng assembly from the chinese as turning cables 180° I now get backlight and encoder lit up but nothing on screen.
                                    • tecnoundefined
                                      tecno @tecno
                                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                                        DIY-O-Sphere @tecno
                                        @tecno
                                        As far as I can tell from the picture, turning is required for exp1 but not for exp2.
                                        (UTC+1)
                                          DIY-O-Sphere @tecno
                                          @tecno
                                          Perfect...
                                          (UTC+1)
                                          • tecnoundefined
                                            tecno @DIY-O-Sphere
                                            @DIY-O-Sphere
                                            So now my mini 12864 is working
                                            Next is to get my old RepRapDiscount to work. So how to read the silkscreen on board as regards cable keying?
