    Extract temp to external display
    Duet Web Control
    1.6k
    • tecnoundefined
      tecno @tecno
      Tried another set of cables = no go
      Is it maybe so that there is no firmware, if so what files do I need?
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @tecno
        @tecno
        Maybe swapped wiring?
        Check if EXP1 + EXP2 on board and the display are plugged in correctly.
        (UTC+1)
          DIY-O-Sphere @tecno
          @tecno
          This is what it looks like in my menu folder
          (UTC+1)
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @DIY-O-Sphere
            @DIY-O-Sphere
            Cables are inserted OK . My menu folder is like yours.
            Did you ever load in FW in your display board?
              DIY-O-Sphere @tecno
              @tecno
              I do not use this type of display, but maybe this will help. There are also versions (think from MKS) where the plug must be turned 180 ° .
              (UTC+1)
              • tecnoundefined
                tecno @DIY-O-Sphere
                @DIY-O-Sphere
                Tried those settings also, next to be a pin detective and see if there is something in wireing.
                Thanks for help, appreciated.
                Will try more tomorrow.
                • tecnoundefined
                  tecno @tecno
                  Pinout seems to be OK.
                  Is this display 5V and not compatible with Mini5+ ?
                  tecnoundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • tecnoundefined
                    tecno @tecno
                    Why is there no DISPLAY in the left menu?
                      DIY-O-Sphere @tecno
                      @tecno
                      It's under System. Have a look at the screenshot I have posted yesterday.
                      (UTC+1)
                        dc42 administrators @tecno
                        @tecno did you get it working?
                        • tecnoundefined
                          tecno @dc42
                          Unfortunately no
                          • tecnoundefined
                            tecno @tecno
                            Is there anybody out there (Pink Floyd) that can help me?
                              DIY-O-Sphere @tecno
                              @tecno
                              Can we have some picures of the wiring?
                              (UTC+1)
                              • tecnoundefined
                                tecno @DIY-O-Sphere
                                @DIY-O-Sphere
                                Std 10 pin cables Exp1 to Exp1 and Exp2 to Exp2
                                • tecnoundefined
                                  tecno @tecno
                                  Had a look again on how cables are keyed as I did not get any life at all. F-ng assembly from the chinese as turning cables 180° I now get backlight and encoder lit up but nothing on screen.
                                  tecnoundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                                  • tecnoundefined
                                    tecno @tecno
                                    DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                                      DIY-O-Sphere @tecno
                                      @tecno
                                      As far as I can tell from the picture, turning is required for exp1 but not for exp2.
                                      (UTC+1)
                                        DIY-O-Sphere @tecno
                                        @tecno
                                        Perfect...
                                        (UTC+1)
                                        • tecnoundefined
                                          tecno @DIY-O-Sphere
                                          @DIY-O-Sphere
                                          So now my mini 12864 is working
                                          Next is to get my old RepRapDiscount to work. So how to read the silkscreen on board as regards cable keying?
                                            DIY-O-Sphere @tecno
                                            @tecno
                                            (UTC+1)
