BLtouch not deploying
homez
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 22 2022 15:24:14 GMT+0100 (Central European Standard Time)
G1 H2 Z10 F2600 ; Raise the Z axis 2mm to ensure it is above the Z probe trigger height.
G90 ; Set absolute positioning mode.
G1 X225 Y225 F6000 ; Go to the center of the bed for probe point.M558 F1000 R0.2 A1 ; Set the Z-probe to fast for the first pass.
M280 P0 S10
G30 ; Perform Z probing.
M280 P0 S90
G1 H0 Z10 F1000 ; Lift the Z axis to the 5mm position.M558 F200 R0.2 A1 H10 S-1 ; Set the Z-probe to slow for the second pass, take 5 probes and yield the average.
M280 P0 S10
M280 P0 S90
G1 H0 Z10 F400 ; Lift the Z axis to the 5mm position.
M402
M558 F200 A1 ; Set the Z-probe to normal speed. -
deploy probe
M280 P0 S10
Retract probe
M280 P0 S90
@jay_s_uk
Thanks for the reply,I realise I shouldn't use them, as I didn't need them on the other printer, but its how I got it to work here
@Queevix does your BLTouch deploy and retract using
M401
andM402
@jay_s_uk
No, it doesn't. The commands appear green in the console, but no response whatsoever from the printer...
Didn't know about these commands by the way. -
@Queevix if they don't work (and your deploy and retract are correct, which they look to be) then check your wiring
Can you send M122 and M98 P"config.g" in the gcode console in DWC and copy and paste the results here?
@Phaedrux
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: URV2B-M396U-D65J0-40KMY-1H03Z-72JMX
Used output buffers: 9 of 40 (24 max)
Static ram: 103684
Dynamic ram: 111512 of which 0 recycled
Never used RAM 26516, free system stack 194 words
Tasks: NETWORK(ready,14.9%,255) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,114) MAIN(running,83.6%,426) IDLE(ready,0.0%,29) AIN(delaying,0.8%,273), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:56:07 ago, cause: power up
Last software reset at 2022-11-08 14:54, reason: User, GCodes spinning, available RAM 26516, slot 1
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
MCU revision 3, ADC conversions started 3367648, completed 3367647, timed out 0, errs 0
Step timer max interval 1079
MCU temperature: min 18.8, current 31.4, max 31.9
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 46133, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 46133, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 46133, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 46132, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 46133, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 5: not present
Driver 6: not present
Date/time: 2022-11-08 20:44:36
Slowest loop: 6.08ms; fastest: 0.13ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.5ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== CAN ===
Messages queued 30304, received 0, lost 0, boc 0
Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 16837/0/0
Tx timeouts 0,0,16836,0,0,13466 last cancelled message type 30 dest 127
=== Network ===
Slowest loop: 16.91ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address d8:bf:c0:15:0b:d5
WiFi Vcc 3.38, reset reason Power up
WiFi flash size 2097152, free heap 25536
WiFi IP address 192.168.1.34
WiFi signal strength -65dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 4 0 0 0 0 0 0 0
- WiFi -
@Phaedrux
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Temperature coefficients ignored due to invalid sensor number 2 -
@jay_s_uk
I've double- and triple checked the wiring, and am pretty confident the wires are intact and well connected to the board -
@Queevix said in BLtouch not deploying:
The BLtouch seems to respond to M280 commands, and can also home the Z axis, however, it will not deploy automatically.
Where are your deployprobe.g and retractprobe.g files located? They should be in the sys folder.
Can you upload those files here?
Since the M280 commands work but M401 and M402 don't that means something is wrong with those files.
@Phaedrux
Yes, something was wrong alright. They were only in my macros.
A profoundly stupid oversight of mine. it works as it should now. Thanks for pointing this out, I could have been looking for a really long time...
I'll get back in my lair now, a little more embarrassed then before.Thanks everyone!
Grtz,
Alexander -
