    MakerGear M2 z issue/board Z drive?
    607
    • FuseDeepundefined
      FuseDeep
      After a decade my M2 showed the known fault, a weak z drive stepper (direct threaded).
      I checked a few connections, all seemed fine, and ordered the MakerGear z stepper w in built screw thread from USA.
      Swapped out the Z stepper... And exactly the same problem so can't print.
      I need to double check the wiring proper, but if not that, then how do I check my duet board for drive failure, or, can I assign the Z to the Z/ B driver (or another axis drive) ?
      Any suggestions appreciated.
      Thanks Rich
        jay_s_uk @FuseDeep
        @FuseDeep the Z/B connect is ran off the same driver as Z/A.
        Nothing stopping you assigning Z to the E1 driver if its not in use
        FuseDeepundefined 1 Reply Last reply Reply Quote 1
        • FuseDeepundefined
          FuseDeep @jay_s_uk
          @jay_s_uk thanks. Am running an extruder and 3 axis currently.
          That would be great if there are 2 extruder outputs. Will have a look.
          • FuseDeepundefined
            FuseDeep
            This is my current config file;
            ; Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 20 2022 11:07:59 GMT+0100 (British Summer Time)
            M550 P"DUET 0.6mm HB / Son.im" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M92 X88.89 Y88.89 Z400.00 E420.00 ; set steps per mm
            M84 S30 ; Set idle timeout
            M208 X200 Y250 Z185 S0 ; set axis maxima
            M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
            M557 X15:200 Y15:195 S20 ; define mesh grid
            M307 H0 R0.227 K0.317:0.000 D10.46 E1.35 S1.00 B0
            ; enable bang-bang mode for the bed heater and set PWM limit
            M106 P0 S0 H0 T40 ; set fan 0 value. Thermostatic control is turned on
            M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
            M552 S2
            • FuseDeepundefined
              FuseDeep
              To change Z axis drive to E1/4 is this the correct change (it has been some months since I touched any of this stuff); Do i need to do anything else, other than move stepper plug to correct output on board?
              M584 X0 Y1 Z4 E3 ; set drive mapping (changed Z from 2 to drive motor 4 (E01)
              M552 S2
                jay_s_uk @FuseDeep
                @FuseDeep thats correct.
                Also add an M569 line for P4 so you can match the settings for P2.
                Then just move the connection
                FuseDeepundefined 1 Reply Last reply Reply Quote 0
                • FuseDeepundefined
                  FuseDeep @jay_s_uk
                  @jay_s_uk
                  replace w
                  M569 P4 S0 ; physical drive 2 goes forwards
                    jay_s_uk @FuseDeep
                    @FuseDeep yep
                    FuseDeepundefined 2 Replies Last reply Reply Quote 0
                    • FuseDeepundefined
                      FuseDeep @jay_s_uk
                      @jay_s_uk thanks
                      • FuseDeepundefined
                        FuseDeep @jay_s_uk
                        @jay_s_uk Please remind me how to save a config. g file, I had a specific piece of software but can't find it now!
                        And yes, I was awoken 0400 this morning by the wind and rain...
                          jay_s_uk @FuseDeep
                          @FuseDeep are you not editing it though DWC?
                          otherwise notepad or something like that
                          • FuseDeepundefined
                            FuseDeep @jay_s_uk
                            @jay_s_uk Thanks, I have notepad but can't find the G option in the drop down, is there a nack to it?
                              jay_s_uk @FuseDeep
                              @FuseDeep you can right click and open with.
                              i use notepad++ and this UDL https://github.com/ComedianTF2/RepRapFirmware-UDL-For-Notepad
                              • FuseDeepundefined
                                FuseDeep @jay_s_uk
                                @jay_s_uk yes, no problem opening it. but when wanting to save as a congig.g file I can't see the G extension option in the save as....can't remeber what I did last time?
                                  jay_s_uk @FuseDeep
                                  @FuseDeep just save? no need to save as
                                  • FuseDeepundefined
                                    FuseDeep
                                    Hmmm
                                    Have saved and checked the new config file and still have a weak as a kitten Z axis.
                                    Please note, the set up worked perfectly for many months then suddenly became weak.
                                    I replaced the entire Z stepper direct from makergear (the old z steppers were known to fail after a decade) and have checked continuity on all 4 stepper cables, all good.
                                    This is now a new z stepper and re assigned as above, but with exact same weakness issue!!!!!!
                                    What is the max current I can set for the duet wifi board for a stepper drive channel, maybe the z set up is stiffer and needs more power (only thing that makes sense)?
                                    Cheers Richard
                                    • FuseDeepundefined
                                      FuseDeep
                                      I canged the z/E1 output MA from 800 to 1600 and it is much happier (0nly cost me 100gbp to not fix this!).
                                      Seems it needed more current. will relube and see how she runs!
