    Cant connect DM542t to Duet2
    295
    • Scara_Armundefined
      Scara_Arm
      i want to connect a Nema23 with external power supply and a dm542t as Driver to my Duet2 but the steppermotor spins only in one direction. If i test the Motor with forward and backward motion the motor turns forward and when it sould turn to the backward direction, it is also going forward but a little bit slower.
      Can anyone help me with this problem?
      If i connect a nema 17 direct to the Duet2 it works normally.
      Maybe some grounding issue?
      The wiring looks like this:
      wiring.pdf
      DM542T_datasheet.pdf
      23HS30-2804S_datasheet.pdf
      config (2).g
        jay_s_uk @Scara_Arm
        @Nicogr you can't connect it like you have.
        you'll need to use something like this https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board
        Scara_Armundefined 1 Reply Last reply Reply Quote 0
          Scara_Arm @jay_s_uk
          @jay_s_uk Thanks a lot for your reply, i will test it soon.
            Scara_Arm
            Do you Know if the Wiring with the expansion board is correct?wiring1.pdf
            I cant move the motor
              jay_s_uk @Scara_Arm
              @Nicogr the second page looks correct.
              Can you post your config?
                Scara_Arm
                Thank you so much for your lightning fast response.
                My config looks like this:
                config (4).g
                to Test the motor I run this macro but nothing happens
                ; Test motors
                M117 TEST E1
                M584 X5
                G91
                G92 X0 Y0 Z0
                ;M201 Y1000
                G1 H2 X50 F5000
                G1 H2 X-50 7000
                G1 H2 X50 F10000
                G1 H2 X-50 2000
                M584 X0 Y1 Z2 E3:5 U4
                  jay_s_uk @Scara_Arm
                  @Nicogr wheres you M569 setting timings etc?
                    Scara_Arm
                    i have set the M669 timing only on the Expansion Board Driver D5
                    M569 P5 S1 R0 T2.5:2.5:5:5
                      Scara_Arm
                      The Motor is spinning. I had to swap the ENA+ and ENA- cable
                        dc42 administrators @Scara_Arm
                        @Scara_Arm when using drivers with single-ended opto isolated inputs, it is better to use the alternate wiring scheme between the expansion breakout board and the external driver. See https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board#signalling-voltages.
