    Reset Machine from PanelDue
    PanelDue
    568
    • oozeBotundefined
      oozeBot
      When the machine is printing and the user presses the emergency stop button on the PanelDue, the machine goes into a halted state. However, there is no way we have deciphered to reset the machine from the PanelDue- the user must go to DWC where they are presented with a prompt to reset the machine. This functionality really needs to be added to the PanelDue instead of forcing the user to login through a web browser.
        Strange. What firmware versions? I use the estop button frequently and don't have to use DWC to reset.
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @Phaedrux
          @Phaedrux 3.4.4, but it's not new as we've seen it in previous versions. I'll try to take some screenshots of the PanelDue in a Halted state the next time it happens. Perhaps it has to do with our use of a SBC? Not sure why that would matter, but I know there are differences..
            Yes it would be good to know the details specific to your setups.
            • Alex.crundefined
              Alex.cr
              I can report a similar experience. After pressing the emergency stop button the system may hang and require the reset button to be pressed. My experience is not with a panel due but it is a similar problem. Firmware 3.4.4.
              This is on a 6HC+1LC+3HC+1HCL+1HCL with SBC.
              Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
              • oozeBotundefined
                oozeBot @Phaedrux
                @Phaedrux It happens when pressing e-stop on the PanelDue when homing the machine.
                  Is this with your customized version of Paneldue firmware?
                  • oozeBotundefined
                    oozeBot @Phaedrux
                    @Phaedrux Fair question, but no- that was put on hold after 3.3. This is happening with 3.4.1
                      Phaedrux Moderator @oozeBot
                      @oozeBot Do you have a standalone config to test with? If we can narrow it down to the SBC that would give us more to go on.
                      • oozeBotundefined
                        oozeBot @Phaedrux
                        @Phaedrux Unfortunately, we do not - all our machines utilize a SBC. Hopefully someone with a 6HC and PanelDue in stand-alone mode can try to recreate this issue.
                          I can try that tomorrow.
                          • chrishammundefined
                            chrishamm administrators @oozeBot
                            @oozeBot I am sorry but I cannot reproduce this problem with firmware 3.4.4 in SBC mode and PD firmware 3.4.1. Even when a homing macro is being executed, I can still press STOP and RRF restarts as expected. Are you using a custom plugin anywhere? Try disabling all third-party plugins and check if the problem persists.
                            Duet software engineer
                            • oozeBotundefined
                              oozeBot @chrishamm
                              @chrishamm Sorry for the delay in our response on this- we let it slip. This primarily occurs when the machine is homing and the e-stop is pressed. It is easily repeatable on our machines running 3.4.4 with a SBC and the stock PanelDue firmware 3.4.1.
                              We have some time to further research, but so far nothing in our homing scripts has been identified as the issue. To reproduce, all we have to do is press the e-stop button while the gantry is homing in X or Y direction (haven't tested Z yet). Thanks
