    Printer does not recognize bed size
    Using Duet Controllers
    405
    • axiomundefined
      axiom @dc42
      Oh, there was an error copying the gcode:
      Here are the lines:
      M208 X90 Y170 Z0 S1 ; set axis minima
      M208 X660 Y910 Z1200 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      ;M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
      M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P1000 X-20 Y80 Z0.492 ; set Z probe trigger value, offset and trigger height
      M557 X125:710Y50:810S100 ; define mesh grid
      • axiomundefined
        axiom @dc42
        Here is the full code again:
        generated by RepRapFirmware Configuration Tool v3.3.12 on Wed Aug 24 2022 12:56:11 GMT+0200 (Mitteleuropäische Sommerzeit)
        M550 P"DUKA1300" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P1 S1 ; physical drive 0 goes forwards
        M569 P3 S0 ; physical drive 3 goes forwards extruder1
        M569 P4 S1 ; physical drive 4 goes forwards
        M584 X0 Y1 Z2 E3:4 ; set drive mapping
        ;M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
        M92 X80.00 Y80.00 Z640.00 E320.20:320.51 ; set steps per mm
        M566 X900.00 Y900.00 Z120.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z1200.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
        M906 X1800 Y1800 Z2000 E1800:1800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M308 S0 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp
        M950 H0 C"e1heat" T0 ; create nozzle heater output on e1heat and map it to sensor 0
        M307 H0 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
        M143 H0 S250 ; set temperature limit for heater 0 to 250C
        M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
        M143 H1 S250 ; set temperature limit for heater 1 to 250C
        M308 S2 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin bedtemp
        M950 H2 C"bedheat" T2 ; create bed heater output on bedheat and map it to sensor 2
        M307 H2 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H2 ; map heated bed to heater 2
        M143 H2 S280 ; set temperature limit for heater 2 to 280C
        ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
        ;M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
        ;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
        ;M563 P0 D0 H0 F0 ; define tool 0
        ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
        ;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
        M563 P1 D1 H1 F1 ; define tool 1
        G10 P1 X45 Y45 Z0 ; set tool 1 axis offsets
          Can you post your homing files? Perhaps you have something strange going on in there.
          axiomundefined 1 Reply Last reply Reply Quote 0
          • axiomundefined
            axiom @Phaedrux
            @Phaedrux
            Here are all 4 files:
            home all
            Home x
            home y
            and home z
            I'm curious if you can discover something bad!
            Many greetings,
            Don
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.3.12 on Wed Aug 24 2022 12:56:11 GMT+0200 (Mitteleuropäische Sommerzeit)
            G91 ; relative positioning
            G1 H1 X-580 Y-760 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X10 Y10 F1800 ; go back a few mm
            G1 H1 X-580 Y-760 F800 ; move slowly to X and Y axis endstops once more (second pass)
            ;G1 H1 Z705 F360 ; move Z up stopping at the endstop
            G90
            G1 X10 Y10 F2400
            G30
            G90 ; absolute positioning
            ;G92 Z700 ; set Z position to axis maximum (you may want to adjust this)
            G1 Z5 F100 ; lift Z relative to current position
            ; homex.g
            ; called to home the X axis
            G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X5 F6000 ; go back a few mm
            G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-5 F6000 ; lower Z again
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y-50 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y5 F6000 ; go back a few mm
            G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass)
            ; homez.g
            ; called to home the Z axis
            G1 X5 Y85 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G90 ; absolute positioning
              Nothing out of the ordinary there. What does your build platter image look like in Cura? I believe it blanks out areas it thinks it cannot reach.
              Are you sure belts or pulleys are not slipping or motors skipping steps?
              • axiomundefined
                axiom @Phaedrux
                @Phaedrux
                In the code I entered the position of the nozzle (distance nozzle to end stop) as the starting position: 50 and 115mm:
                M208 X50 Y115 Z0 S1 ; set axis minima and the same in the slicer settings:
                Is there a misconception here?
                  Phaedrux Moderator @axiom
                  @axiom said in Printer does not recognize bed size:
                  Yes I think so, For those fields you could probably leave them as 0 and see if that improves your situation.
                    deckingman @Phaedrux
                    @Phaedrux said in Printer does not recognize bed size:
                    I think so too. From a firmware perspective, the axes minima are relative to the position of the end stops. But the slicer has no concept of end stop switches, let alone their positions relative to the build surface. So I think the slicer axes min should be zero and the max should be whatever the travel length is. Otherwise one would be doing a double compensation.
                      My German is a little rusty, so I had to open Cura to see the English. The Druckkopfeinstellungen or Printhead Settings tell Cura the general size of your print head, so that if you are printing multiple objects consecutively, it will lay them out to avoid the print head hitting the existing objects on the bed.
                      At 115 and 50 mm you've told it your print head is extremely large.
                      3f3fd2a6-3451-4809-9a02-760d1f07f1bf-Screen Shot 2022-11-13 at 10.39.50 AM.png Screen Shot 2022-11-13 at 10.39.50 AM.png
                      https://all3dp.com/2/cura-printhead-settings-simply-explained/
                      • axiomundefined
                        axiom @Phaedrux
                        @Phaedrux
                        Hello, I was on a business trip for 1 week and was only able to try your tips now.
                        In fact, after I set xmin and ymin to 0 in Cura, the printer printed the entire circle...you guessed right! However, the start position in the control panel changes. I suspect something is still wrong in the Cura startup code. Can you give me a starting code for Cura that is as simple as possible? Here again the start and end code from Cura, which I took over apart from the speeds...
                        M220 S100 ;Reset Feedrate
                        M221 S100 ;Reset Flowrate
                        G28 ;Home
                        G92 E0 ;Reset Extruder
                        G1 Z2.0 F3000 ;Move Z Axis up
                        G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                        G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                        G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                        G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                        • infiniteloopundefined
                          infiniteloop @axiom
                          @axiom Moin axiom,
                          As „Start G-Code“, this here should be sufficient:
                          G28 ; Home
                          M83 ; set extruder to relative mode
                          G92 E0 ; reset extruder’s relative position to 0
                          Most other instructions to prepare the printer for a job should better be written into the start.g macro on SD card.
                          I don’t quite understand this here:
                          With „control panel“, do you mean DWC, PanelDue or something else?
                          Generally, it’s quite simple. In your Druckeinstellungen, you told Cura about the size of your printer and the origin of the coordinate system: „Ausgang in Mitte“ (BTW: strange translation of ‚center origin‘) is deselected, so the origin should be front left. At least, that’s what Cura assumes.
                          Now, depending on where you place your print object in Cura, this should correspond to its placement on your print bed … as far as you defined the printer’s X/Y origin to be at the front left. If the position doesn’t match, there’s something wrong with either the size values in the Druckereinstellungen of Cura or with the axes-settings of your printer.
