BLTouch 3.1 wiring on Duet 3
This is probably a pretty obvious thing, but I've seen a few wiring diagrams and forum posts contradicting each other so I figured I might as well ask here.
To start, here is a very simple wiring diagram I found showing what the wires are. There are two ground wires, so should I just splice both into one wire and connect it to the GND pin of the Duet 3's IO connector?
Second, does +5V (red wire) go to 5V_EXT? From there I assume the yellow wire goes to input (or io4.in in this case), and white goes to output (or io4.out) but I'm not certain.
This post is deleted! -
@jay_s_uk Just to be certain, was I right about red going to 5V_EXT?
@Tortuga yes
undefined Tortuga marked this topic as a question
undefined Tortuga has marked this topic as solved
