    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    5.7k
    • R4ffersundefined
      R4ffers
      Hi, I've just been looking at this as I'd like to shutdown my SBC. How do you actually go about doing it? Thanks in advance.
      Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
      Falcounetundefined 1 Reply Last reply Reply Quote 0
      • Falcounetundefined
        Falcounet @R4ffers
        @r4ffers shutdown requires root privileges and thus isn't possible to use that plugin without hacks as the plugin runs as dsf user.
        It is recommended to use the DuetPiManagementPlugin for shutdown.
        R4ffersundefined 1 Reply Last reply Reply Quote 1
        • R4ffersundefined
          R4ffers @Falcounet
          @falcounet thankyou
          • E3D-TCWundefined
            E3D-TCW
            Hello @Falcounet
            I've tried giving this a run and during install we're coming up with the error:
            Any suggestions how to resolve this? We tried installing dsf-python directly via pip install, but it did not seem to resolve it.
              Falcounet @E3D-TCW
              @e3d-tcw You need to use pip3 as it is a Python3 module. Install python3-pip package if pip3 isn't available on your system.
              What DSF version do you use ? This was normally fixed in 3.4
              • CrazyCreatorundefined
                CrazyCreator
                I like this plugin. But version 0.1 is not that advanced yet. Are you ( @Falcounet ) still developing it?
                http://www.crazycreatorcube.com
                  Falcounet @CrazyCreator
                  @CrazyCreator No real plan so far. Can you be more explicit about what you find it "not that advanced yet" ?
                    CrazyCreator
                    @Falcounet said in ExecOnMcode v0.1:
                    sorry ... that was the bad google translator. The question was, are you still programming or is it finished?
                      @CrazyCreator I'm not still programming it for now but if you have improvement or feature requests, I can consider them.
                        CrazyCreator
                        That sounds good... will try it out in the next few days.
                          CrazyCreator
                          @Falcounet
                          Raspi 4 with bullseye
                          Falcounetundefined 2 Replies Last reply Reply Quote 0
                            @CrazyCreator I think it's an issue with AppArmor. Do you use the DuetPi image for the SBC ?
                            CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                              CrazyCreator @Falcounet
                              @Falcounet
                              No ... i make all clean today
                              Raspi bullseye from raspi
                                @CrazyCreator Then try installing apparmor and try again
                                  @Falcounet
                                  I don't just have to install it. This AppArmor still needs to be configured.
                                  Do you know what I have to do exactly? I'm not the Linux expert
                                    @CrazyCreator DSF configure it for you. Config files are stored into /etc/apparmor.d/.
                                    You should get /etc/apparmor.d/dsf.ExecOnMcode after the plugin installation.
                                    Make sure you also have installed duetpluginservice
                                      CrazyCreator
                                      @Falcounet
                                      I don't have this file.
                                      But the install from the plugin is not complete, so i think the file is not created.
                                        @Falcounet
                                        in screen you see the pluginservice is running
                                        apparmor freshly installed
                                        • chrishammundefined
                                          chrishamm administrators @CrazyCreator
                                          @CrazyCreator I don't think this is an AppArmor issue, it's more likely that the permissions in your DWC directory are off for some reason. Try reinstalling duetwebcontrol and if that doesn't help, run sudo chown -R dsf.dsf /opt/dsf to fix the ownerships again. If that doesn't help, try to delete the file as root (sudo rm /opt/dsf/sd/www/js/...) and install the plugin once more.
                                          Duet software engineer
                                            CrazyCreator @chrishamm
                                            @chrishamm
                                            How can i reinstall or install DuetWebControl?
                                            I don't find any tutorial 😞
                                            /Update
                                            I upload this Zip-File: https://github.com/Duet3D/DuetWebControl/releases
                                            and hope this is what you mean, with reinstall DuetWebControl?
                                            i deleted all files with ExecOnMcode in name and try to reinstall the plugin
                                            ... But ... The same error 😞
