    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    6.3k
      T3P3Tony administrators @T3P3Tony
      @Falcounet Like the example you have for running a python scrip and getting information baout the state of the SBC back:
      • R4ffersundefined
        R4ffers
        Hi, I've just been looking at this as I'd like to shutdown my SBC. How do you actually go about doing it? Thanks in advance.
        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        Falcounetundefined 1 Reply Last reply Reply Quote 0
        • Falcounetundefined
          Falcounet @R4ffers
          @r4ffers shutdown requires root privileges and thus isn't possible to use that plugin without hacks as the plugin runs as dsf user.
          It is recommended to use the DuetPiManagementPlugin for shutdown.
          R4ffersundefined 1 Reply Last reply Reply Quote 1
          • R4ffersundefined
            R4ffers @Falcounet
            @falcounet thankyou
            • E3D-TCWundefined
              E3D-TCW
              Hello @Falcounet
              I've tried giving this a run and during install we're coming up with the error:
              Any suggestions how to resolve this? We tried installing dsf-python directly via pip install, but it did not seem to resolve it.
                Falcounet @E3D-TCW
                @e3d-tcw You need to use pip3 as it is a Python3 module. Install python3-pip package if pip3 isn't available on your system.
                What DSF version do you use ? This was normally fixed in 3.4
                • CrazyCreatorundefined
                  CrazyCreator
                  I like this plugin. But version 0.1 is not that advanced yet. Are you ( @Falcounet ) still developing it?
                  http://www.crazycreatorcube.com
                    Falcounet @CrazyCreator
                    @CrazyCreator No real plan so far. Can you be more explicit about what you find it "not that advanced yet" ?
                      CrazyCreator
                      @Falcounet said in ExecOnMcode v0.1:
                      sorry ... that was the bad google translator. The question was, are you still programming or is it finished?
                        @CrazyCreator I'm not still programming it for now but if you have improvement or feature requests, I can consider them.
                          CrazyCreator
                          That sounds good... will try it out in the next few days.
                            CrazyCreator
                            @Falcounet
                            Raspi 4 with bullseye
                            Falcounetundefined 2 Replies Last reply Reply Quote 0
                              @CrazyCreator I think it's an issue with AppArmor. Do you use the DuetPi image for the SBC ?
                              CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                                CrazyCreator @Falcounet
                                @Falcounet
                                No ... i make all clean today
                                Raspi bullseye from raspi
                                  @CrazyCreator Then try installing apparmor and try again
                                    @Falcounet
                                    I don't just have to install it. This AppArmor still needs to be configured.
                                    Do you know what I have to do exactly? I'm not the Linux expert
                                      @CrazyCreator DSF configure it for you. Config files are stored into /etc/apparmor.d/.
                                      You should get /etc/apparmor.d/dsf.ExecOnMcode after the plugin installation.
                                      Make sure you also have installed duetpluginservice
                                        CrazyCreator
                                        @Falcounet
                                        I don't have this file.
                                        But the install from the plugin is not complete, so i think the file is not created.
                                          @Falcounet
                                          in screen you see the pluginservice is running
                                          apparmor freshly installed
                                          • chrishammundefined
                                            chrishamm administrators @CrazyCreator
                                            @CrazyCreator I don't think this is an AppArmor issue, it's more likely that the permissions in your DWC directory are off for some reason. Try reinstalling duetwebcontrol and if that doesn't help, run sudo chown -R dsf.dsf /opt/dsf to fix the ownerships again. If that doesn't help, try to delete the file as root (sudo rm /opt/dsf/sd/www/js/...) and install the plugin once more.
                                            Duet software engineer
