    Milling motor control - Duet3/PWM Converter
    CNC
    1.2k
      dc42 administrators @Nightowl
      @Nightowl see the section on configuring spindles at https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-or-gpioservo-pin for an explanation of the suggestion by @jay_s_uk.
      Nightowlundefined 1 Reply Last reply Reply Quote 0
      • Nightowlundefined
        Nightowl @jay_s_uk
        I see! Thank you, @jay_s_uk
        Of course, that makes sense. It's the same idea as for the Makita (apart from the pins) so if I used this, to configure the motor:
        ; Spindle configuration
        M950 R0 C"vfd+out7" L0:25000 Q1000	; create spindle with index 0
        M563 P0 S"Sorotec" R0			; create tool 0 with spindle 0 and name it "Sorotec"
        T0					; select tool 0
        ...that would get me to where I want to be, whilst keeping the relay on the existing pins.
        That's brilliant, thank you so much!
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        • Nightowlundefined
          Nightowl @dc42
          Thanks, @dc42, I'll check it out 👍
          • Nightowlundefined
            Nightowl
            Just out of curiosity, how do I find out what the Q setting should be?
            Is this information relative to the PWM controller, which is advertised as being 1kHz to 3kHz?
            Thanks
            jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @Nightowl
              @Nightowl its more relative to VFD
                @Nightowl said in Milling motor control - Duet3/PWM Converter:
                Yes, use between 1000 and 3000.
                • Nightowlundefined
                  Nightowl
                  Some progress!
                  Using the code below, I can now start/stop the motor with M3 Sn and M5 respectively, but I can't change the speed: it is constant at 4,000RPM, which suggests to me that the voltage required to change the speed isn't there. Possibly a fault with the PWM converter?
                  Here's the code:
                  ; Milling motor and relay configuration
                  M950 R0 C"vfd+out7" L0:25000 Q1000	; enable router relay on out7
                  M563 P0 S"Sorotec" R0 			; assign spindle 0 to tool 0 and name it Sorotec
                  T0					; select tool 0
                  M5					; ensure motor is turned off
                    jay_s_uk @Nightowl
                    @Nightowl have you adjusted the variable resistor on the top? have you set the VFD up for PWM control? I had to change some of the registers on my VFD to use PWM rather than RS485
                    • Nightowlundefined
                      Nightowl @jay_s_uk
                      @jay_s_uk
                      If you mean this one (arrowed), no I haven't:
                      I'm not using a VFD, though. Just following the instructions from the Ooznest website, the M950 guide and this document.
                      I've just noticed point 2 indicates the "5V/24V PWM input signal level option" should be set to 5V, so I'll need to check that...
                      • Nightowlundefined
                        Nightowl
                        One thing I've checked - very carefully, is the voltage across the 12V and GND connectors, adjacent to the 5V PWM connectors, on the Duet control board, and they're only providing 6V.
                        Also, the voltage across terminals GND and AO on the PWM board doesn't change when I adjust the motor speed (without the cable connected to the motor, so there's no load) from M3 S1000 to M3 S25000
                        That can't be right, surely?
                        Also, the jumper on the PWM board is set to 5V.
                          jay_s_uk @Nightowl
                          @Nightowl can you just confirm where the PWM is wired to on the duet board?
                          • Nightowlundefined
                            Nightowl @jay_s_uk
                            @jay_s_uk
                            Certainly. The pins on the PWM board are connected to the Out9 VFD\Laser\Servo Drive header:
                            Port 1 (PWM in -ve) to 5V_Ext
                            Port 2 (PWM in +ve) to Out9
                            Port 3 (Power Supply 12-30V) to 12V
                            Port 4 (Power Supply GND) to GND
                            Port 5 (Voltage Out GND) to GND
                            Port 6 (Voltage Out +ve AO) to the motor plug
                            There is a loop between Ports 4 and 5, and this is also connected to the GND wire on the motor plug.
                            The third wire from the motor plug is connected to the PSU 24V +ve of the PSU.
                              jay_s_uk @Nightowl
                              @Nightowl thats where you'll be going wrong then as the header you're using is always on (i think). change numbers 3 and 4. it'll also probably explain why its always on at power up without that relay. i would just wire them to an out connector and switch your M950 accordingly.
                              • Nightowlundefined
                                Nightowl @jay_s_uk
                                @jay_s_uk
                                Forgive me, but aren't they 'just' the power supply to the converter? The switch operating the relay (to stop it the motor spinning) is on out7.
                                Also @dc42 posted earlier (I missed it, sorry) that I should connect PWM in -ve to GND (not 5V-Ext)
                                jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                                  jay_s_uk @Nightowl
                                  @Nightowl ah bugger, you're right. i looked at the diagram wrong
                                  • Nightowlundefined
                                    Nightowl
                                    All sorted, thank you gentlemen!
                                    It was in fact down to way the PWM converter was connected to the Duet board.
                                    I'll amend my diagram and publish it here (and delete the earlier one!
                                    • dc42undefined dc42 marked this topic as a question
                                    • dc42undefined dc42 has marked this topic as solved
                                    • Nightowlundefined
                                      Nightowl
                                      Here's the updated connection diagram:
                                      ...and this is the code from the config.g file:
                                      M950 R0 C"vfd+out7" L4000:25000 Q1000	; enable router relay on out7
                                      M563 P0 S"St George" R0 		; assign spindle 0 to tool 0 and name it St George
                                      T0					; select tool 0
                                      Note: I have used this relay to provide mains power to the milling motor, which is activated from Out7 in this case. I guess any Out could be used, but the code would need to be changed accordingly.
                                      Many thanks to @dc42 and @jay_s_uk for helping me resolve this, and I hope this diagram will be of use to others.
                                      • Nightowlundefined Nightowl referenced this topic
