Duet 3 Mini 5+ Firmware with SBC
@Basil what are you exactly stuck on?
@Basil said in Duet 3 Mini 5+ Firmware with SBC:
Configuration with endstops switches failed
How did they fail?
I would suggest getting the endstop switches working first. It would likely be a lot easier than tuning sensorless homing.
Please share your config.g and homing files. Also send M122 and M98 P"config.g" in the gcode console tab in DWC and share the results here.
The endstop documentation is here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_endstops
@Phaedrux
Thanks for your prompt reply
Now I am in config with sensorless mode. I will revert to switches homing mode.
I will send you as soon the new configuration is uploaded and all data submitted.
Sys files has been generated with https://configtool.reprapfirmware.org/ -
I think you need to do a
sudo apt update && sudo apt upgrade
on your Pi to get your firmware and software up to date and in sync.After that please send M122 again and post the results.
Sincerely I have now to investigate this new issue and how to perform the Pi update.
In this moment I'm really don't now how to do
I will try to find out, if will be, in the Duet Documentation for this update, in this situation, when the Pi is connected with Duet Board
The Raspberry Py image has been setup from Duet documentation, Duet site, dedicated for Duet 3. there is another link for an update image
Update as is instruct successfully upload.
Below new M122
dac932b5-2461-46ec-ab99-923401e69bff-console.txt -
It looks like the Pi side upgraded correctly, but the Duet board firmware itself did not.
I suggest you do a manual update as described here. You'll need to connect the board to your computer via USB and copy a file onto it. That should get you back in sync.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
And the 3.4.5 firmware file for the mini5 is here: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet3Firmware_Mini5plus.uf2
@Phaedrux
Update completed.
M122 again? -
@Basil
Duet board has no any sd card conected -
@Phaedrux
Dear Phaedrux,
Many thanks for your efforts to help me. Silence and quiet means also an answer.
Conclusion:- following your recommendation, my issues has not been solved and my printer is not able to simply move axis for homing. Even if I strictly/accordingly follow the duet documentation.
All my efforts, time & expenses, patients and confidences to duet company, as consequently, has been lost.
Please don’t try, now and ever, to find out for any other explanation or advice regarding my issues. Leave it as it is.
Howether, board has been removed from my build printer and another new one board, from anywhere, not from duet, will be take in consideration to build for my future printer. This one, duet 3mini 5 plus v1.02 will be sent back to your genuine seller on my own expenses.
I am not asking/claim for any payment/refund for the board in discussion. I make it a gift, for study my board, for your research company department.
I’m very disappointed. Forum will not be accessed from now. Sorry. All reaction from duet to be sent, if you want, to me, by email.
A complete information will be sent to the duet company sales department.
Regards
Well we do have to sleep occasionally.
When you say update complete, did you verify that the firmware was updated this time with M122?
@Basil
Duet board has no any sd card conectedWhat does this mean? Is an SD card inserted into the slot on the board?
