    Voron 2.4 3MB6 §EB config issues.
    1.4k
    • Titus A Duxassundefined
      Titus A Duxass @jay_s_uk
      @jay_s_uk My config.g now looks like this.
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Dec 18 2022 17:39:32 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"voron" ; set printer name
      M669 K1 ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M584 X1.1 Y1.2 Z0.1:0.5:0.3:0.4 E1.0 ; set drive mapping
      M569 P1.1 S0 ; A motor goes forwards
      M569 P1.2 S0 ; B motor goes forwards
      M569 P0.1 S1 ; FL goes forwards
      M569 P0.5 S0 ; RL goes backwards
      M569 P0.3 S0 ; RR goes forwards
      M569 P0.4 S1 ; FR goes backwards
      M569 P1.0 S0 ; Extruder goes backwards
      M350 Z16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
      M92 X320.00 Y320.00 Z400.00 E436.54 ; set steps per mm
      M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S10 ; Set idle timeout
      M208 X290 Y290 Z250 S0 ; set axis maxima
      M574 X2 S1 P"^io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^io1.in
      M574 Y2 S1 P"^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^io2.in
      M558 P5 C"^io3.in" H5 F1200:120 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X40:260 Y40:260 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"Revo" D0 H1 F0:1 ; define tool 0
      T0 ; select first tool
        jay_s_uk @Titus A Duxass
        @Titus-A-Duxass you need to change the X and Y steps too from 320 to 80
        Titus A Duxassundefined 1 Reply Last reply Reply Quote 0
          @jay_s_uk Done.
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            @Titus-A-Duxass have a go at homing and see how that performs
              @jay_s_uk
              Perfekt!!
              I positioned it at approx. 150 for all three axes and all homed with out an issue.
                @Titus-A-Duxass great news. if you need anything else just ask
                Titus A Duxassundefined 2 Replies Last reply Reply Quote 0
                  @jay_s_uk
                  Once again thank you for your invaluable assistance.
                  I owe a beer/tea/coffeee.
                    @jay_s_uk
                    I'm back, just a quick question.
                    After I have homed all, all motors are powered (you can just hear them buzzing) is this normal?
                      @Titus-A-Duxass yes, you can get that when they're in spreadcycle.
                      if its something you want to reduce, then you could switch them over to stealthchop.
                      you either want to switch over at very low speeds or always run them in stealthchop.
                      you would do this by adding D3 VX to each M569 line, with X being something like 4000 for low speed switch over or 1 for always stealthchop.
                      If you can live with the sound, stick to spreadcycle.
                        @jay_s_uk
                        Thanks, I leave it as is for the moment until I become more confident.
                        This thing flies, just gone from X200 Y0 to X20 Y250 in less than a second - scary fast.
