    Voron 2.4 3MB6 §EB config issues.
    1.4k
    • Titus A Duxassundefined
      Titus A Duxass @jay_s_uk
      @jay_s_uk said in Voron 2.4 3MB6 §EB config issues.:
      F120
      your probe speed is to move at 2mm/s. thats ok for a second pass but your first pass probably wants to be quicker. you can set a first and second probing speed like this F1200:120
      Sorry but you've lost me there.
      Which file is this in and what am I editing.
      I'm going to need a beer after this!
        jay_s_uk @Titus A Duxass
        @Titus-A-Duxass the M558 F value in config.g
        Titus A Duxassundefined 1 Reply Last reply Reply Quote 0
          @Titus-A-Duxass you'll also have to divide your steps per mm by 4
          for the probe point you'd move to X150 Y125
          Again, you've lost me. Unfortunately I have zero knowledge of G code and configuration. I have been following a youtube video to set this lot up.
            @jay_s_uk
            Okay, so F1200 is the first pass speed and 120 the second pass speed.
            my line now looks like this:
            M558 P5 C"^io3.in" H5 F1200:120 T6000
              @Titus-A-Duxass
              these lines
              M350 Z64 I0 ; configure microstepping without interpolation
              M350 X64 Y64 E64 I1 ; configure microstepping with interpolation
              M92 X320.00 Y320.00 Z400.00 E1746.16 ; set steps per mm
              change to
              M350 Z16 I0 ; configure microstepping without interpolation
              M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00 E436.54 ; set steps per mm
              your Z steps were wrong for X64 which is probably why your moves were so slow and it was erroring out after 100mm (as the machine had thought you'd moved 400mm which is greater than your Z height)
              Titus A Duxassundefined 2 Replies Last reply Reply Quote 0
                This post is deleted!
                  @Titus-A-Duxass because we're setting x16 rather than x64, so the values need to be dividing by 4 as we're using 4 times less microsteps
                      @jay_s_uk Okay, I think I understand. I need to do a bit of reading about microsteps.
                        @jay_s_uk My config.g now looks like this.
                        ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
                        ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Dec 18 2022 17:39:32 GMT+0100 (Mitteleuropäische Normalzeit)
                        M550 P"voron" ; set printer name
                        M669 K1 ; select CoreXY mode
                        ; Wait a moment for the CAN expansion boards to start
                        G4 S2
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M584 X1.1 Y1.2 Z0.1:0.5:0.3:0.4 E1.0 ; set drive mapping
                        M569 P1.1 S0 ; A motor goes forwards
                        M569 P1.2 S0 ; B motor goes forwards
                        M569 P0.1 S1 ; FL goes forwards
                        M569 P0.5 S0 ; RL goes backwards
                        M569 P0.3 S0 ; RR goes forwards
                        M569 P0.4 S1 ; FR goes backwards
                        M569 P1.0 S0 ; Extruder goes backwards
                        M92 X320.00 Y320.00 Z400.00 E436.54 ; set steps per mm
                        M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                        M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2)
                        M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S10 ; Set idle timeout
                        M208 X290 Y290 Z250 S0 ; set axis maxima
                        M574 X2 S1 P"^io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^io1.in
                        M574 Y2 S1 P"^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^io2.in
                        M558 P5 C"^io3.in" H5 F1200:120 T6000 ; set Z probe type to switch and the dive height + speeds
                        G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
                        M557 X40:260 Y40:260 S20 ; define mesh grid
                        M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
                        M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                        M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                        M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                        M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                        M563 P0 S"Revo" D0 H1 F0:1 ; define tool 0
                        T0 ; select first tool
                          @Titus-A-Duxass you need to change the X and Y steps too from 320 to 80
                            @jay_s_uk Done.
                            jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                              @Titus-A-Duxass have a go at homing and see how that performs
                                @jay_s_uk
                                Perfekt!!
                                I positioned it at approx. 150 for all three axes and all homed with out an issue.
                                  @Titus-A-Duxass great news. if you need anything else just ask
                                    @jay_s_uk
                                    Once again thank you for your invaluable assistance.
                                    I owe a beer/tea/coffeee.
                                      @jay_s_uk
                                      I'm back, just a quick question.
                                      After I have homed all, all motors are powered (you can just hear them buzzing) is this normal?
                                        @Titus-A-Duxass yes, you can get that when they're in spreadcycle.
                                        if its something you want to reduce, then you could switch them over to stealthchop.
                                        you either want to switch over at very low speeds or always run them in stealthchop.
                                        you would do this by adding D3 VX to each M569 line, with X being something like 4000 for low speed switch over or 1 for always stealthchop.
                                        If you can live with the sound, stick to spreadcycle.
                                          @jay_s_uk
                                          Thanks, I leave it as is for the moment until I become more confident.
                                          This thing flies, just gone from X200 Y0 to X20 Y250 in less than a second - scary fast.
