    finding DWC with safari browser
    CNC
    • baird1faundefined
      baird1fa
      Hello everyone. I'm using a duet 2 for a CNC router control board and I like to use either my phone or a tablet as a pendant control for it. The issue I'm having is finding the DWC interface with my phone or my tablets. I will have to check the network router for the IP it assigned then use that IP address in the browser on my phone or tablet. I don't have a network router that I can configure so I cannot assign the CNC a static IP. Google chrome and other PC web browsers seem to be able to search the local network by name to find the CNC, but I can't seem to get that to work on the phone or table.
        droftarts administrators @baird1fa
        @baird1fa If you have given the Duet a name, you should be able to connect over ethernet using mdns, on devices that support mdns, which is most nowadays. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#a-note-about-mdns-local-network-discovery
        What phone and tablet are you using? You said Safari, so I assume iPhone and iPad, which should support mdns.
        baird1faundefined 1 Reply Last reply Reply Quote 1
        • baird1faundefined
          baird1fa @droftarts
          @droftarts Thank you for pointing me to that document. on a computer I can simply type cncrouter/ and it will find it.
            @baird1fa on tablet/phone, try:
            http://cncrouter.local/
