3.5 beta1 print not starting
Beta Firmware
352
    Touchthebitum
    Hello
    After 3.5b1 update, it hangs after home process and print doesn't start...
    How to downgrade please ?
    Thanks
    Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
    BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
    undefined 1 Reply Last reply 1 Jan 2023, 18:01 Reply Quote 0
      dc42 administrators @Touchthebitum
      @Touchthebitum does your home process include using G32 to perform true bed levelling? If so, see https://forum.duet3d.com/post/303514.
      undefined 1 Reply Last reply 1 Jan 2023, 18:47 Reply Quote 0
        Touchthebitum @dc42
        @dc42 No, the problem stands when I run a print. Home is ok and then it freezes. PanelDue indicates printing.... I tried your update but it doesn't work.
        undefined 1 Reply Last reply 1 Jan 2023, 18:52 Reply Quote 0
          @Touchthebitum to clarify: are you saying that your homing process does not run G32? The G32 bug did not always cause an immediate reset.
          undefined 1 Reply Last reply 1 Jan 2023, 18:56 Reply Quote 0
            Touchthebitum @dc42
            @dc42 No, my homing process doesn't run G32.
            undefined 1 Reply Last reply 1 Jan 2023, 18:57 Reply Quote 0
              @Touchthebitum thanks. When the machines hangs while trying to start a print, are you able to send M122 and get a report back?
              undefined 1 Reply Last reply 1 Jan 2023, 19:01 Reply Quote 0
                Touchthebitum @dc42
                @dc42 console.txt
                undefined 1 Reply Last reply 1 Jan 2023, 19:41 Reply Quote 0
                  The instructions for rolling the firmware back were linked to in my original post announcing the new release. Here is a copy of that link: https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#switch-to-unstable-packages.
                  undefined 1 Reply Last reply 1 Jan 2023, 19:42 Reply Quote 0
                    Touchthebitum @dc42
                    @dc42 thanks
                    1 out of 9
