    3.5 beta1 print not starting
    Beta Firmware
    353
    • Touchthebitumundefined
      Touchthebitum
      Hello
      After 3.5b1 update, it hangs after home process and print doesn't start...
      How to downgrade please ?
      Thanks
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
        dc42 administrators @Touchthebitum
        @Touchthebitum does your home process include using G32 to perform true bed levelling? If so, see https://forum.duet3d.com/post/303514.
        Touchthebitumundefined 1 Reply Last reply Reply Quote 0
          Touchthebitum @dc42
          @dc42 No, the problem stands when I run a print. Home is ok and then it freezes. PanelDue indicates printing.... I tried your update but it doesn't work.
            @Touchthebitum to clarify: are you saying that your homing process does not run G32? The G32 bug did not always cause an immediate reset.
              Touchthebitum @dc42
              @dc42 No, my homing process doesn't run G32.
                @Touchthebitum thanks. When the machines hangs while trying to start a print, are you able to send M122 and get a report back?
                  Touchthebitum @dc42
                  @dc42 console.txt
                    The instructions for rolling the firmware back were linked to in my original post announcing the new release. Here is a copy of that link: https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#switch-to-unstable-packages.
                      Touchthebitum @dc42
                      @dc42 thanks
