    CONSTANT AJAX disconnect errors
    307
    55.1k
    • KeeganBundefined
      KeeganB
      @dc42:
      KeeganB, I recall that you are getting disconnections more frequently when your printer is printing than at other times. Please can you try simulating some prints (this is a right-click option in DWC1.19.3) and see if connections are lost more frequently during simulations than when the printer is idle.
      Patel, if you too have found that the connection is much less reliable when printing, please try this too.
      Hey David,
      I can test that. I need to email you, Roland, and Tony with some of my findings over the past few days. Ill try to type that up today.
      Thanks
      Artemis
      Rostock Max v2
      Orion
      • patelundefined
        patel
        @dc42:
        Patel, a few more questions:
        1. Have you worked through https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
        2. In the AJAX error message box, is the Error Reason always given as "timeout"?
        3. After a disconnection occurs, are you able to ping the Duet?
        Error timeout. And I follow your wiki page also.
        After error some time connect right way and some time I need press reset button get back
        I am tried to do this thing can you accept return.
          I've noticed a difference between the M122 reports from KeeganB and patel when the wifi connection has been lost and DWC won't reconnect. KeeganB's report from some time ago had this:
          HTTP sessions: 1 of 8
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          Patel's more recent reports have this:
          HTTP sessions: 2 of 8
          Socket states: 2 0 0 0 0 0 0 0
          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          Patel's reports are intriguing, because HTTP state 1 should time out after 2 seconds if no data is received.
          Patel, were M122 reports obtained by sending M122 from the USB port when DWC has disconnected? Or did you reconnect DWC and send M122 from DWC?
          Also, did you have just one device (e.g. PC) connected to the Duet; or did you have a second device (e.g. smartphone, tablet or another PC) connected too, or a second browser tab?
            1. I have put a build of DuetWiFiServer with sleep disabled (version 1.20beta7-nosleep) at https://www.dropbox.com/s/59s7vfkrf50fe0v/DuetWiFiServer-1.20beta7-nosleep.bin?dl=0. Please try it. The previous build (1.20beta6) is at https://www.dropbox.com/s/djs0p4beitjs60t/DuetWiFiServer-1.20beta6.bin?dl=0.
            2. Patel, what make and model of wifi router are you connecting the Duet to?
            • KeeganBundefined
              KeeganB
              @dc42:
              David, I will try the beta7 build tonight.
              Email sent.
              Thanks
              Artemis
              Rostock Max v2
              Orion
              • cbusilloundefined
                cbusillo
                DC. It happens on my Ethernet Duet at idle and while printing. Tried different browsers and computers. Also WiFi and Ethernet connections. I saw you were concentrating on the WiFi server, so I wanted to let you know that might be the wrong direction! Love everything else about the board. Keep up the good work.
                Oh you might want to put a warning out that Chinese Duets are out.
                • Dougal1957undefined
                  Dougal1957
                  David
                  Just tried to install B7-nosleep and sorry to say it failed (FW Loads fine) when trying to diagnose this I sent the usual M552 S0 but got no response back send M552 S1 and get an error saying to stop the wifi before starting it and M552 reposrts WiFi starting (Reloaded the Server fw 3 times with the same results including copying direct to the SD Card and renaming etc).
                  so decided to try B6 which worked and loaded the Wifi almost instantly.
                  Hope this helps (Not that I was suffering the Disconnects anyway)
                  Doug
                  • abeckerundefined
                    abecker
                    Any tips on what I should try. I have noticed I will get the Ajax Disconnect error at random times in a print. Sometimes it is when it is probing with the G32 command, and other times it can be actually printing. Mine will completely disconnect from the network and can't ping it or anything. I will have to wait for the print to finish and then turn it off and back on and it connects back immediately. The printer is in the same room as the router.
                    • Jareryundefined
                      Jarery
                      Loaded on my system. Got a message saying can't rename the file but then it went ahead and updated.
                      Wont be able to print to later but I can make it run through some large simulation files remotely.
                      • Jareryundefined
                        Jarery
                        JavaScript Error
                        A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                        Script Error: See Browser Console for Detail
                        Received the above when i resized the browser window, reconnected when the "connect" button is pressed.
                        Then when i ran M122 and tried to copy the wifi section it disconnected with same error
                        M122:Network state is running
                        WiFi firmware version 1.20beta7-nosle
                        WiFi MAC address a0:20:a6:10:55:89
                        WiFi Vcc 3.45, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 28552
                        WiFi IP address 192.168.2.34
                        WiFi signal strength -45dBm, reconnections 0, sleep mode none
                        • number40fanundefined
                          number40fan
                          @cbusillo:
                          Where?
                            T3P3Tony administrators
                            No. One. Mention. The. Clones.
                            J/k pm where you have seen them 🙂
                              number40fan
                              I thought I had some good google fu, but I can't find anything. Mythological creature, maybe?
                              • elmoretundefined
                                elmoret
                                I've seen 0.8.5 clones, but nothing for Duet Wifi/Ethernet yet.
                                • patelundefined
                                  patel
                                  @dc42:
                                  Devid I try my iPhone it same
                                  An AJAX error has been reported, So the current session has been terminated.
                                  HTTP sessions : 1 of 8
                                  Socket states:- 2 0 0 0 0 0 0 0
                                  Responder states:HTTP(1) HTTP(0)…......
                                  I connect to the duet to USB ( My desktop )
                                  this is the summery .
                                  USB CONNECT TO DUET
                                  m122
                                  SENDING:M122
                                  Used output buffers: 1 of 32 (15 max)
                                  RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
                                  Board ID: 08DDM-9FAM2-LW4SD-6J9D6-3SN6L-12ZHY
                                  Static ram used: 21176
                                  Dynamic ram used: 96040
                                  Recycled dynamic ram: 1568
                                  Stack ram used: 4048 current, 5920 maximum
                                  Never used ram: 6368
                                  Last reset 02:34:02 ago, cause: power up
                                  Last software reset reason: User, spinning module GCodes, available RAM 7408 bytes (slot 4)
                                  Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                  Error status: 0
                                  [ERROR] Error status: 0
                                  Free file entries: 10
                                  SD card longest block write time: 0.0ms
                                  MCU temperature: min 34.6, current 35.4, max 36.4
                                  Supply voltage: min 12.0, current 12.0, max 12.2, under voltage events: 0, over voltage events: 0
                                  Driver 0: standstill
                                  Driver 1: stalled standstill
                                  Driver 2: stalled standstill
                                  Driver 3: standstill
                                  Driver 4: standstill
                                  Date/time: 2017-11-09 13:48:43
                                  Slowest main loop (seconds): 0.224121; fastest: 0.000000
                                  MaxReps: 8, StepErrors: 0, FreeDm: 240, MinFreeDm 239, MaxWait: 5259148ms, Underruns: 0, 0
                                  Scheduled moves: 9, completed moves: 9
                                  Bed compensation in use: none
                                  Bed heater = 0, chamber heater = -1
                                  Heater 0 is on, I-accum = 0.0
                                  Heater 1 is on, I-accum = 0.0
                                  Segments left: 0
                                  Movement lock held by null
                                  http is idle in state(s) 0
                                  telnet is idle in state(s) 0
                                  file is idle in state(s) 0
                                  serial is ready with "M122" in state(s) 0
                                  aux is idle in state(s) 0
                                  daemon is idle in state(s) 0
                                  queue is idle in state(s) 0
                                  Code queue is empty.
                                  WiFi firmware version 1.20beta6
                                  WiFi MAC address 2c:3a:e8:0a:f1:18
                                  WiFi Vcc 3.36, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 33592
                                  WiFi IP address 192.168.0.144
                                  WiFi signal strength -42dBm
                                  Reconnections 0
                                  Communication Error
                                  An AJAX error has been reported, so the current session has been terminated.
                                  Please check if your printer is still on and try to connect again
                                  m122
                                  SENDING:M122
                                  Used output buffers: 10 of 32 (15 max)
                                  Last reset 02:36:37 ago, cause: power up
                                  Error status: 0
                                  MCU temperature: min 35.3, current 35.5, max 35.9
                                  Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0
                                  Driver 0: stalled standstill
                                  Date/time: 2017-11-09 13:51:18
                                  Slowest main loop (seconds): 0.079102; fastest: 0.000000
                                  MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                  Scheduled moves: 10, completed moves: 10
                                  Segments left: 0
                                  WiFi signal strength -43dBm
                                  Reconnections 0
                                  • Jareryundefined
                                    Jarery
                                    12:35:24 PMConnection established!
                                    10:51:05 AMDisconnected.
                                    9:46:14 AMConnection established!
                                    9:46:14 AMPage Load complete!
                                    Went for lunch, came back, and disconnected….it did reconnect with connect button but it had bene disco'd for over 90 min which usually is long enough for it to reconnect
                                    Firmware Name: RepRapFirmware for Duet WiFi
                                    Firmware Electronics: Duet WiFi 1.0
                                    Firmware Version: 1.20beta6 (2017-11-03)
                                    WiFi Server Version: 1.20beta7-nosle
                                    Web Interface Version: 1.19.3
                                    edit: Made a change to config, rebooted printer....and the below is the printer sitting idle
                                    1:14:26 PMDisconnected.
                                    12:54:22 PMConnection established!
                                    12:54:17 PMDisconnected.
                                    12:38:44 PMConnection established!
                                    12:38:44 PMPage Load complete!
                                    • Jareryundefined
                                      Jarery
                                      My system has disconnected again, 8 min after disconnect I can ping it via terminal fine and it still shows as connected in my router page. Connected via connect button.
                                      Will test again when i get one of the locked out disconnects.
                                        Jarery, thanks for your report. What make and model of router are you using?
                                        Patel, thanks for your reports too. have you tried with DuetWiFiServer 1.20beta7-nosleep yet? Also, what make and model of router are you using?
                                        • Jareryundefined
                                          Jarery
                                          I have 2, an Asus RT-AC3100 as my main and located 3m away, and an Asus RT-AC66U used as a access point located about 12m away. I get similar results with and without the AP router turned on.
                                          Running latest Merlin Firmware, 380.68_4
                                          Edit:
                                          last disconnect at 2:56, its now 4:03 and connect button will not reconnect. Will take a reboot or reset of wifi module. Cannot ping via terminal
                                          edit 2: wifi reset (M552 S-1, G4 S1, M552 S1) showed a reconnect on the paneldue screen but could not connect web browser, a power cycle to the printer did work.
                                          • KeeganBundefined
                                            KeeganB
                                            I have updated to DuetWiFiServer 1.20beta7-nosleep and am testing it now.
                                            Curiously, I am not sure that they "print simulation" is working. Its been going for 33mins on a print file that should have taken less than 10mins.
                                            I gave up on the print simulation issue. I guess Ill sort that later.
                                            I have been connected since 8:42pm.
                                            I printed a 14 min calibration cube. Success.
                                            Started a 6.5 hour print at 10:45pm
                                            Fingers crossed for the morning.
                                            Artemis
                                            Rostock Max v2
                                            Orion
