    Can't compile 3.5.0 (Duet2)
    Firmware developers
    635
    • OwenDundefined
      OwenD @jay_s_uk
      @jay_s_uk said in Can't compile 3.5.0 (Duet2):
      try adding
      #include <Platform/Tasks.h>
      Thanks, but made no difference.
      • gloomyandyundefined
        gloomyandy @OwenD
        @OwenD Try using the 3.4-dev version of RRFLibraries I don't think the current 3.5-dev is being used.
        OwenDundefined 1 Reply Last reply Reply Quote 2
        • OwenDundefined
          OwenD @gloomyandy
          @gloomyandy
          Thanks
          I actually tried that earlier and it almost worked.
          The binary was created but I got an error on the after compile section about crcappender I think.
          I'll have a bit more of a play later to see if I can figure it out.
          gloomyandyundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
            gloomyandy @OwenD
            @OwenD I think you may need to have "go" set up to run that tool. It may be possible to build a debug version (which I think does not use the crc stuff), but to be honest I'm not very familiar with that side of things as we don't use it on the STM32 or LPC port.
            • JoergS5undefined
              JoergS5 @OwenD
              @OwenD said in Can't compile 3.5.0 (Duet2):
              if you use windows, you should add the path to the PATH environment, so the crc32appender exe file can be found, e.g.:
              C:...\RepRapFirmware\Tools\crc32appender\win-x86_64
              This crc32appender is used to calculate a checksum of the compiled binary.
              In the tools subdirectory are versions for linux and mac also.
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @JoergS5
                @JoergS5
                The path to crc32appender.exe is already there in the environment path section, but I'm sure it's something basic like that as I can compile 3.4-dev no problems.
                • JoergS5undefined
                  JoergS5 @OwenD
                  @OwenD I a not fit enought for Eclipse details, but this path may only be valid for building, but crc32 is after linking. You could try to do it like me and add it to the environment path, then restart eclipse. I don't know why 3.4 works for you, however.
                  Maybe it helps to diagnose if you post the exact error message.
                  • OwenDundefined
                    OwenD @JoergS5
                    @JoergS5
                    Ahh, sorry. Didn't realise you meant the windows environment path.
                    I've added it there as well. Restarted windows and eclipse, but same thing.
                    JoergS5undefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • JoergS5undefined
                      JoergS5 @OwenD
                      @OwenD please post the register Console (lower half, third register).
                      • OwenDundefined
                        OwenD @JoergS5
                        @JoergS5 Here you go (last part only)
                        Building target: Duet2CombinedFirmware.elf
                        Invoking: Cross G++ Linker
                        arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreN2G\SAM4E_SDHC_USB_RTOS" -L"C:\Eclipse\Firmware\RRFLibraries\SAM4E_RTOS" -L"C:\Eclipse\Firmware\FreeRTOS\SAM4E" -L"C:\Eclipse\Firmware\CANlib\SAM4E_RTOS" --specs=nosys.specs -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -T"C:\Eclipse\Firmware\ReprapFirmware\src\Hardware\SAM4E\sam4e8e_flash.ld" -Wl,-Map,"C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.map" -o "Duet2CombinedFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group  ./src/libcpp/eh_alloc.o ./src/libcpp/vterminate.o  ./src/libc/atoi.o ./src/libc/errno.o ./src/libc/memcmp.o ./src/libc/memcpy.o ./src/libc/memmove.o ./src/libc/memset.o ./src/libc/nano-mallocr.o ./src/libc/strptime.o  ./src/bossa/Applet.o ./src/bossa/BossaFlash.o ./src/bossa/Device.o ./src/bossa/EefcFlash.o ./src/bossa/Flasher.o ./src/bossa/Samba.o ./src/bossa/WordCopyApplet.o ./src/bossa/WordCopyArm.o  ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o  ./src/Storage/CRC16.o ./src/Storage/CRC32.o ./src/Storage/EmbeddedFiles.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o  ./src/PrintMonitor/PrintMonitor.o  ./src/Platform/ArrayHandle.o ./src/Platform/Event.o ./src/Platform/Heap.o ./src/Platform/Logger.o ./src/Platform/MessageBox.o ./src/Platform/OutputMemory.o ./src/Platform/Platform.o ./src/Platform/PortControl.o ./src/Platform/RepRap.o ./src/Platform/Scanner.o ./src/Platform/StringHandle.o ./src/Platform/Tasks.o ./src/Platform/UniqueId.o  ./src/ObjectModel/GlobalVariables.o ./src/ObjectModel/ObjectModel.o ./src/ObjectModel/Variable.o  ./src/Networking/W5500Ethernet/Wiznet/Internet/DHCP/dhcp.o  ./src/Networking/W5500Ethernet/Wiznet/Ethernet/W5500/w5500.o  ./src/Networking/W5500Ethernet/Wiznet/Ethernet/WizSpi.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/socketlib.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/wizchip_conf.o  ./src/Networking/W5500Ethernet/MdnsResponder.o ./src/Networking/W5500Ethernet/W5500Interface.o ./src/Networking/W5500Ethernet/W5500Socket.o  ./src/Networking/MulticastDiscovery/MulticastResponder.o ./src/Networking/MulticastDiscovery/fgmc_protocol.o  ./src/Networking/ESP8266WiFi/WiFiInterface.o ./src/Networking/ESP8266WiFi/WiFiSocket.o ./src/Networking/ESP8266WiFi/WifiFirmwareUploader.o  ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkInterface.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o  ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o  ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/FiveBarScaraKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/RoundBedKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o  ./src/Movement/HeightControl/HeightController.o  ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o  ./src/Movement/AxisShaper.o ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/ExtruderShaper.o ./src/Movement/Move.o ./src/Movement/MoveSegment.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o  ./src/Libraries/sha1/sha1.o  ./src/Libraries/sd_mmc/ctrl_access.o ./src/Libraries/sd_mmc/sd_mmc.o ./src/Libraries/sd_mmc/sd_mmc_mem.o ./src/Libraries/sd_mmc/sd_mmc_spi.o  ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o  ./src/InputMonitors/InputMonitor.o  ./src/Heating/Sensors/AdditionalOutputSensor.o ./src/Heating/Sensors/BME280.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RemoteSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SensorWithPort.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o  ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Heater.o ./src/Heating/HeaterMonitor.o ./src/Heating/LocalHeater.o ./src/Heating/RemoteHeater.o  ./src/Hardware/Spi/SharedSpiClient.o ./src/Hardware/Spi/SharedSpiDevice.o ./src/Hardware/Spi/SpiDevice.o  ./src/Hardware/SAM4E/Devices.o ./src/Hardware/SAM4E/Main.o  ./src/Hardware/ExceptionHandlers.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o ./src/Hardware/NonVolatileMemory.o ./src/Hardware/SoftwareReset.o  ./src/GPIO/GpInPort.o ./src/GPIO/GpOutPort.o  ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/ExpressionParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o  ./src/GCodes/CollisionAvoider.o ./src/GCodes/GCodeException.o ./src/GCodes/GCodeFileInfo.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/GCodes5.o ./src/GCodes/GCodes6.o ./src/GCodes/GCodes7.o ./src/GCodes/ObjectTracker.o ./src/GCodes/RestorePoint.o ./src/GCodes/StraightProbeSettings.o ./src/GCodes/TriggerItem.o  ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o  ./src/Fans/Fan.o ./src/Fans/FansManager.o ./src/Fans/LedStripDriver.o ./src/Fans/LocalFan.o ./src/Fans/RemoteFan.o  ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/LocalZProbe.o ./src/Endstops/RemoteZProbe.o ./src/Endstops/StallDetectionEndstop.o ./src/Endstops/SwitchEndstop.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeEndstop.o  ./src/DuetNG/DueXn.o ./src/DuetNG/SX1509.o  ./src/Display/Lcd/ST7920/Lcd7920.o  ./src/Display/Lcd/ST7567/Lcd7567.o  ./src/Display/Lcd/ILI9488/ILI9488.o  ./src/Display/Lcd/Fonts/ER3301_1.o ./src/Display/Lcd/Fonts/glcd11x14.o ./src/Display/Lcd/Fonts/glcd19x21.o ./src/Display/Lcd/Fonts/glcd28x32.o ./src/Display/Lcd/Fonts/glcd7x11.o  ./src/Display/Lcd/Lcd.o ./src/Display/Lcd/MonoLcd.o ./src/Display/Lcd/TFTLcd.o  ./src/Display/ButtonMenuItem.o ./src/Display/Display.o ./src/Display/FilesMenuItem.o ./src/Display/ImageMenuItem.o ./src/Display/Menu.o ./src/Display/MenuItem.o ./src/Display/ResistiveTouch.o ./src/Display/RotaryEncoder.o ./src/Display/TextMenuItem.o ./src/Display/ValueMenuItem.o  ./src/Config/Pins.o  ./src/Comms/AuxDevice.o ./src/Comms/FirmwareUpdater.o ./src/Comms/PanelDueUpdater.o  ./src/ClosedLoop/ClosedLoop.o  ./src/CAN/CanDriversData.o ./src/CAN/CanInterface.o ./src/CAN/CanMessageGenericConstructor.o ./src/CAN/CanMotion.o ./src/CAN/CommandProcessor.o ./src/CAN/ExpansionManager.o  ./src/Accelerometers/Accelerometers.o ./src/Accelerometers/LIS3DH.o  ./src/RepRapFirmware.o ./src/Version.o   -lCANlib -lCoreN2G -lRRFLibraries -lFreeRTOS -lsupc++  -Wl,--end-group -lm
                        Finished building target: Duet2CombinedFirmware.elf
                        Generating binary file
                        arm-none-eabi-objcopy -O binary "C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.elf" "C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.bin" && crcappender "C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.bin"
                        c:/program files/gnu arm eclipse/build tools/2.6-201507152002/bin/sh: crcappender: not found
                        makefile:124: recipe for target 'post-build' failed
                        make[1]: [post-build] Error 127 (ignored)
                        21:43:07 Build Failed. 1 errors, 0 warnings. (took 25s.810ms)
                          dc42 administrators @OwenD
                          @OwenD for historical reasons, some build configurations use crc32appender and some use the more recent program CrcAppender. The Duet 2 configuration uses CrcAppender. You can find this tool at https://github.com/Duet3D/CrcAppender/releases/tag/v1.2.0.
                          PS - I have also added CrcAppender to the Tools folder of RepRapFirmware.
                          JoergS5undefined OwenDundefined 2 Replies Last reply Reply Quote 1
                          • JoergS5undefined
                            JoergS5 @dc42
                            @dc42 Thanks for stepping in. I would have looked for a while longer for a solution....
                            • OwenDundefined
                              OwenD @dc42
                              Thanks for that.
                              I have downloaded that.
                              However it now says it can't find CrcAppender.dll?
                              The application to execute does not exist: 'C:\Program Files\GNU ARM Eclipse\Build Tools\2.6-201507152002\bin\CrcAppender.dll'.
                              VTALRM
                              make[1]: [post-build] Error 154 (ignored)
                              Edit:
                              Strangely I can build for Duet2_SBC and Duet 3 Mini 5 ??
                                @OwenD that's odd! It has worked for me for several months. It should work provided that you have CrcAppender.exe on your Path. Try entering command CrcAppender on a command line, to see if it is found.
                                In the Post Build Step within Project Properties/Settings you could try replacing crcappender by CrcAppender in case that part of Eclipse is case-sensitive on your machine; or replace it by CrcAppender.exe; or you could replace it by crc32appender which is what the other configurations you mentioned used.
                                • OwenDundefined
                                  OwenD @dc42
                                  @dc42 said in Can't compile 3.5.0 (Duet2):
                                  Well if you want something broken, I'm your man! 🙄
                                  It's found no problem, but if I try to execute it, I get the same thing about crcappender.dll as if the .exe file is trying to call functions within a .dll ??
                                  None of the above work
                                  This does work.
                                  I can compile if I change the post build settings to use Crc32Appender.exe
                                  Given my needs are purely self education, that will be fine.
                                  Thanks for your help 👍
                                  • OwenDundefined OwenD marked this topic as a question
                                  • OwenDundefined OwenD has marked this topic as solved
                                  • JoergS5undefined
                                    JoergS5 @OwenD
                                    @OwenD I tried and get the same strange message:
                                    C:\Users\joerg>path %path%;c:_
                                    C:\Users\joerg>where crcappender
                                    c:_\CrcAppender.exe
                                    C:\Users\joerg>crcappender
                                    The application to execute does not exist: 'c:_\CrcAppender.dll'.
                                    C:\Users\joerg>
                                    I've never seen this before...
                                    Maybe the .NET 6 library is missing (no change after installing). But the message is very confusing.
                                      dc42 administrators @JoergS5
                                      @JoergS5 there is now a new build of CrcAppender.exe at https://github.com/Duet3D/CrcAppender/releases/tag/v1.2.0. Can you try that one? I have just tested it.
                                      • OwenDundefined
                                        OwenD @dc42
                                        That one works for me
                                        arm-none-eabi-objcopy -O binary "C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.elf" "C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.bin" && CrcAppender "C:\Eclipse\Firmware\ReprapFirmware\Duet2/Duet2CombinedFirmware.bin"
                                        Firmware binary: C:\Eclipse\Firmware\ReprapFirmware\Duet2\Duet2CombinedFirmware.bin
                                        CRC32 = 0x71B36E05
                                        20:06:38 Build Finished. 0 errors, 0 warnings. (took 3s.747ms)
                                          @OwenD thanks, I'll update the one in the Tools folder of RRF.
                                          • JoergS5undefined
                                            JoergS5 @dc42
                                            @dc42 thank you! (confirmed: works for me too now)
