    instant extruder speed
    Duet Web Control
    717
    • paolozampini1973undefined
      paolozampini1973 @dc42
      @dc42 said in instant extruder speed:
      @paolozampini1973 yes the RRF 3.5 source code provides the peak extrusion rate in mm/s for the current move before pressure advance is applied.
      Thanks for the answer but when will be available the 3.5 Thanks ?
      And very importantly I wanted to know if there are any changes that could lead to a configuration change by upgrading Because now my printer is perfect but I don't want to have problems and go change some commands Thanks?
        dc42 administrators @paolozampini1973
        @paolozampini1973 I hope to release 3.5beta1 next week. It's currently in the testing and bug fixing phase.
        paolozampini1973undefined 3 Replies Last reply Reply Quote 1
          @dc42 Thanks
            3.5beta1
            @dc42 Good evening, I wanted to have some updates on the firmware for the instantaneous speed of the extruder
              It's still in the works. You can follow the Github project if you want notification when it is released.
              https://github.com/Duet3D/RepRapFirmware
              • chrishammundefined
                chrishamm administrators @paolozampini1973
                @paolozampini1973 It's available in version 3.5-b1. Note that this is still a beta, so be prepared to revert to v3.4 if you encounter problems.
                Duet software engineer
                  Good morning when will firmware version firmware 3.5beta1 be available ?
                    Phaedrux Moderator @paolozampini1973
                    @paolozampini1973 It is available now.
                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0beta1
                    paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                      paolozampini1973 @Phaedrux
                      @Phaedrux said in instant extruder speed:
                      Thanks for the information. Here I understand that the instantaneous extruder velocity function has not been added as @dc42 said
                        droftarts administrators @paolozampini1973
                        @paolozampini1973 It has been added to RRF, I think it is this: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-350beta1
                        Added floating point field move.currentMove.extrusionRate (returns the current total extrusion rate in mm/sec)
                        We are testing internally a version of DWC 3.5b1 that shows volumetric flow:
                        But you should be able to see it through the Object Model.
                        paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                          paolozampini1973 @droftarts
                          @droftarts said in instant extruder speed:
                          GRAZIE
                            it is possible to have only the upgrade of the instantaneous volumetric part of the extruder and without upgrading all the firmware because I don't want to have problems and by the way everything works fine now
                              T3P3Tony administrators @paolozampini1973
                              @paolozampini1973 unfortunately not, this display relies on information from the newer firmware.
                                paolozampini1973 @T3P3Tony
                                @T3P3Tony said in instant extruder speed:
                                OK
