    Optical Endstops
    1.3k
    • Adamfilipundefined
      Adamfilip @Adamfilip
      https://www.youtube.com/watch?v=g5L1AnrOytY&t=4s
        Phaedrux Moderator @Adamfilip
        @Adamfilip said in Optical Endstops:
        Error: Unknown pin name 'e6stop'
        Where is it actually connected?
        Adamfilipundefined 1 Reply Last reply Reply Quote 0
          Adamfilip @Phaedrux
          @Phaedrux duex5 e6stop
            Change your pin name to duex.e6stop
            https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
            Adamfilipundefined 1 Reply Last reply Reply Quote 1
              Adamfilip @Phaedrux
              @Phaedrux Amazing thank you! that fixed it all. its all homing properly now. im shocked to be honest.
              I am curious why you need to add duex before e6stop but not when declaring the drive number on duex with M584
              • Phaedruxundefined Phaedrux marked this topic as a regular topic
                A Former User @Adamfilip
                This post is deleted!
                • mrehorstdmdundefined
                  mrehorstdmd @Adamfilip
                  @Adamfilip I use endstops that have an LM393 comparator chip and LED on board with Duet2 controller. They are very reliable and precise, except that I have had problems with them when sunlight hits them directly (an easy problem to fix, once you have figured out that that's the problem).
                  These are the exact ones I used, but they are no longer available.
                  These are similar to the ones I used.
                  The comparator slams the output either hard high or hard low, and it works fine with the voltage available at the pins on the controller board.
                  https://drmrehorst.blogspot.com/2020/01/ummd-gets-opto-endstops.html
                  https://drmrehorst.blogspot.com/2020/03/testing-ummds-xy-optical-endstops.html
                    Adamfilip @A Former User
                    @Herve_Smith I didn't LOL at you. more at the absurdity at the amounts Canadians get charged for things. Sorry Didn't intend any offense. unfortunately the same items in canada are priced very high, so the links you provided isn't a affordable option for me.. But I do appreciate you posting it as it helps to search for local alternatives.
                    • Nordleundefined
                      Nordle
                      wouldn't it work to just run the sensor from any spare 5V pin on the baord?
                      • Phaedruxundefined Phaedrux has marked this topic as solved
                        dc42 administrators @Nordle
                        @Nordle said in Optical Endstops:
                        Yes, I said that in my reply at https://forum.duet3d.com/post/305741.
