    Can't run pressure advance g-code
    1.9k
      Why such old firmware?
      gbartschundefined 1 Reply Last reply Reply Quote 0
      • gbartschundefined
        gbartsch
        This is the result of the pressure advance test. I see no variation. Maybe my firmware is too old for this script to work?
        Custom cartesian dinosaur machine; it's a tank but just works so I just keep tweaking it. / Duet Ethernet 1.02 or later / RepRapFirmware for Duet 2 WiFi/Ethernet: 3.4.5 / SuperSlicer
        • gbartschundefined
          gbartsch @Phaedrux
          @Phaedrux I'm clueless and not sure I could upgrade it without goofing something up. My friend set up my Duet and has moved away so I'm still using this. It's been working so I haven't needed to upgrade so far but it seems I should learn how.
            @gbartsch No reason to update firmware if you're still happy with how it's running. But if you do decide to give it a try, start a new thread and we'll be happy to help you along.
            If the script isn't doing it for you I would try the living tuning method. Plop a cube down in the slicer and stretch it out in one axis so you have a long flat rectangle with rectilinear infill. Then start the print and manually send the gcode command to enable PA and send a new value to increase it and see how it changes.
            Unless you have a very long bowden setup even a small amount of PA is better than no PA. Somewhere in the 0.02 to 0.04 range is probably going to be usable on a direct drive or short bowden.
            • gbartschundefined
              gbartsch @Phaedrux
              @Phaedrux Thanks a lot! I'd really appreciate help with upgrading the firmware. I'll look into the procedure and then likely make a post with some questions.
              I printed this shape at 60mm/sec and manually sent codes from M572 D0 S0.025 to M572 D0 S0.085. I don't see any difference in the seam.
                Phaedrux Moderator @gbartsch
                @gbartsch said in Can't run pressure advance g-code:
                this is what I usually tell people.
                If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                That will get your firmware and DWC up to date.
                You can see the change logs here:
                https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                https://configtool.reprapfirmware.org/Start
                Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                These documents will come in handy during the conversion.
                https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                https://docs.duet3d.com/en/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
                https://docs.duet3d.com/en/User_manual/Reference/Gcodes
                • gbartschundefined
                  gbartsch @Phaedrux
                  @Phaedrux Thanks! I'll read the sources you suggest.
                  So this is incremental upgrade method is used because the firmware is so old? But you don't recommend I do that?
                  I should use the configurator and skip the above steps?
                  I'm wondering if I could use a file compare tool (I use Beyond Compare) to look inside new versus old files? That might help with finding settings that need to move over?
                  I have a disability so will have to wait for someone to help me remove/re-insert the MicroSD card so I can backup my current config.
                    Uploading the zip files is usually a pretty quick and easy way to get up to date if you already have a working board. The fallback would be to use bossa to flash the firmware directly, but then you also have to manually place the correct files and update the DWC files manually. The zip file upload just takes care of everything for you.
                    You would still need to use the config tool to generate a new config file set that would work with RRF3. You would need to know the details of your printer setup before hand to make it easier. If you uploaded your current files it would be possible to provide you with a basic config set.
                    You don't need to remove the SD card to create a backup of the config files on the card since you can download them from DWC, but having a full copy of the card contents is always a good idea anyway.
                    • gbartschundefined
                      gbartsch @Phaedrux
                      @Phaedrux Ah! OK, this is starting to make a little sense. Now I am getting intrigued and would like to upgrade the firmware so my machine would the have the newest version of firmware and DWC and learn to how to do it.
                      Because this is off-topic from the pressure advance question should I do as you suggested and start a new thread? I really appreciate you being willing to help me. I'm sure if I can learn, anyone could and such a thread might be useful to others.
                        Sure you can start a new thread. Include your config.g and homing files. Go through the config tool and try and create a new config set and include that as well and we can compare to see how far off it is.
                        gbartschundefined 1 Reply Last reply Reply Quote 1
                        • gbartschundefined
                          gbartsch @Phaedrux
                          @Phaedrux Thank you! I will get started soon.
                          tasundefined 1 Reply Last reply Reply Quote 0
                          • tasundefined
                            tas @gbartsch
                            @gbartsch My turn to apologize for being tardy.
                            Your sample prints definitely have no pressure advance happening at all.
                            If your extruder jerk setting is too low it can limit Pressure Advance ability to function. Maybe that is what is happening.
                            Duet3D Documentation
                            Check the 'Side effects of Pressure Advance' section at the bottom of the page.
                            Pressure Advance was working for 2.04 as far as I can remember but I still think it is worth upgrading as @Phaedrux suggested. You do have to do it in the order he suggested.
                            Do post your config to get it checked before trying to print with the new firmware. There are a few significant changes. If only I had written them down.
                            gbartschundefined 3 Replies Last reply Reply Quote 0
                            • gbartschundefined
                              gbartsch @tas
                              @tas said in Can't run pressure advance g-code:
                              Thank you!
                              Well that might be the problem as my jerk is lower than default even. My machine is the Cartesian style with heavy X and Y movements so I lowered the jerk to reduce shaking. I'll increase it and run the test.
                              M566 X800.00 Y800.00 Z24.00 E300.00     ; set maximum instantaneous speed changes (mm/min)
                              • gbartschundefined
                                gbartsch @tas
                                I posted my config.g files in my firmware post (https://forum.duet3d.com/topic/31263/idiot-s-guide-to-upgrading-duet-firmware/10) and am looking at the differences. There are a number of them and I'm gathering that sorting them out will be the trickiest part of upgrading firmware; the other steps seem easy.
                                • tasundefined
                                  tas @gbartsch
                                  @gbartsch I have set my max E jerk to 3000. I also had it at 300 to begin. I have an E3D V6 on a Creality Ender 5 Pro x-carriage with an LGX Lite bowden setup.
                                  Setting the max to a high value does not force it to use that setting it simply allows it to go that high if the gcode commands require it.
                                  This should not affect the X and Y. The M566 parameters are per axis so E only affects extruder jerk. It shouldn't make your printer shake.
                                  It would be great if that change can solve your problem.
                                  • tasundefined
                                    tas @gbartsch
                                    @gbartsch Funny! We were posting at the same time. I saw your other post and thought I would add a note about the jerk setting in this one as I think it is more relevant to this topic.
                                    I did see your config files and will let the experts have a look. It should be very straight forward. Just go through the steps in order as @Phaedrux laid out above.
                                    It takes a while but it is not difficult because I was able to do it.
                                    • gbartschundefined
                                      gbartsch @tas
                                      His explanation was very clear and if those steps - combined with rebuilding the config.g file - are most of what is involved in upgrading the firmware I'm feeling more confident about it.
                                      • gbartschundefined
                                        gbartsch @tas
                                        I did see your config files and will let the experts have a look. It should be very straight forward. Just go through the steps in order as @Phaedrux laid out above. It takes a while but it is not difficult because I was able to do it.
                                        I really appreciate everyone's help. Much of this doesn't seem to bad if people with knowledge guide me along. I'm hoping I can understand the overall schema through this and be able to keep up from here on.
                                        • gbartschundefined
                                          gbartsch @tas
                                          I have set my max E jerk to 3000. I also had it at 300 to begin. I have an E3D V6 on a Creality Ender 5 Pro x-carriage with an LGX Lite bowden setup. Setting the max to a high value does not force it to use that setting it simply allows it to go that high if the gcode commands require it. This should not affect the X and Y. The M566 parameters are per axis so E only affects extruder jerk. It shouldn't make your printer shake.
                                          I changed my max E jerk to 3000 but there was no change to the print. I'm thinking the best thing to do now is upgrade the firmware and revisit this issue after. I'm quite at a loss here.
                                          • gbartschundefined gbartsch referenced this topic
                                          • gbartschundefined
                                            gbartsch
                                            Well I give up trying to run the code in my slicer; I can't get it to work in either PrusaSlicer or SuperSlicer.
                                            But I could send commands from the console and pressure advance does work when added to my filament g-code so I'm happy. 😄
                                            I can say it wasn't working for a long time because the extruder stepper shaft moves differently now than before; I can see the stepper rotation indicator move with slight twitches at the end of each path.
                                            Thank you everyone for your suggestions!
                                            droftartsundefined 1 Reply Last reply Reply Quote 1
