Never Printing Flat
497
    Adam_Sw3
    Hi All,
    I was just wondering if anyone would be able to help me.
    I can never seem to get a nice flat initial printing layer, I have EZABL and have calibrated it as the guide says.
    I have been going at this for around a month now and I cannot seem to get a good first layer, one side of my print is too close to bed and the other is too far away,
    I then had the idea to do some Z probes around the bed to see what the variation was. Please see my attached readouts from both left and right-hand sides. Does anyone know what is causing this, and if so, how would I fix it and ensure that my probing figures are correct all around my plate?
    Thank you.
      That's a pretty big difference in trigger height. That may indicate the probe is tilting as it moves in XY.
      What kind of printer is this? Can you give some more details? How is the Z axis arranged? How do you home? Are you doing manual leveling as well?
      How is the probe mounted?
      Please share your config.g, homing files, and bed.g
      Please send M122 and M98 P"config.g" and copy and paste the results here.
      undefined undefined 2 Replies Last reply 30 Jan 2023, 21:48 Reply Quote 1
        Adam_Sw3 @Phaedrux
        @Phaedrux Hi there,
        Yes, I thought the same!! This is my own built 3D printer and the layout of the Z axis is a triangular shape using 3 lead screws at each point in a symmetrical triangle. I don't think it's the probe as the probe cable is fixed locally to it ensuring it is static. I home XY at end of travel and Z in the centre of the bed. The probe is mounted using its standard hole mount with 2 nuts.
        Would ABL solve this? or even true bed levelling?
        Home all code:
        G91 ; relative positioning
        G1 H1 X-555 Y-415 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X-555 ; home X axis
        G1 H1 Y-415 ; home Y axis
        G1 H1 X-555 F360 ; move slowly to X axis endstop once more (second pass)
        G1 H1 Y-415 ; then move slowly to Y axis endstop
        G90 ; absolute positioning
        G1 X270 Y180 F6000 ; go to first bed probe point and home Z
        ;G1 X-20 Y10 F6000 ; go to first bed probe point and home Z
        config.g
        M550 P"Printer" ; set printer name
        M669 K1 ; select CoreXY mode
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P4 S0 ; physical drive 4 goes forwards - E1
        M584 X0 Y1 Z2:5:4 E3 ; set drive mapping
        M92 X80.00 Y80.00 Z1066.67 E446.8 ; set steps per mm
        M906 X1500 Y1500 Z1500 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X550 Y410 Z500 S0 ; set axis maxima
        M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
        M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
        M558 P1 C"!zprobe.in" H10 F240 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X35 Y0 Z5.7 ; set Z probe trigger value, offset and trigger height
        M557 X15:525 Y10:400 S50 ; define mesh grid
        M307 H0 R0.310 K0.291:0.000 D1.41 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
        M143 H1 S300 ; set temperature limit for heater 1 to 300C
        M563 P0 S"MATERIAL 1" D0 H1 F0 ; define tool 0
        M563 P1 S"MATERIAL 2" D0 H1 F0 ; define tool 1
        bed.g
        G28 ; home
        G30 P0 X50 Y410 Z-99999 ; probe near a leadscrew, half way along Y axis
        G30 P1 X550 Y410 Z-99999 ; probe near a leadscrew and calibrate
        G30 P2 X275 Y3 Z-99999
        M122:
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917NK-F23T0-6JKDJ-3SD6N-TDBJF
        Used output buffers: 1 of 26 (13 max)
        Static ram: 23860
        Dynamic ram: 75216 of which 0 recycled
        Never used RAM 12932, free system stack 116 words
        Tasks: NETWORK(notifyWait,14.0%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,294) MAIN(running,85.9%,458) IDLE(ready,0.1%,30), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:37:27 ago, cause: software
        Last software reset at 2023-01-30 21:01, reason: User, GCodes spinning, available RAM 12932, slot 2
        Error status: 0x00
        Step timer max interval 0
        MCU temperature: min 33.0, current 34.6, max 37.3
        Supply voltage: min 23.9, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0
        Driver 1: standstill, SG min 0
        Driver 2: standstill, SG min 0
        Driver 3: standstill, SG min n/a
        Driver 4: standstill, SG min 0
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Date/time: 2023-01-30 21:39:08
        Slowest loop: 34.57ms; fastest: 0.18ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 7.7ms, write time 1.1ms, max retries 0
        DMs created 83, segments created 3, maxWait 418264ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 250, completed 250, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty
        === Network ===
        Slowest loop: 97.08ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        = WiFi =
        Network state is active
        WiFi firmware version 1.27
        WiFi MAC address b4:e6:2d:53:0c:f9
        WiFi Vcc 3.37, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 24528
        WiFi IP address 192.168.1.247
        WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        M98 Returns an error?
        M98
        Error: M98: No P or R parameter
        Thank you for your help, any help in getting to the bottom of this would be greatly appreciated.
        Kind Regards,
        Adam
          Phaedrux Moderator @Phaedrux
          @Phaedrux said in Never Printing Flat:
          M98 P"config.g"
            Have you tried setting up automatic leveling?
            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
            undefined 1 Reply Last reply 30 Jan 2023, 21:58 Reply Quote 1
              Adam_Sw3 @Phaedrux
              @Phaedrux oooh, what does M98 do?
              Is automatic levelling different to ABL? Like the one seen in my bed.g file?
              undefined 1 Reply Last reply 31 Jan 2023, 01:13 Reply Quote 0
                Phaedrux Moderator @Adam_Sw3
                @Adam_Sw3 said in Never Printing Flat:
                what does M98 do?
                It calls a macro to run. M98 P"config.g" will call config.g to run as it does on startup, but since the system is already running it can catch syntax errors that might otherwise get missed at startup.
                No its the same thing but your bed.g appears to be missing the S parameter on the last probe point to do the calculation, but maybe that's just a copy and paste error?
                undefined 3 Replies Last reply 31 Jan 2023, 09:52 Reply Quote 1
                  Adam_Sw3 @Phaedrux
                  This post is deleted!
                    Adam_Sw3 @Phaedrux
                    @Phaedrux Thank you for this! I will read through the documentation! Hopefully this should solve it!
                      Adam_Sw3 @Phaedrux
                      @Phaedrux Hi There, I have just had a crack at this tonight and I am getting an error "Some computed corrections exceed configured limit of 0.50mm: -0.487 5.186 -8.188" I understand that this is out of the tolerance for the machine to avoid it damaging itself.
                      I am thinking that the way I have wired it up may be the issue, 2 Z's are connected to both Z drivers. and the other "Z driver" is connected to E0. I, therefore, believe the 2 Z's arent independent. Is this the case or are they individually addressable?
                      Thank you.
                      undefined 1 Reply Last reply 2 Feb 2023, 20:04 Reply Quote 0
                        You can adjust the tolerance in the M671 S parameter.
                        undefined 1 Reply Last reply 2 Feb 2023, 20:05 Reply Quote 1
                          Adam_Sw3 @Phaedrux
                          @Phaedrux to like +-10mm?! Are the dual Z's independent?
                          undefined 1 Reply Last reply 2 Feb 2023, 20:13 Reply Quote 0
                            to like +-10mm?!
                            Well you'll have to determine what a safe amount of movement is to prevent damage. However, the whole point of the feature is to reduce the difference between the points, so it should be bringing things closer to spec.
                            I would suggest trying 2 or 3mm and manually leveling the sides to begin with. Then there shouldn't be much of a difference between the sides and only a small amount of correct would be needed.
                            I'm not exactly sure I follow. Which motors are wired where? The Z driver on the Duet 2 board is a single driver. The two ports for that driver are wired in series. So to use independent control each motor must have it's own driver.
                            From your config.g I see your driver mapping is a little wrong.
                            There are only 5 drivers on the Duet, but you have 6 mapped. There is no driver 5, only 0,1,2,3,4.
                            So you can't actually do 3 motor leveling (and still have an extruder) on a duet 2 without either a Duex or external driver expansion.
                              Adam_Sw3
                              @Phaedrux Ohhhhh!! I am misunderstood sorry about that. Yes it is massively better now thank you and watching it in action is extremely awesome!
                              Yes my fault, I don't know why I stuck 5 in there!! I have since removed that now. Thanks for your help!
                              Cheers!
                                Well how many Z motors do you have?
                                6 out of 15
