    Extrude and retract backwards.
    1.0k
    • Borgtribbleundefined
      Borgtribble
      I'm running ender 3 with microswiss direct drive extruder. I believe everything is installed correctly but for some reason when using the extrude command the filament retracts and using the retract command the filament feeds into the hotend. ? It's funny but also frustrating lol.
      Rushmere3Dundefined OwenDundefined 2 Replies Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @Borgtribble
        @Borgtribble Change the S value of the M569 command for the extruder. (S0 or S1)
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          You likely need to change the direction of rotation of your extruder motor in the M569 S command in config.g.
          https://docs.duet3d.com/User_manual/Reference/Gcodes#m569-set-motor-driver-direction-enable-polarity-mode-and-step-pulse-timing
          • OwenDundefined
            OwenD @Borgtribble
            @Borgtribble
            Look in config.g for a line like this for your extruder driver(s)
            M569 P3 S0 ; physical drive 3 (E0) goes backwards
            If the S parameter is set to zero, set it to one.
            If it's currently set to one, set it to zero.
            Adjust the comment to the opposite direction of whatever it is now for clarity
            Edit: 😂😂. Too slow
            Flynbrdundefined 1 Reply Last reply Reply Quote 3
            • Flynbrdundefined
              Flynbrd @OwenD
              @OwenD
              like this! 🙂
              M569 P0 S0 ; physical drive 0 goes backwards
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @Flynbrd
                @Flynbrd
                I have no reference point as you only posted one set of commands, but as long as you have the right driver number (usually 3) then yes.
