    My latest head scan print.
    Example setups and prints
    2.9k
    • botundefined
      bot
      Sorry to flood the board, last post with finished pics: http://imgur.com/a/TV74Z
      *not actually a robot
      • Toddimusundefined
        Toddimus
        Very, very cool.
        Out of curiosity, is this done with the "vase" spiral mode, or are there more than one perimeters per layer?
        If it's not a spiral, how did you deal with the seams? Are they running up the back of his head? 🙂
        And what slicer program did you use?
        • botundefined
          bot
          Thanks. It was not done with spiral vase mode. There are 3 perimeters, and no infill other than selective solid infill simplify3d puts to maintain shell thickness.
          Yes, the seam is running up the back. It's pretty small but still visible. I actually sculpted the back and top of his head smooth to help alleviate some suspected problems with the rough hair, so the back is kinda funny looking.
          • Toddimusundefined
            Toddimus
            Thanks for the info. Now that I have my printer mostly dialed in, I'm looking into slicers and slicing parameters. I was curious how you did it.
            Cheers!
            • ianlee74undefined
              ianlee74
              Nice job. How did you get the scan?
              • botundefined
                bot
                Thanks. It was professionally done by a company called Pixel Light Effects. I got a second one done, too, and printed some 1/6th scale heads as a test: http://imgur.com/a/kwwDL
                • jmlundefined
                  jml
                  That is amazing! The skin is is so detailed! And I can barely notice the print lines!
                  • botundefined
                    bot
                    Thanks! It is pretty good, but I'm almost ready to build a printer that should produce even better results… all made possible by Duet.
                    As a side note, this head print was one of my longest prints until just the other day -- 204 hours print time is now my new record (client's print, can't show pics unfortunately.)
                    Not a single ajax disconnect in those 204 hours! (Duet 0.8.5 on an ancient beta firmware 1.15) (Sorry for any users encountering troubles, not meant as a low blow.)
                      deckingman
                      @bot:
                      Wow! That's like 8 and a half days - hope you charged the client a lot of money. 🙂
                      • botundefined
                        bot
                        It was only part of an order, but that part alone was priced at about $650.
                        • Jareryundefined
                          Jarery
                          Cool, if your brother get an iPhone X you can probably unlock it 🙂
