    My latest head scan print.
    Example setups and prints
    2.9k
    • botundefined
      bot
      I got a pretty good scan done of my brother. It turned out quite well, though the texture of the skin might be a bit exaggerated compared to reality, it is a great test of the detail possible with FDM.
      PLA, 80 micron layers, 0.4 mm nozzle. Printer is slow, and jerk is set low (480mm/min) so the print time will be 3-4 days.
      More photos in this album: http://imgur.com/a/2IZ6I
      PS I am very sorry, but I cheated… this was done with a Duet 0.8.5 (haven't got a wifi yet to try). Please forgive me.
      *not actually a robot
      • botundefined
        bot
        The print just completed. 94 hours total! Wowza!
        Amazingly, even though this model has a ridiculous mesh density, this was in the m122 after:
        Move Diagnostics:
        MaxReps: 7, StepErrors: 0\. Underruns: 58
        Amazing. You've done some great improvements to the motion code lately it seems, dc42. Thank you. I'm running 1.15-beta3 (2016-07-09).
        • botundefined
          bot
          Sorry to flood the board, last post with finished pics: http://imgur.com/a/TV74Z
          • Toddimusundefined
            Toddimus
            Very, very cool.
            Out of curiosity, is this done with the "vase" spiral mode, or are there more than one perimeters per layer?
            If it's not a spiral, how did you deal with the seams? Are they running up the back of his head? 🙂
            And what slicer program did you use?
            • botundefined
              bot
              Thanks. It was not done with spiral vase mode. There are 3 perimeters, and no infill other than selective solid infill simplify3d puts to maintain shell thickness.
              Yes, the seam is running up the back. It's pretty small but still visible. I actually sculpted the back and top of his head smooth to help alleviate some suspected problems with the rough hair, so the back is kinda funny looking.
              • Toddimusundefined
                Toddimus
                Thanks for the info. Now that I have my printer mostly dialed in, I'm looking into slicers and slicing parameters. I was curious how you did it.
                Cheers!
                • ianlee74undefined
                  ianlee74
                  Nice job. How did you get the scan?
                  • botundefined
                    bot
                    Thanks. It was professionally done by a company called Pixel Light Effects. I got a second one done, too, and printed some 1/6th scale heads as a test: http://imgur.com/a/kwwDL
                    • jmlundefined
                      jml
                      That is amazing! The skin is is so detailed! And I can barely notice the print lines!
                      • botundefined
                        bot
                        Thanks! It is pretty good, but I'm almost ready to build a printer that should produce even better results… all made possible by Duet.
                        As a side note, this head print was one of my longest prints until just the other day -- 204 hours print time is now my new record (client's print, can't show pics unfortunately.)
                        Not a single ajax disconnect in those 204 hours! (Duet 0.8.5 on an ancient beta firmware 1.15) (Sorry for any users encountering troubles, not meant as a low blow.)
                          deckingman
                          @bot:
                          Wow! That's like 8 and a half days - hope you charged the client a lot of money. 🙂
                          • botundefined
                            bot
                            It was only part of an order, but that part alone was priced at about $650.
                            • Jareryundefined
                              Jarery
                              Cool, if your brother get an iPhone X you can probably unlock it 🙂
