    RRF3.5 crash Duet 3 6HC
    Firmware installation
    724
    • damaged_goodsundefined
      damaged_goods @OwenD
      @OwenD I did all that you suggested without luck. I cannot connect to the board by any means it seems.
        damaged_goods @Phaedrux
        I wondered what a Bossa port was. I saw it when I was trying to connect to the board through YAT. I did not touch the Erase button.
        @Phaedrux If a port called Bossa port is shown then the firmware has been erased. Perhaps you pressed the Erase button. You need to re-install firmware via USB. See the "Fall-back procedure #2" section in Installing and Updating Firmware.
          Yes, if you see a bossa port, you'll need to reflash the firmware.
            @Phaedrux It appears the flash is corrupted so I downloaded the version 3.5.0 beta 2 zip file. If I try and load zip file into the Duet Bossa I get an error that " file operation exceeds flash size". What am I missing?
              Phaedrux Moderator @damaged_goods
              @damaged_goods said in RRF3.5 crash Duet 3 6HC:
              What am I missing?
              Following the directions.
              https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
              Use this firmware file.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet3Firmware_MB6HC.bin
              damaged_goodsundefined 1 Reply Last reply Reply Quote 0
                @Phaedrux Sorry for my ignorance but I downloaded the duet bossa but cannot find the exe file.
                  https://github.com/Duet3D/BOSSA/releases/download/1.9.1a-duet3d/Bossa.exe
                  Did you download that?
                    @Phaedrux After multiple loading failures it thankfully loaded. I now have the board showing up on the computer.
                      So you were able to get it flashed?
                        @Phaedrux Yes although it did freeze several times and would not complete. I just prayed, ended the task and tried again. I reinstalled the sys file from backup and all seems back to normal.
                        Any idea what might have happened? I would like to attempt future firmware upgrades but now I am a little scared.
                          Please send M122 and M122 B# where # is the canbus address of your expansion boards and copy and paste here.
                          Also check your DWC version.
                          Uploading the 3.4.5 zip file to the system tab in DWC should work.
                          You're not using an SBC are you?
                            @Phaedrux 2/20/2023, 10:41:54 AM M122
                            RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
                            Board ID: 08DJM-9P63L-DJ3T0-6JTDJ-3SJ6M-T83BA
                            Used output buffers: 3 of 40 (25 max)
                            Static ram: 152760
                            Dynamic ram: 97040 of which 160 recycled
                            Never used RAM 100712, free system stack 200 words
                            Tasks: NETWORK(ready,23.1%,176) ETHERNET(notifyWait,0.3%,443) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,333) TMC(notifyWait,7.9%,91) MAIN(running,68.4%,1083) IDLE(ready,0.3%,30), total 100.0%
                            Owned mutexes:
                            Last reset 00:12:35 ago, cause: power up
                            Last software reset at 2023-03-02 01:46, reason: AssertionFailed, Platform spinning, available RAM 100424, slot 2
                            Software reset code 0x4120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xf069b60c Task M��� Freestk 4294967295 ok
                            Stack: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 131
                            MCU temperature: min 17.4, current 34.2, max 35.6
                            Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                            12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                            Events: 0 queued, 0 completed
                            Driver 0: standstill, SG min 0, mspos 8, reads 12817, writes 16 timeouts 0
                            Driver 1: standstill, SG min 0, mspos 8, reads 12819, writes 14 timeouts 0
                            Driver 2: standstill, SG min 0, mspos 8, reads 12819, writes 14 timeouts 0
                            Driver 3: standstill, SG min 0, mspos 8, reads 12820, writes 14 timeouts 0
                            Driver 4: standstill, SG min 0, mspos 8, reads 12820, writes 14 timeouts 0
                            Driver 5: standstill, SG min 0, mspos 8, reads 12818, writes 16 timeouts 0
                            Date/time: 2023-02-20 10:41:56
                            Slowest loop: 1171.63ms; fastest: 0.05ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 3.5ms, write time 154.2ms, max retries 0
                            DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            === AuxDDARing ===
                            Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            SBC is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Aux2 is idle in state(s) 0
                            Code queue is empty
                            === CAN ===
                            Messages queued 6798, received 0, lost 0, boc 0
                            Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 3778/0/0
                            Tx timeouts 0,0,3777,0,0,3019 last cancelled message type 4514 dest 127
                            === Network ===
                            Slowest loop: 1171.52ms; fastest: 0.03ms
                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                            HTTP sessions: 2 of 8
                            = Ethernet =
                            State: active
                            Error counts: 0 0 0 1 0 0
                            Socket states: 5 2 2 2 2 2 0 0
                            === Multicast handler ===
                            Responder is inactive, messages received 0, responses 0
                            DWC 3.4.0 is installed at this time
                            I have no idea what an SBC is 🙂
                              Ok, so with firmware 3.4.5 flashed to the board your DWC version should now be updated to match. You didn't include the M122 for the expansion board, so it's probably not matched to 3.4.5 yet either.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                              Upload that zip file to the system tab in DWC and that should get everything updated.
                                @Phaedrux Thank you for your assistance. I really appreciate it!
                                I did not include an expansion board M122 because I don't believe I have one.
                                Thank you again. Hopefully I won't be bothering you any time soon.
