Solved How to configure a Duet 2 wi-fi board to run a replicator 2
Can you be more specific about what you're looking for?
See here for general guidance on adapting an existing printer to use a Duet.
https://docs.duet3d.com/en/User_manual/Overview/Adapting -
Thank you for you reply. I recently changed the Makerbot mighty board in my replicator 2 to a Duet 3D duet 2 WiFi board. I went to the Thingiverse web site and downloaded a file after reading a post on the forum. Duet WiFi configuration files for replicator 2X, http://www.thingiverse.com/thing:2475257. I loaded this file thinking it would allow me to print, but it didn't. I guess what I need is the software/ firmware to set up my printer to start printing. Thank you so much for your help.
Walt -
Ok, how far have you gotten?
Have you been able to connect to the web interface?
https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
If so, can you go to the gcode console tab and send
M122
and copy and paste the result here. That will tell us what firmware version you are using. -
OK this is what I found === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later<LF>Board ID: 0JD2M-9F8TA-GJ4TD-6JKF2-3S46N-K6NL7<LF>Used output buffers: 1 of 24 (9 max)<LF>=== RTOS ===<LF>Static ram: 23868<LF>Dynamic ram: 74028 of which 12 recycled<LF>Never used RAM 14172, free system stack 172 words<LF>Tasks: NETWORK(ready,12.3%,332) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,87.6%,460) IDLE(ready,0.1%,30), total 100.0%<LF>Owned mutexes: WiFi(NETWORK) USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:25:49 ago, cause: power up<LF>Last software reset at 2023-01-25 10:01, reason: User, GCodes spinning, available RAM 13968, slot 1<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a<LF>Error status: 0x08<LF>Aux0 errors 0,0,0<LF>Step timer max interval 0<LF>MCU temperature: min 14.4, current 28.8, max 29.3<LF>Supply voltage: min 1.8, current 24.1, max 24.2, under voltage events: 1, over volta[Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.]
You'll need to make a settings change in YAT to get the full report to show up properly.
@Phaedrux I hope thuis is what your looking for? {\rtf1\ansi\ansicpg1252\deff0\nouicompat\deflang1033{\fonttbl{\f0\fnil DejaVu Sans Mono;}}
{\colortbl ;\red128\green0\blue128;\red255\green165\blue0;}
{*\generator Riched20 10.0.22621}\viewkind4\uc1
\pard\cf1\b\f0\fs17 === Diagnostics ===\b0 <LF>\b RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later\b0 <LF>\b Board ID: 0JD2M-9F8TA-GJ4TD-6JKF2-3S46N-K6NL7\b0 <LF>\b Used output buffers: 5 of 24 (24 max)\b0 <LF>\b === RTOS ===\b0 <LF>\b Static ram: 23868\b0 <LF>\b Dynamic ram: 74028 of which 12 recycled\b0 <LF>\b Never used RAM 14172, free system stack 170 words\b0 <LF>\b Tasks: NETWORK(ready,6.2%,324) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,93.7%,385) IDLE(ready,0.0%,30), total 100.0%\b0 <LF>\b Owned mutexes: USB(MAIN)\b0 <LF>\b === Platform ===\b0 <LF>\b Last reset 00:58:24 ago, cause: power up\b0 <LF>\b Last software reset time unknown, reason: User, GCodes spinning, available RAM 14172, slot 2\b0 <LF>\b Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a\b0 <LF>\b Error status: 0x0c\b0 <LF>\b Aux0 errors 0,0,0\b0 <LF>\b Step timer max interval 0\b0 <LF>\b MCU temperature: min 30.0, current 30.3, max 30.7\b0 <LF>\b Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power \cf2 [Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.]\cf0\b0\fs17\par
Walt -
Nope. I don't think you've made the change as it's still trying to put the entire report on a single line.
@Phaedrux I'm doing my best, hope this is it=== Diagnostics ===
Used output buffers: 3 of 24 (24 max)
Static ram: 23868
Dynamic ram: 74028 of which 216 recycled
Never used RAM 13968, free system stack 162 words
Tasks: NETWORK(ready,9.2%,243) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,90.8%,204) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes:
Last reset 00:50:24 ago, cause: power up
Error status: 0x0c
Aux0 errors 0,0,0
MCU temperature: min 29.5, current 30.3, max 30.6
Supply voltage: min 23.8, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2023-02-20 15:27:36
Slowest loop: 50.22ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.9ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 39.55ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 5
WiFi firmware version 1.26
WiFi MAC address a4:e5:7c:03:da:22
WiFi Vcc 3.31, reset reason Power up
WiFi flash size 2097152, free heap 24368
WiFi IP address 192.168.1.24
WiFi signal strength -48dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 4 0 0 0 0 0 0 0
2/20/2023, 3:26:16 PM Connected to 192.168.1.24
- WiFi -
@waltdonjr said in How to configure a Duet 2 wi-fi board to run a replicator 2:
Are you able to go to this IP address in your browser and access the web control?
@Phaedrux Yes
Alright, that's half the battle.
Now that you have access to the web interface you can finish updating the firmware, etc by uploading this zip file to the system tab.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
That should get you on good footing for the rest of your setup.
You can try and create a base config file set based on what you know about the printer details with the online tool here to at least get you started.
@Phaedrux Thank you for all your help. I'm at the point where I'm able to put in commands and make the changes I need to. Your the best and I couldn't have done it without you
Thank you again
Walter Perry -
