Temperature offset?
Can you post your full config.g and config-override.g?
Also post the results of M122 and M98 P"config.g" -
@infiniteloop
The spare gives me more or less the same result (difference of about half a degree), also with the other connector lead. -
Here's my full config file. I do not seem to have a config-override on this printer. Could that be a problem?
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 22 2022 15:24:14 GMT+0100 (Central European Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"BigBitch" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X475 Y465 Z450 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in M574 Y1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io2.out" ; Duet 3 Mini 5+ M558 P9 C"io2.in" H10 F120 T6000 A3 ; set Z probe type to modulated and the dive height + speeds G31 P1000 X-39 Y2 Z3.1 S21 H2 T0.02 ; Nozzle offset - Powder Coated Sheet with temperature compensation (0.02mm/°C) M574 Z1 S2 ; set Z probe trigger value, offset and trigger height M557 X5:435 Y5:465 P10:10 ; define mesh grid M376 H5 ; Fade height 5mm ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 R0.213 C666.6 D8.13 S1.00 V24.1 ; M140 H0 ; map heated bed to heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R1.350 K0.244:0.000 D5.89 E1.35 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P1 D0 H1 F0 ; define tool 0 G10 P1 X0 Y0 Z0 ; set tool 0 axis offsets G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P2 D0 H1 F0 ; define tool 0 G10 P2 X0 Y0 Z0 ; set tool 0 axis offsets G10 P2 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P3 D0 H1 F0 ; define tool 0 G10 P3 X0 Y0 Z0 ; set tool 0 axis offsets G10 P3 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P4 D0 H1 F0 ; define tool 0 G10 P4 X0 Y0 Z0 ; set tool 0 axis offsets G10 P4 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P5 D0 H1 F0 ; define tool 0 G10 P5 X0 Y0 Z0 ; set tool 0 axis offsets G10 P5 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P6 D0 H1 F0 ; define tool 0 G10 P6 X0 Y0 Z0 ; set tool 0 axis offsets G10 P6 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P7 D0 H1 F0 ; define tool 0 G10 P7 X0 Y0 Z0 ; set tool 0 axis offsets G10 P7 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 ; Custom settings are not defined
M122
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: URV2B-M396U-D65J0-40KMY-1H03Z-72JMX Used output buffers: 3 of 40 (27 max) === RTOS === Static ram: 103684 Dynamic ram: 111512 of which 0 recycled Never used RAM 26516, free system stack 196 words Tasks: NETWORK(ready,14.4%,253) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,114) MAIN(running,84.0%,426) IDLE(ready,0.1%,29) AIN(delaying,0.8%,273), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:05:29 ago, cause: power up Last software reset at 2023-02-26 13:21, reason: User, GCodes spinning, available RAM 23252, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 330081, completed 330080, timed out 0, errs 0 Step timer max interval 1490 MCU temperature: min 23.5, current 28.0, max 28.0 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17318, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17317, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17317, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17317, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17318, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-02-27 07:12:12 Cache data hit count 636420885 Slowest loop: 33.38ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 1.5ms, write time 8.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 2964, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1648/0/0 Tx timeouts 0,0,1647,0,0,1315 last cancelled message type 4514 dest 127 === Network === Slowest loop: 33.48ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address d8:bf:c0:15:0b:d5 WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 25464 WiFi IP address 192.168.1.33 WiFi signal strength -70dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M98 P"config.g"
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Temperature coefficients ignored due to invalid sensor number 2
@Queevix said in Temperature offset?:
That warning is because you've put temperature compensation using sensor 2 in the probe definition, but you don't have a sensor 2. I don't think it's relevant to the fault under discussion though.
The warning would go if you took the
S21 H2 T0.02
out of your G31 line. -
I'll try that this evening. Thanks!
Try moving the sensor to a different input. It is possible you have a bad ADC channel.
@mendenmh @achrn @Phaedrux @DIY-O-Sphere @infiniteloop
So yeah, I connected the sensor to temp2 instead of temp1, and get normal temperatures now. Does this mean my temp1 connection is shot on this board? I wouldn't be very happy about that...
Also, what is an ADC channel?Anyway, I can print again now, So I guess I'll get started on that
Thanks everyone!
Analog Digital Conversion. It's the part that takes the analog signal from the temp sensor and converts it to a digital representation.
When and where did you get the board?
Can you try updating your firmware by uploading this zip file to the system tab in DWC? Just in case.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
