    duet2 wifi does not respond
    Using Duet Controllers
    413
    • oolykundefined
      oolyk
      after several months of my delta not working, I am trying to revive it and so far no luck.
      • duet 2 wifi
      • re installed firmware
      • can communicate by yat
      • verified firmware
      • was able to connect to wifi only thru hotpoint (all other wifi channels at home did not work)
      • received name and ip address
      • could not connect to said address because the board did not respond
      • all leds are correctly lid, including wifi module
      • diag led off but shortly lid when usb connected
      • followed all items in "what to do when duet does not respond"
      any ideas?
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @oolyk
        @oolyk it sounds like it does respond.
        What firmware have you updated to?
        Did you update the wifi firmware?
        Can you post an output of M122, preferably with the wifi enabled (M552 S1)
        I would also suggest clearing all saved wifi networks using M588 S"*" and resending the wifi info again using M587
        oolykundefined 1 Reply Last reply Reply Quote 0
        • oolykundefined
          oolyk @jay_s_uk
          @jay_s_uk - thanks.
          I did not know how to attach yat results, so here is a link to my cloud copy of m122 file:
          https://drive.google.com/file/d/1D7v9JxPmQ4dLjUtWh55y0Khf83Ro-7P1/view?usp=sharing
          after clearing 588 as sugggested.
          also, the newly installed firmware is: duet2 combined firmware.bin v 3.4.5
          does it include wifi firmware? did not deal separately with wifi firmware
            jay_s_uk @oolyk
            @oolyk that doesn't include the wifi firmware. You are on 1.26 for the wifi firmware and, although it's not the latest (which is 1.26), it's still compatible with 3.4.5
            Your network strength is a little on the low side (-66db). The recommended strength is -60db or better.
            Does nothing load at all when you try the ip address in a browser?
            Can you ping the duet?
              When you updated the firmware did you also update the DWC files on the SD card?
              • oolykundefined
                oolyk @Phaedrux
                @Phaedrux : how do you update dwc on the sd card ?
                Jay: 1. nothing loads at all when i try the ip address 2. how can I ping the duet?
                  jay_s_uk @oolyk
                  @oolyk https://www.alphr.com/how-to-ping-an-ip-address/
                    Phaedrux Moderator @oolyk
                    @oolyk said in duet2 wifi does not respond:
                    You need to extract the files to the WWW folder on the SD card.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/DuetWebControl-SD.zip
                    • oolykundefined
                      oolyk @Phaedrux
                      @Phaedrux and Jay, thanks but so far nothing worked. extracted the dwc to the sd card, did not help.
                      a stupid question: is it possible that a full firmware {latest) for duet2 wifi , including everything necessary, will be placed in a cloud so that simple copy paste into an sd card will work?
                      also, is there a way to change config.g thru yat? or with the bare sd card thru usb in the pc?
                        So the wifi module works when using the access point mode, but it can't connect to your own network? The Duet can only connect to 2.4ghz networks, does your router put out a separate 2.4ghz network?
                        • oolykundefined
                          oolyk @Phaedrux
                          @Phaedrux
                          yes. I have a separate 2.4 network.
                          another hint: after months of dead paneldue, I managed to fix the problem (firmware) and it now works. yet the paneldue cannot connect to the duet board. does that help in understanding what is the source of the problem?
                          is it possible that completely wrong config.g blocks connection? and if so, how can I access the config.g while I cannot talk to the board?
                          thank you for your patience.
                            Post your full config.g
                            Do you have the command to enable the PanelDue in your config.g?
                            M575 P1 B57600 S1
                            • oolykundefined
                              oolyk
                              https://docs.google.com/document/d/1Bdd7taF6CYyKC1IcAW1qdQgT3Mw4bWTz/edit?usp=sharing&ouid=103516884958399788064&rtpof=true&sd=true
                              this is the config.g from the firmware I had newly downloaded and is completely wrong for me. connected to pc thru usb, I cannot change anything in it or replace the entire file.
                              by the way, the paneldue is active but would not connect.
                                jay_s_uk @oolyk
                                @oolyk yea, that config won't work with 3.4.5
                                you're probably best off generating a new one for your machine using the configurator https://configtool.reprapfirmware.org/
                                • oolykundefined
                                  oolyk
                                  here is a copy of my last working config:
                                  https://drive.google.com/file/d/1j4c8mMl5Ldy47qrH7TA3_doUThTSzMDt/view?usp=sharing
                                  how to load it into my duet2 board when i cant connect to it? sd card thru usb to pc is locked and not changeable (tried to unlock it in the pc, did not work)
                                  I can do bossa but which files I use for it?
                                    jay_s_uk @oolyk
                                    @oolyk those files live on the SD card so if your SD card is locked and not working, you need a new one
                                    • oolykundefined
                                      oolyk @jay_s_uk
                                      @jay_s_uk this is micro sd and it does not any lock in it so it must be in the pc, but as I said I could not unlock it.
                                        jay_s_uk @oolyk
                                        @oolyk then try a different pc. otherwise replace the sd card
                                        • oolykundefined
                                          oolyk @jay_s_uk
                                          @jay_s_uk I just thought about something. I loaded the firmware with bossa. it has couple of internal settings and one of them is "lock". they recommend locking and I did.
                                          so now i will start all over again and try without locking.
                                            jay_s_uk @oolyk
                                            @oolyk that has nothing to do with the sd card. the firmware should be locked as instructed
