Duet 2 Wifi fried?
I am running duet 2 wifi board on e3d toolchanger.
I have all 4 tools on my device and needed to rebuild tool 2 due to a print failure that clogged up the hotend.
When I picked up tool 2 and proceeded to turn on the hotend heater it became unresponsive. I was re-using a heater component I had recovered from another tool for my rebuilt hotend, which was connected to a new thermistor same part cooling fans and hotend fans.
I shut down the printer and powered it again and it is only showing a blue LED light. The blue led light that was coming on was the one at the same level as the motor connections and not near the sdcar. I couldn't connect to the printer any more. Web interface was not up.
I then proceeded to plug in the usb cable to my laptop after verifying that the sdcard was not corrupted.
Wifi came back up and I was able to connect to my printer. The 2 led lights on duet 2 near sdcard slot lighted up and appeared to look ok. I even attempted to home the printer but that operation failed, which I expected since 5v doesnt have enough power for that.
I also measured the voltage at the dc power out to the duet 2 , when the blue light was on and it was 24v .
Any help would be appreciated to trouble shoot this further.
Thx
@incurio It sounds most likely that the 5V regulator may have blown. This may have been caused by a short in tool wiring, hard to say. Check this guide for diagnosis https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond and post a good, clear image of the board, particularly the area around the 3.3V and 5V regulators, U2 and U3. Replacement parts are available, see https://docs.duet3d.com/en/User_manual/Troubleshooting/Parts#voltage-regulators-1
@droftarts here is photo when powered up using the micro USB
There is a red led light on near left side of image, I hadn't noticed that before.
Will fixing this require soldering work to replace fuse?
Thx
@incurio I can't see any obvious signs of damage on the 5V and 3.3V regulators, but that doesn't necessarily mean that they are okay. The lit LED is the Z endstop indicator LED, see https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#led-indications
You appear to have a Z endstop plugged in (though no X or Y endstop?), so it's probably not relevant.It's difficult to tell what is at fault. I would disconnect everything, then power the board only via mains power. If the 5V and 3.3V LEDs come on, and using a multimeter you can read 5V and 3.3V on some pin that provides these, it's probably a short in the wiring. If they don't, it could still be a short, but it has caused the failure of at least one of the regulators, probably the 5V regulator.
@droftarts I measured the resistance of the heating element and it showed very little resistance 0.3 , I think this is the culprit. It is the only used component that I used.
Assumming this is correct, what is the fix for this? Do you have a part I should look for to attempt a fix?
thx
@incurio If the heating element shorted, probably the main fuse has blown, rather than the voltage regulator. Check the 7.5A fuse by the power input.
Here is 7.5A fuse and 1.5A side by side.
I think 7.5A is blown. Not sure about 1.5A it looks clean.
I checked the 15A fuse also and it looks clean it has a connecting metal strip
Please Advise,
Thx
@incurio I replaced 7.5 and 1.5 fuse and it is working, thx
@incurio The 7.5A fuse is definitely blown. The other fuse is for the fans, and looks okay; it should be a 1A fuse.
