    MKS_Mini LCD_12864 -SD1
    PanelDue
    • adhanabalundefined
      adhanabal
      Im using MKS mini lcd with duet wifi board - Everything works fine
      Only issue is i dont find files from External SD card, But in web interface i can see it is reading the external sd card files.
      what could be the reason?
      Firmware version :3.4.5
      droftartsundefined adhanabalundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @adhanabal
        @adhanabal which "duet wifi board" do you have? Send M115 and post the response.
        I'm not sure what you mean when you say you can read them in DWC, but can't find them. Do you mean when you click on them in DWC, it says 'file not found'? Can you do a screen grab of what you see? Also check that your DWC version is the same as the firmware version. Check these in the System settings tab in DWC.
        adhanabalundefined 1 Reply Last reply Reply Quote 0
          adhanabal @droftarts
          @droftarts i can see the files from external memory card in DWC, but when clicking on lcd display print section i can only see SD0 files, SD1 files are not visible.
            @adhanabal If you can see them, and execute them, in DWC, it sounds more like an issue with the menu system on the LCD defaulting to SD0. Which menu set are you using on the LCD (see https://docs.duet3d.com/User_manual/Connecting_hardware/Display_12864_menu#configuration)
            From what I understand, @JadonM's Ultimate Duet Menu System is the only one that works with external SD cards, though I haven't tested this myself. Unfortunately I'm not able to test this on my machine currently (it's in pieces, again).
              adhanabal @adhanabal
              @adhanabal im using jottesman - DUET3D_12864LCD_MenuFiles
              I will try other one you mentioned and will update you.
                @droftarts yes Ultimate Duet Menu System works
                • dc42undefined dc42 marked this topic as a question
                • dc42undefined dc42 has marked this topic as solved
