Solved Thermistor 104nt-4-r025h42g
Hello Tony,
I feel lost.
I think you can trust this:
H1 T0 is linked to with 2 cables to E0Temp 9,4kOhm
H2 T1 is linked to the bottom board with the resistor 108Ohm
H3 T2 is linked with 4 wires connected to one of the top 150kOhm
H4 T3 is linked with 2 cables to E5Temp 9,4kOhmThe setup worked before the firmware update with all sensors except T2
But I have no idea why some tools switched from active in inactive an back. I just does not make sense to me.
I think it would be the best to get access to the first tool for the very beginning.
I need a reference point for the first tool.
I tried these things to see at least a reaction on the first tool.
M308 S1 P"duex.e1temp" Y"thermistor" T100000 B4138
;M308 S1 P"temp0" Y"rtd-max31865"
;M308 S1 P"spi.cs0" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughterboard connectorBut I think I might have messed up some numbers.
@MIke-1 i agree lats sort the first tool out.
If its on e0temp then you need to use P"e0temp" in the M308 try that.
Do you have any information about the thermistor in T0 - 9.4Kohm is strange for an extruder, 94Kohm otoh would be in the right ball park.
P"e0temp" did not help the heater ist n/a
I think the resistance is not a big issue because this here worked:
M305 S"T0" P1 T100000 B4138 C0 -
@MIke-1 I checked your wiring image again, posting here to make it easier to reference:
https://forum.duet3d.com/assets/uploads/files/1677954007806-87d3ed42-0e46-4a99-b7dd-e0b7291af44d.jpgAnd it does look like you have something plugged into e0temp so something else is failing please send M98 Pconfig.g from the console and see what errors you get back.
@T3P3Tony said in Thermistor 104nt-4-r025h42g:
M98 Pconfig.g
My latest config is uploaded Here is the respondse, but it does not make sense to me:
M98 Pconfig.g
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Unknown pin name 'duex.e1heat'
Error: Heater 1 not found
Error: Heater 1 does not exist
Error: Sensor 4 does not exist
Error: Bad command: mp"" Y"thermistor" T100000 B4138
Error: in file macro line 108: M308: missing parameter 'S'
Error: Heater 4 not found
Error: Heater 4 does not exist
Error: Unknown pin name 'duex.fan0'
Error: Fan number 0 not found
Error: Unknown pin name 'duex.fan1'
Error: Fan number 1 not found
Error: Unknown pin name 'duex.fan2'
Error: Fan number 2 not found
Warning: Heater 0 predicted maximum temperature at full power is 403°C
Warning: Heater 2 predicted maximum temperature at full power is 842°C
Warning: Heater 3 predicted maximum temperature at full power is 494°C
Error: Heater 5 not found
Error: Heater 6 not found
Error: Heater 7 not found -
@MIke-1 now we are getting somewhere. We need to fix those errors.
if you look in the documentation here:
https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pin-namesyou will not find "duex.e1heat" the e1heat connector is on the duet 2 mainboard so change that to "e1heat" without the duex and then restart and run M98 Pconfig.g again
you will hopefully see that first error disappear and then probably the next two which relate to heater 1 not being setup correctly.
Next error, these three lines:
Error: in file macro line 108: M308: missing parameter 'S'This line is possibly the culprit
M308 S4 P"duex.e5temp" Y"thermistor" T100000 B4138try the following in its place
M308 S1 P"e5temp" Y"thermistor" T100000 B4138
Once again save, run M98 Pconfig.g and lets see if thats fixed some more of the issues.
Using the same process have a a go fixing the other errors.
M98 Pconfig.g
Now it looks better:
M98 Pconfig.g
FTP is disabled
TELNET is disabled
Error: in file macro line 109: M308: missing parameter 'S'
Warning: Heater 1 predicted maximum temperature at full power is 715°C
Error: Heater 7 not foundI updated the config but do not understand the issue.
The thermistor is the upper one with the 2 blue and 2 yellow wires just using 2
See this from me previous reply:
; Heater4
;M308 S1 P"e5temp" Y"thermistor" T100000 B4138
M308 S4 "P"duex.e3temp"" Y"thermistor" T100000 B4138 ; configure sensor 4 as thermistor on pin duex.e6temp
M308 H4 C"duex.e3heat" T4 ; create nozzle heater output on duex.e6heat and map it to sensor 4
M307 H4 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H4 S280This here is said to be the faluty line:
M308 H4 C"duex.e3heat" T4Here is the response:
M98 Pconfig.g
FTP is disabled
TELNET is disabled
Error: in file macro line 110: M308: missing parameter 'S'
Error: Heater 7 not foundBut why S1 in M308 S1?
@MIke-1 said in Thermistor 104nt-4-r025h42g:
sorry my cut and paste mistake. it should have been
M308 S4 P"e5temp" Y"thermistor" T100000 B4138to replace this line
M308 S4 "P"duex.e3temp"" Y"thermistor" T100000 B4138 ; configure sensor 4 as thermistor on pin duex.e6tempif S4 is actually connected to e3temp rather than e5temp then adjust the line accordingly.
M98 Pconfig.g
FTP is disabled
TELNET is disabled
Error: in file macro line 111: M308: missing parameter 'S'
Error: Heater 7 not foundThis is the current code:
; Heater4
;M308 S4 "P"duex.e3temp"" Y"thermistor" T100000 B4138
M308 H4 C"duex.e3heat" T4 it to sensor 4
M143 H4 S280 ; set temperature limit for heater 4 to 280CI think this should work
M308 S4 P"duex.e3temp" Y"thermistor" T100000 B4138 ; the yellow and blue cable on the picture on the extension board
M308 H4 C"duex.e3heat" T4 ; heater 3 on the extension boardThanks a lot!!!
@MIke-1 that yellow and blue cable looks like its wired to a PT100 because its 4 wires not 2. but that aside, there is a fault in the config.g that it preventing the sensor from being created. looking at it with fresh eyes i think i spot the issue, there is another M308 in there which should be a M950
please replace this:
; Heater4
;M308 S1 P"e5temp" Y"thermistor" T100000 B4138 ;M308 S1 P"e5temp" Y"thermistor" T100000 B4138 M308 S4 P"e5temp" Y"thermistor" T100000 B4138 ;M308 S4 "P"duex.e3temp"" Y"thermistor" T100000 B4138 M308 H4 C"duex.e3heat" T4 it to sensor 4 M307 H4 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H4 S280 ; set temperature limit for heater 4 to 280C
with this
; Heater4
M308 S4 P"e3temp" Y"thermistor" T100000 B4138 M950 H4 C"duex.e3heat" T4 it to sensor 4 M307 H4 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H4 S280 ; set temperature limit for heater 4 to 280C
I don't necessarily think we will get a correct temperature reading but we should get a configuration that stops failing at that point.
Also please update this table:
H4 T3 is linked with 2 cables to E5Temp 9,4kOhmbecause it looks like at least H4 is using S4 and is using a 4 wire sensor.
M98 Pconfig.g
FTP is disabled
TELNET is disabled
Warning: Heater 4 predicted maximum temperature at full power is 575°C
Error: Heater 7 not foundThe T3 cable has 4 wire but is connected to only 2 pins on the board.
H1 T0 is linked to with 2 cables to E0Temp 9,4kOhm ;Sensor is on H1 and working
H4 T3 is linked with 2 cables to E3Temp 9,4kOhm ;Sensor is on H4 and workingNow it is time to fix the other 2 sensors
@MIke-1
T1 is working
M308 S2 P"spi.cs1" Y"rtd-max31865"T2 is a 104nt-4-r025h42g should it be pluged into the board itself? How do I connect to that sensor?
M308 S3 P"spi.cs3" Y"104GT-2" is not workingM98 Pconfig.g
FTP is disabled
TELNET is disabled
Error: Unknown sensor type name "104gt2"
Warning: Sensor number 3 has not been defined
Yes if it's a normal thermistor it needs to be connected to the board itself on a temperature input and not the PT100 daughterboard.
Then you'd need commands similar to these depending on what pin you use and what values are needed for the thermistor.
M308 S4 P"e3temp" Y"thermistor" T100000 B4725 C7.06e-8 M950 H4 C"duex.e3heat" T4 it to sensor 4
This is just an example though.
Can you post your config.g as it currently is now?
Now the heaters are all working
I used another plug for the sensor.Sensorless homing is crashing at least for the x axis.
Might be a good idea to start a new thread about this issue. Include your config.g and homing files.
