    Voron 2.4 with 6HC & 3HC
    712
    • wbrokow1undefined
      wbrokow1
      I am initially setting up my voron . Almost everything works except the extrusion. Using 3.4.5 for boards and dwc. I updated using the web interface. The extrusion motor is plugged into the 3HC. I have verified that it not a dead extrusion motor. Any motor plugged into the board doesn’t work. Any help is appreciated. I am almost there!
      T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @wbrokow1
        @wbrokow1 please provide more information:
        config.g
        and also send M115 Bn where "n" is the address of the 3HC (by default this would be 1).
          Phaedrux Moderator @wbrokow1
          @wbrokow1 said in Voron 2.4 with 6HC & 3HC:
          Is the tool selected?
          wbrokow1undefined 1 Reply Last reply Reply Quote 0
          • wbrokow1undefined
            wbrokow1 @Phaedrux
            This is what I got with M115 B1
              dc42 administrators @wbrokow1
              @wbrokow1 does M122 B1 work?
              • wbrokow1undefined
                wbrokow1 @dc42
                @dc42 No, it doesn't. Could the board not be recognized?
                wbrokow1undefined dc42undefined 3 Replies Last reply Reply Quote 0
                • wbrokow1undefined
                  wbrokow1 @wbrokow1
                  @wbrokow1 oh M122. let me try!
                  • wbrokow1undefined
                    wbrokow1 @wbrokow1
                    @wbrokow1 no , m122 says response too long.
                      @wbrokow1 try starting the object model plugin. Then look under the "boards" key to see the data for board 1.
                      I suspect that your 3HC may be running somewhat old firmware. If that's the case:
                      1. Upload the version 3.4.4 EXP3HC firmware to the Duet via the Install Update facility;
                      2. Power down the system. Set the 3HC switches all off. Then power the system up again. The 3HC should load new firmware from the 6HC. When its Status LED is flashing in sync with the 6HC again, power the system down and reset the switches to address 1.
                      • wbrokow1undefined
                        wbrokow1 @dc42
                        @dc42 where is the "Install Update Facility" ?
                        Thanks
                          @wbrokow1 it's on the Setup/Machine Specific page. You can also use the upload facility on the System Files page.
                          wbrokow1undefined 2 Replies Last reply Reply Quote 0
                          • wbrokow1undefined
                            wbrokow1 @dc42
                            @dc42 OK, 1 Problem solved. (thank you) Another arises:
                            I get an error driver 1.0 error phase A shorted to Vin.
                            • wbrokow1undefined
                              wbrokow1 @dc42
                              @dc42 ok swapped in another motor directly connected to board and get the same error.
                              Board issue?
                                response too long means you need to look in the Console tab to see the longer response.
                                • wbrokow1undefined
                                  wbrokow1 @Phaedrux
                                  @Phaedrux OK , I see it thanks. Same error, It was fixed though. Thanks
                                    Can you send M122 and M122 B1 in the console and then copy and paste the results here please?
                                    • wbrokow1undefined
                                      wbrokow1 @Phaedrux
                                      @Phaedrux 3/24/2023, 3:09:16 PM m122
                                      RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
                                      Board ID: 08DJM-9P63L-DJ3T8-6JKDL-3SN6Q-KS7BA
                                      Used output buffers: 3 of 40 (14 max)
                                      Static ram: 152760
                                      Dynamic ram: 97332 of which 184 recycled
                                      Never used RAM 100324, free system stack 138 words
                                      Tasks: NETWORK(ready,30.0%,210) ETHERNET(notifyWait,0.1%,561) HEAT(notifyWait,0.0%,328) Move(notifyWait,0.0%,259) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,8.5%,57) MAIN(running,61.3%,925) IDLE(ready,0.1%,30), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:01:28 ago, cause: power up
                                      Last software reset at 2023-03-24 13:40, reason: User, GCodes spinning, available RAM 100324, slot 0
                                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      Step timer max interval 126
                                      MCU temperature: min 23.0, current 35.6, max 35.8
                                      Supply voltage: min 24.1, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                      12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
                                      Events: 0 queued, 0 completed
                                      Driver 0: standstill, SG min 0, mspos 1016, reads 31060, writes 16 timeouts 0
                                      Driver 1: standstill, SG min 0, mspos 24, reads 31060, writes 16 timeouts 0
                                      Driver 2: standstill, SG min 0, mspos 1016, reads 31057, writes 19 timeouts 0
                                      Driver 3: standstill, SG min 0, mspos 24, reads 31060, writes 16 timeouts 0
                                      Driver 4: standstill, SG min 0, mspos 130, reads 31057, writes 19 timeouts 0
                                      Driver 5: standstill, SG min 0, mspos 598, reads 31057, writes 19 timeouts 0
                                      Date/time: 2023-03-24 15:09:12
                                      Slowest loop: 16.87ms; fastest: 0.05ms
                                      === Storage ===
                                      Free file entries: 10
                                      SD card longest read time 4.4ms, write time 0.0ms, max retries 0
                                      DMs created 125, segments created 3, maxWait 17600ms, bed compensation in use: none, comp offset 0.000
                                      === MainDDARing ===
                                      Scheduled moves 10, completed 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                      === AuxDDARing ===
                                      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                      Heater 1 is on, I-accum = 0.0
                                      Segments left: 0
                                      Movement lock held by null
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      SBC is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Aux2 is idle in state(s) 0
                                      Code queue is empty
                                      === CAN ===
                                      Messages queued 795, received 715, lost 0, boc 0
                                      Longest wait 1ms for reply type 6018, peak Tx sync delay 10, free buffers 50 (min 49), ts 444/443/0
                                      Tx timeouts 0,0,0,0,0,0
                                      === Network ===
                                      Slowest loop: 16.54ms; fastest: 0.03ms
                                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                      HTTP sessions: 1 of 8
                                      = Ethernet =
                                      State: active
                                      Error counts: 0 0 0 1 0 0
                                      === Multicast handler ===
                                      Responder is inactive, messages received 0, responses 0
                                      3/24/2023, 3:07:56 PM Connection established
                                      3/24/2023, 2:00:37 PM Connection interrupted, attempting to reconnect...
                                      m122 b1
                                      Diagnostics for board 1:
                                      Duet EXP3HC rev 1.01 or earlier firmware version 3.4.4 (2022-10-14 11:45:56)
                                      Bootloader ID: not available
                                      All averaging filters OK
                                      Never used RAM 158932, free system stack 200 words
                                      Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.4%,99) MAIN(running,91.2%,407) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
                                      Last reset 00:02:28 ago, cause: software
                                      Last software reset data not available
                                      Driver 0: pos 0, 1746.2 steps/mm,standstill, SG min 0, mspos 2, reads 46407, writes 16 timeouts 0, steps req 0 done 0
                                      Driver 1: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 46413, writes 11 timeouts 0, steps req 0 done 0
                                      Driver 2: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 46413, writes 11 timeouts 0, steps req 0 done 0
                                      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                      Peak sync jitter -2/10, peak Rx sync delay 177, resyncs 0/0, no step interrupt scheduled
                                      VIN voltage: min 24.2, current 24.3, max 24.3
                                      V12 voltage: min 12.3, current 12.3, max 12.3
                                      MCU temperature: min 26.4C, current 31.6C, max 31.6C
                                      Last sensors broadcast 0x00000000 found 0 165 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 1216, send timeouts 0, received 1339, lost 0, free buffers 37, min 37, error reg 0
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                        @wbrokow1 what is the issue at this point? I don't see any phase errors from the drivers in those M122 reports and the 3HC is responding to can messages.
                                        • wbrokow1undefined
                                          wbrokow1 @T3P3Tony
                                          @T3P3Tony thanks for responding. basically the extruder was not extruding. I swapped to the second driver on the 3hc (1.1) and it worked. So I guess I have a bad driver on the 3hc board. Which is disappointing. I thought that spending extra for a quality board like the Duet would be w/o as many headaches as chinese crap.
                                            Can you setup the extruder motor on that original driver again and try to extrude? Do you get any error messages? After trying to extrude, send M122 and M122 B1 again and copy paste the results here please.
                                            When and where did you purchase the Duet boards? If we can verify the driver has failed and you're within the warranty period and the boards were purchased from an authorized vendor you would be entitled to warranty replacement.
