    WiFi disconnect errors
    79
    12.1k
    • Jareryundefined
      Jarery
      Made a big change. Switched my router system to an Netgear Orbi Mesh network.
      Downloaded the newest firmware. Couldn't use the Newest wifi server 1.20B8 no sleep, any command I types into web console just said wifi server stopped, and repeated my calibration results….
      Firmware Version: 1.20beta7 (2017-11-11)
      WiFi Server Version: 1.20b8
      Web Interface Version: 1.19.3
      Edit: any associated disconnections so far have been able to reconnect via connect button.
      With the new router system, it seems to stay connected to router, just disconnects from browser, probably due to laptop sleep but router page always shows connected, and always able to ping.
      The router I replaced was an Asus Rt-AC3100 with merlin firmware, which somehow would drop the client and the only method of reconnection was :
      1. cycle wifi module on/off
      2. cycle printer on/off
      3. wait about 30 min and reconnect via connect button in browser. This was about 50/50 success rate.
      • KeeganBundefined
        KeeganB
        David, testing DuetWifiServer 1.20b8:
        • A M122 diagnostic report produced when WiFi was connected
          [c]Connecting…
          Printer is now online.
        M122
        SENDING:M122
        Used output buffers: 2 of 32 (9 max)
        RepRapFirmware for Duet WiFi version 1.20beta7 running on Duet WiFi 1.0
        Board ID: 08DDM-9FAM2-LW4SD-6JTF0-3S86N-TLWZX
        Static ram used: 15472
        Dynamic ram used: 99192
        Recycled dynamic ram: 4120
        Stack ram used: 3992 current, 9196 maximum
        Never used ram: 3092
        Last reset 00:54:35 ago, cause: reset button or watchdog
        Last software reset reason: User, spinning module GCodes, available RAM 7296 bytes (slot 3)
        Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
        Error status: 0
        [ERROR] Error status: 0
        Free file entries: 9
        SD card longest block write time: 14.6ms
        MCU temperature: min 29.0, current 33.5, max 34.6
        Supply voltage: min 12.2, current 12.7, max 12.9, under voltage events: 0, over voltage events: 0
        Driver 0: ok
        Driver 1: ok
        Driver 2: ok
        Driver 3: ok
        Driver 4: standstill
        Date/time: 2017-11-14 20:25:36
        Slowest main loop (seconds): 2.192716; fastest: 0.000042
        MaxReps: 5, StepErrors: 0, FreeDm: 123, MinFreeDm 120, MaxWait: 4216772852ms, Underruns: 0, 0
        Scheduled moves: 32211, completed moves: 32181
        Bed compensation in use: none
        Bed probe heights: -0.042 0.010 -0.062 -0.060 -0.063
        Bed heater = 0, chamber heater = -1
        Heater 0 is on, I-accum = 0.3
        Heater 1 is on, I-accum = 0.5
        Segments left: 1
        Movement lock held by file
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is doing "G1 X9.258 Y-3.758 F1839" in state(s) 0
        serial is ready with "M122" in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        Network state is running
        WiFi firmware version 1.20b8
        WiFi MAC address 5c:cf:7f:ef:51:6f
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 29096
        WiFi IP address 10.0.1.161
        WiFi signal strength -39dBm, reconnections 0, sleep mode modem
        HTTP sessions: 1 of 8
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        [/c]
        • The make and model of your WiFi router
          Tenda AC18 - Does the problem occur mainly (or only) during printing, or does it occur equally frequently when the printer is idle?
          Both (from past experience) - When the problem occurs, are you able to reconnect by pressing the Connect button in DWC?
          Not this time - If you are unable to connect, are you still able to ping the IP address of the Duet WiFi?
          Could not ping the IP address - Anything else that you think may be correlated with disconnections occurring
          I had 24 hours of successful connection with DuetWifiServer 1.20b8-nosleep prior to this test. It took me 3 tries to upload the DuetWifiServer 1.20b8 firmware. I renamed the file, then uploaded via DWC. It "worked" but then via pronterface M552 only would report "wifi module starting." It took two consecutive runs of M997 S1 to get it fully working. I then started homing it, G32's and preheating. After about 15 minutes of that, I started a print. It disconnected 27 mins after the print started. This was a total connection time of about 40 mins.
        Artemis
        Rostock Max v2
        Orion
        • KeeganBundefined
          KeeganB
          Ok, a new problem….
          I revert back to WifiServer 1.20b8-nosleep since it had previously been working great. It took 2 installs to get it to work. Since then I've had 3 discontents in the last 2 hours. These were different though.
          The first was seems harmless, it disconnected and i just clicked connect in DWC and everything was up and running again. no problem.
          The second two were different. Both times They reported a new AJAX error, that gave no reason. It didn't have the normal timeout. Image attached. Both times, I could not connect to the duet via USB with pronterface. It was like the whole board was locked out or frozen. A power cycle resolved it the first time, but then it disconnected again near immediately. The second time I just let it sit and after about 10mins I was able to simply click connect in DWC again.
          I am lost.
          UPDATE: APPARENTLY I HAVEN'T SLEPT ENOUGH. I WAS TRYING TO PRINT A .STL FILE. INTERESTINGLY THIS CREATES AN IMMEDIATE DISCONNECT AND LOCKS UP THE BOARD.
          David, any way to adjust the firmware to prompt an error message rather than locking up the board for those times when we try to print an STL?
          Artemis
          Rostock Max v2
          Orion
          • zlowredundefined
            zlowred
            David, I'm not sure if that's the same problem or not, but here is what I'm observing:
            WiFi connection works most of the time, signal strength looks ok (between -60dBm and -50dBm) but sometimes it just fails throwing AJAX error and doesn't come back until I reset the WiFi module by using M552 S0 followed by M552 S1.
            It was always the case, and I thought it just a signal level issue. I tried using two different routers (one noname provided by my provider, the other one is Apple TimeCapsule). Now the strange part I noticed just recently, is that when it fails, it is till showing as connected in the WiFi router web UI. Even more, if I connect using the USB and issue M122, it is showing wifi as connected, with good signal strength and valid IP address. That makes me thinking that at least in some cases what looks like a WiFi connectivity issue is not related to connectivity. I believe it might be the web server firmware crashing or hanging.
            It happens pretty often, and I'm happy to provide further diagnostic data - just tell me what exactly do I need to do.
              zlowred, please upgrade to the just-released DuetWiFiFirmware 1.20beta8 and DuetWiFiServer 1.20beta9. Connect a PC via USB and send M111 S1 P14 to enable the new WiFi debugging feature. You will get a few WiFi debug messages during startup and initial connection to your router, but there should be no more after that. If the disconnect occurs again, look at the console on the PC to see whether any more debug messages have been received, and report what you find.
              • zlowredundefined
                zlowred
                That means to keep USB connected all the time, right? (no problems with that, just to confirm)
                added: maybe it's better to keep debug log somewhere on the flash card so that nothing is lost in case when PC went to sleep for example.
                • peirofundefined
                  peirof
                  I think I've sent my Duet3D WiFi to England, because of symptoms very similar to those described …
                  I hope not....
                    @peirof:
                    I hope not....
                    Yours was different, it wouldn't upload new wifi firmware.
                    • peirofundefined
                      peirof
                      i hope….
                      • zlowredundefined
                        zlowred
                        So I was able to reproduce the disconnect. Below is the full log. Note that I temporarily disabled M552 S1 in the config.g so that full log is captured.
                        I issued M122 after the disconnect in case it contains something useful.
                        RepRapFirmware for Duet WiFi Version 1.20beta8 dated 2017-11-17
                        Executing config.g...HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Done!
                        Network disabled.
                        RepRapFirmware for Duet WiFi is up and running.
                        M111 S1 P14
                        Debugging enabled for modules: WiFi(14)
                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
                        ok
                        M552 S1
                        ok
                        WiFi:
                        WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,7)
                        WiFi:
                        WiFi: load 0x4010f000, len 1384, room 16
                        WiFi: tail 8
                        WiFi: chksum 0x2d
                        WiFi: csum 0x2d
                        WiFi: v00007fff
                        WiFi: ~ld
                        WiFi module started
                        WiFi: mode : sta(ec:fa:bc:02:1e:41)
                        WiFi: add if0
                        WiFi: scandone
                        WiFi: sleep enable,type: 2
                        WiFi: scandone
                        WiFi: state: 0 -> 2 (b0)
                        WiFi: state: 2 -> 3 (0)
                        WiFi: state: 3 -> 5 (10)
                        WiFi: add 0
                        WiFi: aid 3
                        WiFi: cnt
                        WiFi:
                        WiFi: connected with Lrrr, channel 1
                        WiFi: dhcp client start...
                        Wifi module is connected to access point Lrrr, IP address 192.168.1.102
                        WiFi: ip:192.168.1.102,mask:255.255.255.0,gw:192.168.1.1
                        WiFi: pm open,type:2 0
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        WiFi: p->ref == 1
                        M122
                        Used output buffers: 1 of 32 (8 max)
                        RepRapFirmware for Duet WiFi version 1.20beta8 running on Duet WiFi 1.0
                        Board ID: 08DDM-9FAM2-LW4S8-6JTDD-3SJ6P-9MXBY
                        Static ram used: 15488
                        Dynamic ram used: 99624
                        Recycled dynamic WiFi:
                        ram: 3672
                        Stack ram used: 4328 current, 5324 maximum
                        NeveWiFi: LINK
                        r used ram: 6964
                        Last reset 00:02:07 ago, cause: power up
                        Last software reset reason: User, spinning module GCodes, available RAM 6960 bytes (slot 4)
                        Software reset code 0x0003, HFSR 0x00000000, CFSRWiFi: 	xmit: 0
                        Error status: 0
                        Free file entries:WiFi: 	recv: 0
                         10
                        SD card longest block write time: 0.0ms
                        MCU temperature: min 31.5, current 34.8, max 35.0
                        Supply voltage:WiFi: 	fw: 0
                         min 0.3, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0
                        Driver 0: ok
                        Driver 1: ok
                        Driver 2: ok
                        Driver 3: okWiFi: 	drop: 0
                        Driver 4: ok
                        Date/time: 2017-11-18 11:55:08
                        Cache data hit count 436514026
                        Slowest main loop (seconds): 0.099160; fastest: 0WiFi: 	chkerr: 0
                        .000034
                        MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                        Bed compensation iWiFi: 	lenerr: 0
                        n use: none
                        Bed heater = 0, chaWiFi: 	memerr: 0
                        mber heater = -1
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        telnet is idle in stateWiFi: 	rterr: 0
                        (s) 0
                        file is idle in state(s) 0
                        serial is ready with "M122" inWiFi: 	proterr: 0
                         state(s) 0
                        Failed mWiFi: 	opterr: 0
                        essages: pending 0, notready 0, nWiFi: 	err: 0
                        oresp 0
                        WiFi firmware version 1.20b9
                        WiFi MAC address ec:fa:bc:02:1e:41
                        WiFi Vcc 3.35, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 25224
                        WiFi IP address 192.168.1.102
                        WiFi signal strength -58dBm, reconnections 0, sleep mode WiFi: 	cachehit: 0
                        modem
                        Socket states:  0 0 0 0 0 0 0 0
                        ok
                        WiFi:
                        WiFi: ETHARP
                        WiFi: 	xmit: 4
                        WiFi: 	recv: 2
                        WiFi: 	fw: 0
                        WiFi: 	drop: 39
                        WiFi: 	chkerr: 0
                        WiFi: 	lenerr: 0
                        WiFi: 	memerr: 0
                        WiFi: 	rterr: 0
                        WiFi: 	proterr: 39
                        WiFi: 	opterr: 0
                        WiFi: 	err: 0
                        WiFi: 	cachehit: 1605
                        WiFi:
                        WiFi: IP
                        WiFi: 	xmit: 1614
                        WiFi: 	recv: 1892
                        WiFi: 	fw: 0
                        WiFi: 	drop: 1
                        WiFi: 	chkerr: 1
                        WiFi: 	lenerr: 0
                        WiFi: 	memerr: 0
                        WiFi: 	rterr: 0
                        WiFi: 	proterr: 0
                        WiFi: 	opterr: 0
                        WiFi: 	err: 0
                        WiFi: 	cachehit: 0
                        WiFi:
                        WiFi: IGMP
                        WiFi: 	xmit: 4
                        WiFi: 	recv: 1
                        WiFi: 	drop: 0
                        WiFi: 	chkerr: 0
                        WiFi: 	lenerr: 0
                        WiFi: 	memerr: 0
                        WiFi: 	proterr: 0
                        WiFi: 	rx_v1: 0
                        WiFi: 	rx_group: 0
                        WiFi: rx_general: 1
                        WiFi: rx_rmit: 1174
                        WiFi: 	recv: 1831
                        WiFi: 	fw: 0
                        WiFi: 	drop: 0
                        WiFi: 	chkerr: 0
                        WiFi: 	lenerr: 0
                        WiFi: 	memerr: 0
                        WiFi: 	rterr: 0
                        WiFi: 	proterr: 0
                        WiFi: 	opterr: 0
                        WiFi: 	err: 0
                        WiFi: 	cachehit: 0
                        The "WiFi: p->ref == 1" messages appeared around every few seconds or so, and the "AJAX error" appeared after the last "WiFi: p->ref == 1" message. I waited for another 10 minutes, but didn't see these messages after the "AJAX error"
                          Thanks. Did the p->ref==1 messages start appearing as soon as you connected, or not until shortly before the disconnection message?
                          • zlowredundefined
                            zlowred
                            First message is seconds after I connected. Others are at irregular intervals between few seconds and somewhere around a minute between each other.
                            In the meanwhile, I've replaced the wifi module with ESP-07S with external antenna, and it didn't change anything, e.g. behaviour is exactly the same.
                              I've never seen those p->ref==1 messages on my test systems. I suspect they are related to the disconnections. Please do a few more tests, to establish how many p->ref messages you get, before they start appearing every few seconds and the disconnection occurs.
                              Edit: those p->ref == 1 messages indicate an assertion failure within the TCP/IP stack, so they are definitely indicative of something going wrong.
                              • zlowredundefined
                                zlowred
                                Sure, I'll collect more data and post it here
                                In the meanwhile – I can build the firmware myself, so if you need me to build it with maybe some additional debug flags, or quickly test some changes without releasing the new beta version – feel free to ask.
                                  Thanks. Those debug messages come from the firmware on the wifi module, so it's that firmware that is likely to contain the fault.
                                    Please can anyone else who is still getting WiFi disconnections even though the RSSI is good do the following:
                                    1. Upgrade to the just-released DuetWiFiFirmware 1.20beta8 and DuetWiFiServer 1.20beta9.
                                    2. Connect a PC via USB and send M111 S1 P14 to enable the new WiFi debugging feature. If you have already started wifi, send M552 S-1 and then M552 S1 to restart it. You will get some WiFi debug messages during startup and connection to your router, similar to the following:
                                    WiFi:
                                    WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,6)
                                    WiFi:
                                    WiFi: tail 8
                                    WiFi: chksum 0x2d
                                    WiFi: csum 0x2d
                                    WiFi: v00007fff
                                    WiFi: ~ld
                                    WiFi module started
                                    WiFi: mode : sta(a0:20:a6:19:28:23)
                                    WiFi: add if0
                                    WiFi: scandone
                                    WiFi: scandone
                                    WiFi: add 0
                                    WiFi: aid 2
                                    WiFi: cnt
                                    WiFi:
                                    WiFi: connected with ********, channel 6
                                    WiFi: dhcp client start…
                                    Wifi module is connected to access point ********* IP address 192.168.1.123
                                    WiFi: ip:192.168.1.123,mask:255.255.255.0,gw:192.168.1.254
                                    3. Load DuetWebControl in your browser.
                                    4. If/when the wifi disconnects unexpectedly, look at the console on the PC to see whether any more debug messages have been displayed, and report what you find.
                                    • zlowredundefined
                                      zlowred
                                      Hi David,
                                      So I was able to reproduce few more times. Here are my observations:
                                      • (obvious one) I didn't see any debug messages including p->buf==1 while DWC page is not opened
                                      • these p->buf==1 messages always (or most of the time) come out in pairs
                                      • there are no regular intervals between these messages, sometimes I see few per second, sometimes I don't any for 10-15 minutes
                                      • they are not getting more often before the disconnect
                                      • I feel that messages are coming much more often when printer is printing (compared to the idle) - suspect it may be related to some timings, e.g. CPU is busy with something and can't send some command or data to the WiFi module in time. Or maybe noise in power line due to heaters PWM. My power supply is able to provide enough current, so it's not under-voltage, but maybe some noise…
                                      I'll post here if I get more data
                                        Thanks. Please can you install this DuetWiFiServer.bin file twice (the second time you can just send M997 S1 to install it again from the existing SD card file). It will provide a slightly more detailed debug message.
                                        • zlowredundefined
                                          zlowred
                                          Sure, will do. I wonder if there is anything of interest to you in the debug message showing when I do M552 S0 after such disconnect:
                                          WiFi: state: 5 -> 0 (0)
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: tcp_pcb_purge: pcb->state == SYN_RCVD but tcp_listen_pcbs is NULL
                                          Wifi module is idle
                                          WiFi: del if0
                                          WiFi: usl
                                          WiFi: mode : null
                                          Not sure if these pcb->state checks are ok
                                            Yes, those are interesting too, in particular the tcp_pcb_purge messages.
